Question about Compaq Presario uWave2 K7 Socket 462 Motherboard (232148002)
Why wont my front usb ports work
I decently aquired a new hard drive case and everything works except the front usb ports, what do u think is wrong?
    President:
  • 1,073 Answers
My guess is that the cable from the front usb isent connected properly since everything els working from the front
Posted on Dec 07, 2008
How to remove front panel to repair the front usb ports on an Acer Aspire E380 -?
The front USB connectors are usually either molded into the front case or held in via a clip or screws. Unfortunately, when they go out due to the tab within the USB port breaking, they are not easily replaced as each manufacturer creates their own proprietary connector...not the USB part but the hardware to hold the USB in place. So you will find the hardest part of this project finding the right connector or "jerry-rigging" the new one to fit.
Another alternative is to remove everything from the old case...the mainboard, all the drives and whatever else can be moved, and put it into a new case. If your current power supply is good and of a standard size, etc...you can get a used case for around $10.00 and put all the other things from the old one in it. Fortunately, this series of Acer seems to be pretty much generic so everything should fit....just make sure the "new" case has good front USB ports.
Jul 12, 2014 | Acer Aspire E380 ASE380-UD500A PC Desktop
Whenever i insert my external hard drive to the USB port of my desktop, the desktop flashes a message saying USB not recognize. And the hard drive does not work. i do not know to make it work..
The most common cause of this in my experience is not enough amperage available at the USB port. If you're using a front/top case port, try switching to one of the ones at the back of the case that is connected directly to the motherboard. If that doesn't work, you can use an externally powered USB hub, which usually solves the problem as long as the hub has a 2A or better power supply.
Hope this helps.
Sep 25, 2011 | Transcend StoreJet 320 GB USB 20 Hard...
USB wont work
You arent doing anything wrong, might be the drive is faulty since no light comes. Get it replaced. :)
Jun 18, 2010 | Dane-Elec DaneElec 4GB USB Drive Copper...
Xp computer wont recognise new 250gb elements ext hard drive
use it on a differnet usb port
these portable hard drives have some issues with 1.1 usb ports
Jul 12, 2009 | Computers & Internet
My two front usb ports cant read usb hard drives
Some external USB drives require external power sources. Typically this is done either with an external power supply that connects to the drive or a second USB cable that connects to the drive and a second usb port on the pc. I have even seen one drive that comes with a Y cable. one end goes to the drive and the 2 usb plugs go to the pc.
Dec 12, 2008 | Linksys Wireless-G WRT54G Router
I reciently aquired a new case for my hard drive and stuff. Everything works correctly except the front usb ports. What do u think is wrong?
THERE PROBABLY JUST NOT CONNECTED, LOOK AT YOUR MOTHERBOARD MANUAL AND SEE WHERE THE USB-PINS ARE ON YOUR MOTHERBOARD FOR THE FRONT OUTPUTS...
Dec 07, 2008 | Compaq Presario uWave2 K7 Socket 462...
GETTING INFO FROM OLD HARD DRIVR TO NE LAPTOP.
Hard Drive requires lots of power to load. If you have purchased only the IDE cable to connect it to USB port, USB port will be unable to initialize the Hard Drive.
To make it work,you require an external casing for IDE Hard Drives with external power support. Like this one --
http://shopping.rediff.com/shop/productdisplay.jsp?3.5Inch-USB-2.0-EXTERNAL-Casing-For-SATA-/-IDE-Hard-Drives&prrfnbr=10209520&source=browse&frompg=Hard%20Disk%20Drives
If you already have this casing with external power support, please let me know.
Nov 15, 2008 | Computers & Internet
Won't recognize my USB
i have a feeling its not the hard drive thats bad i think it sounds like the case .
you can try buying another case and transfering the hard drive to it the case is around $20.00
Nov 30, 2007 | SimpleTech 250GB USB2.0 7200 RPM External...
Flashing led light on my hard drive
well the best thing i figured out to do was to purchase a new case. i think the case burned up. i pulled the hard drive out and hooked it up to another drive so to see if it would work. the drive works just fine in the other device, so i ordered another case.
Nov 06, 2007 | LaCie 301103U 500 GB USB 2.0 Hard Drive
Compaq Presario uWave2 K7 Socket 462 Motherboard (232148002) Logo
552 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
