Question about Westinghouse 22" Widescreen LCD Flat Panel Monitor
I have a Westinghouse LCM-22W2 LCD monitor. I believe my power board is bad. I want to either replace the power board or bad capcitors, if I can find them. I do not know how to take off the back cover, however. It almost looks as if a special key is needed in the lower left corner of the back cover. Does anyone know how to remove the back cover? Ed
  • 1 more comment
  • eddotterer Mar 29, 2009
    The problem I have determined was the board. I did finally figure out how to take the cover off. I took a very small flat head screwdriver and wedged it between the seem of the from part and the back part. This is always dangerous, but I tried anyways. I then turned the screwdrive 90 degress to separate the fron fronm the back. I did this in four areas. This worked fine and did not damage the cover.
  • blueblizzard May 11, 2009
    I have the same problem with the same monitor.
    Where did you purchase a replacement power board?
  • eddotterer Jun 04, 2009
    I ordered my part through partsotre.com. I ordered it in December and have not recevied it. They say it's on national backorder. I have to find another distributer and see if they say the same thing.
    Ed
    President:
  • 1,996 Answers
Have you gone through the user's guide? There are some sleep settings and automatic adjustments that this monitor makes, and other changes that users have inadvertently triggered that seem to be causing quite a bit of confusion these days. Make sure you haven't overlooked the Troubleshooting steps outlined there:
Troubleshooting
No Power
• Make sure the AC cord is plugged into the back of the LCD monitor.
• Make sure the AC power cord is securely connected to an AC outlet.
• Plug another electrical device (like a radio) to the power outlet to verify that the
outlet is supplying the proper voltage.
No Screen Image
• Make sure monitor is turned on.
• Make sure the video cable is securely connected to both the monitor and PC or
Audio/Video apparatus.
• Make sure you have selected the correct video input source
• Adjust the brightness and contrast levels.
“Out Of Range”
• Restart your computer and adjust your desktop resolution and refresh rate to 1680 x
1050 at 60 Hz.
Fuzzy Image
• Set desktop resolution on your PC to 1680 x 1050 at 60 Hz.
• Adjust Phase/Sharpness setting on the monitor
Cannot find 1680 x 1050 under screen resolution on my Display Properties
• You may need to download and install the latest video card driver for your PC.
Listed below are websites for major video card manufacturers:
Nvidia: http://www.nvidia.com/content/drivers/drivers.asp
Intel: http://downloadfinder.intel.com/scripts-df/support_intel.asp
ATI: https://support.ati.com/ics/support/default.asp?deptID=894
Image Too Bright or Too Dark
• Adjust the brightness and contrast levels under the OSD menu.
• Perform Auto Adjust.
Distorted Image
• Reset the LCD monitor by performing the “Reset” function using the OSD.
• Remove extra accessories (such as a VGA extension cord).
Image is Not Centered (size is not scaled correctly)
• Adjust the horizontal and/or vertical position using the OSD.
• Check image size setting.
You can see an online version here: http://www.westinghousedigital.com./pdf/60_User_Manual.pdf
I do not know how to remove the cover from that monitor. Here is a link to Westinghouse customer service technical support: http://www.westinghousedigital.com./contactus.aspx or
Our service and support team is available:
Monday through Saturday
9 AM - 9 PM Eastern Time
1 (866) 287-5555
I hope this helps to resolve your issue.
Posted on Mar 28, 2009
  • efs_perpends
    efs_perpends Mar 29, 2009
    Glad to hear it! A lot of folks have been having problems with these units, it seems..
    I'm glad yours is up and running again.
2 Suggested Answers
  • 13 Answers
SOURCE: Can't remove cover of Westinghouse LCM-22w2 monitor
Hey Ed,
I hope I can help, It doesn't open from the back, it opens from the front.... carefully! There are four support screws, which hold the LCD screen to the desk stand,after removing all the support screws (4) on the back under the support stand cover.(which pull up to remove) (Remember! the whole case and face frame is plastic, so take your time). Work to separate the black face frame around the LCD from the silver case. Its held together by small plastic clips on the face frame to the wall on the LCD case. Start at one of the corners and slowly pry the face frame and silver case apart. (separate it inch by inch, work your way around the case carefully. If one corner doesn't give, go to another side.
Putting back together works reverse, the face frame and the case snap back together, Carefully! And replace screws (4).
Russell
P.S. I have three LCD models from Westinghouse, LCM-22w2, L2210NW and the L1916HW. They all open the same way.
Posted on Jan 03, 2009
What and how much is a power supply board for the westington lcm-22w2 monitor. my tv went out i took it apart checked the circutry to me doesnt look like anythings rong. dont know what the caps are the...
Check here: <a href="http://www.shopjimmy.com/catalogsearch/result/?q=Westinghouse+LCM-22W2">http://www.shopjimmy.com/catalogsearch/result/?q=Westinghouse+LCM-22W2</a><br /> <br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">If you are going to DIY and have proper tools and know safety precaution then please read on:</span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: <a href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Post back what you see inside so we can guide you further and it will help out other people in the future also.</span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><a href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</a><span style="mso-tab-count: 1"> </span></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Capacitors kit: <span style="mso-spacerun: yes"> </span><a href="http://lcdalternatives.auctivacommerce.com/">http://lcdalternatives.auctivacommerce.com/</a><span style="mso-spacerun: yes"> </span>he can make you a set of caps for you.</span><br />
Aug 26, 2010 | Westinghouse Electric LCM-22W2 Monitor
My LCM-22w2 monitor will now rarely start up. It powers up white-screen and won't do anything. Occasionally it powers up OK and works fine.
wford451, You should open up the unit and inspect the "switch-mode-power-supply"/"CCFL inverter supply" printed circuit board for the common 2 problems that create symptoms like yours. Do some reading in my and other CCFL back-lit lcd monitor technicians fixya profiles. They are loaded with solutions to fix your unit. Your LCM 22W2 is no different than any other brand in it's basic design and operation!!! 12fixlouie
Mar 17, 2010 | Westinghouse 22" Widescreen LCD Flat Panel...
Monitor Brightness
most user manuals for these moniters you can get on line (free downloads)
it will explain how to use the buttons on your monitor
Feb 02, 2010 | Westinghouse LCM-19v1 Monitor
I think I also have a bad power board.
Could be a bad fuse in the powerboard,ore look for bad caps...
Jun 09, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
Can't find correct setting for westinghouse lcm22w2 monitor
I don't know if this actually will fix your problem, but all LCM 22w2's are plagued with the 'white screen of death' and eventual power shutoff, including garbage characters and faulty menu, video output, etc. Here's how I fixed it.
The Westinghouse LCM 22w2 has bad capacitors on the yellow power supplyboard. This is a common problem plaguing motherboards and LCDflatpanels that use capacitors from Taiwan. If you know how to solder,or know somebody that can, it's actually a pretty easy fix. Take outthe yellow circuit board on the inside, write down the specificationsfor each of the capacitors (the cylindrical things) go to theelectronics supply store and get the replacement capacitors. You can goover the voltage specification (not under), but keep the capacitancevalue matching. Replace one at a time. Go to www.badcaps.net foradvice, tutorials and training on doing this. *You really shouldreplace all the capacitors*, but the very large one next to the powerplug I did leave on the board because I couldn't find a match. To mydelight, the white screen of death went away and it was working as new!
I saved a ton of money fixing this, it's definitely worth learning how to solder to do this.
http://www.ctcco.com for professional hosting solutions
Jan 07, 2009 | Westinghouse LCM-22w2 Television
Screen goes white
I fixed it! It's the power supply board.
The Westinghouse LCM 22w2 has bad capacitors on the yellow power supply board. This is a common problem plaguing motherboards and LCD flatpanels that use capacitors from Taiwan. If you know how to solder, or know somebody that can, it's actually a pretty easy fix. Take out the yellow circuit board on the inside, write down the specifications for each of the capacitors (the cylindrical things) go to the electronics supply store and get the replacement capacitors. You can go over the voltage specification (not under), but keep the capacitance value matching. Replace one at a time. Go to www.badcaps.net for advice, tutorials and training on doing this. *You really should replace all the capacitors*, but the very large one next to the power plug I did leave on the board because I couldn't find a match. To my delight, the white screen of death went away and it was working as new!
Dec 24, 2008 | Westinghouse LCM-22w2 Television
No image on my Westinghouse LCM-22w2 monitor
Your problem isn't precisely the same one I had, but I have the feeling you're not saying that this was a problem that gradually got worse over time and now it won't power up.
Nov 13, 2008 | Westinghouse LCM-22w2 Television
Monitor shuts off for a few seconds when i play games or watch videos.
I fixed it! It's the power supply board. The bad news is you need to solder.
Dec 16, 2007 | Westinghouse LCM-22w2 Television
Black screen
The Westinghouse LCM 22w2 has bad capacitors on the yellow power supply board. This is a common problem plaguing motherboards and LCD flatpanels that use capacitors from Taiwan. If you know how to solder, or know somebody that can, it's actually a pretty easy fix. Take out the yellow circuit board on the inside, write down the specifications for each of the capacitors (the cylindrical things) go to the electronics supply store and get the replacement capacitors. You can go over the voltage specification (not under), but keep the capacitance value matching. Replace one at a time. Go to www.badcaps.net for advice, tutorials and training on doing this. *You really should replace all the capacitors*, but the very large one next to the power plug I did leave on the board because I couldn't find a match. To my delight, the problem went away and it was working as new!
Aug 19, 2007 | Westinghouse LCM-22w2 Television
Westinghouse 22" Widescreen LCD Flat Panel Monitor Logo
1,528 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Alun Cox
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
