Question about JVC RX-778V
How to hook up a surround sound system
I have a jvc rx-778v audio/video receiver which i am hooking up to a jvc xv-501 dvd player ow do i do it?
terribleteac
SOURCE: No Prologic Surround Sound
im thinking the reciever is set to get its audio from somehwere other than the dvd, sounds like you did most of the troubleshooting but do you get audio out of the reciever if its just playing the radio or something other than a dvd?
Posted on Feb 13, 2008
  • 151 Answers
SOURCE: PS3 with this receiver.
I dont know your reciver but if it has a hdmi input plug ps3 into it and set audio on ps3 to pcm,this will give you digital surround eg multichannel,if not you must use a optical cable from ps3 to reciver and set ps3 audio to digital.
hope this helps.
CABLE GUY.
Posted on Jun 30, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: lines in pic.
make sure your audio cables are going from the audio OUT of the dvd player and VCR to the audio IN of the receiver
Posted on Aug 14, 2008
SOURCE: Audio but no video from Sony Blu-Ray w/ HDMI hookup to RX-V663
Okay...my first contribution to any forum but I have the same problem (Yamaha RX-V663 and Samsung Blu Ray) and found the solution. The problem is you probably have your HDMI cables from your DVD player and reciever connected to a DVI input on your TV. The DVI may have problems communicating--not HDCP compliant. My system was working great then I hit a button on my remote...just playing around. I think it was the pure audio and I turned off the receiver. After that, the audio worked but there was no video. After many frustrating hours, the fix was to unplug the HDMI and DVI cable then turn the power off, cycle the power again, and plug the HDMI and DVI cables back in (the DVI was the last cable plugged in, not sure if that matters). By unplugging everthing you've reset the communication between the HDMI components and the DVI TV.
See page 18 of the yamaha owners manual, second to last note on bottom right of the page. It says there may be a problem...
I also noticed that the yamaha reciever was sending 1080p (my older tv is 1080I) and that is why the video wouldn't display on the TV. You can see this in the video signal info screen, unfortunately there is no setting to switch it back, just recycle the cables and power and it should reset.
Uncredibly frustrating but I got my picture back!
Jason
Posted on Jan 10, 2009
  • 3 Answers
SOURCE: DTS Master HD audio problem
Hey! Make shure your amp and blu-ray player output and input signals are set to "bitsteam" and you are useing HDMI and optical connections. I hooked up my Onkyo tx sr 506 integrated amp to a Samsung BD 1400 player and everthing worked perfectly right out of the box. Perhaps your amp can"t decode DTS HD Master or your blue ray doesn't support it although i think a firmware upgrade may accomplish this. Put on The Chronicles of Narnia Prince Caspian which will DEFAULT to DTS HD MASTER 7.1 and see if it works. It's an excellent source to test your system. Picture and audio recieved 5 stars from Home Theatre magaziene and like i said, either your amp, or player doesn't support it or your interconnects are keeping it from coming thru. HDMI and OPTICAL connects and check your set up for "bitstream" Remember what Todd Rundgren allways said,"Everything will work if you just let it!"
Posted on Jul 26, 2009
HOOKED ALL MY SPEAKERS UP BUT SUB AND CANT GET ANY SOUND FROM FM OR TV THAT I HAVE HOOKED UP AM I MISSING SOMETHING ALSO THERE IS A LIGHT THAT SAYS SOUND MUTE BY FM
From the remote control ONLY:
Press MUTING to mute the sound through all
speakers and headphones connected.
"MUTING" appears on the display and the
volume turns off (the volume level indicator goes
off).
To restore the sound, press MUTING again so that "OFF" appears
on the display.
• Turning MASTER VOLUME on the front panel or pressing
VOLUME +/- on the remote control also restores the sound.
Dec 22, 2010 | JVC RX-778V
Subwoofer not working.... JVC surround sound system 778V Subwoofer Part Number SP-PW37-SUB I hear a hum coming from unit so there's power going to it. I hear weak bass thumps with volume turned all the way...
A connectivity check could provide the solution, notice any wrong wire connections on device or any other devices requiring interconnection. The woofer would perform properly when the connections that provide current for woofing are approapiate
important notes
1. Trace the connection from Recorder or sound output to the woofer device
2. The wiring connections should be sound and video ouput into sound and video output into woofer.
3. The connections if any problems would be located at the stereo recorder or device producing the spund and video. Check the connections of wires on the recorder device ensuring rewiriing
4. finally, adjust the equalisers if any the buttoms could have been disbled by master switch hindering full blaster boost sound.
Dec 05, 2010 | JVC RX-778V
No sound
Check the settings on the receiver. You may need to switch the dvd from analog to digital or hdmi.
Jan 04, 2009 | Yamaha RX-V563 Receiver
Manual
hooked up ps3 to amp works great! trying to hook up 2nd blueray player, with 2nd fiber chord. i have it pluged in to dvd port on amp , can"t get no sound ! wat to do ?
Nov 04, 2008 | JVC RX-1028V Receiver
Lines in pic.
Jul 27, 2008 | JVC RX-5020VBK Receiver
Hooking it up
To get the dvd working hook up to amp with a optical or coax lead to your amp digital in,set out put on dvd to give 5.1 sound,next put a phono cable from cable box to tv input on amp or sat input,now put phono cables from tv audio out to tv or other free input on amp.Set sound to prologic2 and you should have surround sound for all.
hope this helps.
CABLE GUY.
Jun 05, 2008 | JVC RX-6030V Receiver
Sub
Most amplified sub woofers need to be grounded to the output source.If you plug the sub woofer in to the receiver you would use a ground wire from the receiver to the sub woofer there should be a ground terminal on the sub woofer and receiver.
Feb 17, 2008 | JVC RX-778V
Nov 19, 2007 | JVC RX-778V
JVC RX-778V Logo
382 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
