I hava a Ariston washing machine it does not spin it isn warranty but if it has a foreign object it will not be under warranty I have tried what they said going to the outlet but nothing there also how do you get the clothes out that have not spun before I call the repairer they will get ruined pleade help
  • Washing Mach... Master
  • 3,463 Answers
Lay the drain hose down into a bucket or something similar, and let the water run out.
This will then enable you to open the door and remove your washing.
Once the water has gone you should find it will spin
Posted on Dec 07, 2008
Kenmore Model 110.2234 top loading wash machine About a year old It is so loud on spin cycle we cant hear each other talk in the other room with laundry door shut What is the problem?
Possible bearing failure but if only a year old, it should be under warranty. Check around the spin bowl for any foreign objects sticking through the tub. Perhaps a bra wire or nail , screw etc or something has come out and stuck in the tub.
Nov 20, 2016 | Kenmore Washing Machines
Why does agitator make a kinda grinding noise and machine will not spin?
some foreign object jammed under the agitator ???
unplug machine and use coat hanger to fish it out from underneath
Jan 19, 2016 | Washing Machines
Working but not drain
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Feb 06, 2011 | Washing Machines
Will not drain the water and spin
this unit will not spin until the water is drained. your pump is jammed or faulty.if u r confident, remove and clean pump.please turn off power b4 u work on it do want any accidents . please reply if u need more help
Apr 08, 2010 | LG Washing Machines
Machine won't spin
If water remains in the drum the unit will not go into the final spin. There may be a couple of reasons which I have experienced resulting in your problem. If water remains in the tub the unit will not go into the high speed spin.
1.) A coin or other foreign object is blocking the drain hose. Check the drain hose for foreign objects impeding the exit of the water. Shake the hose and listen for coins or a small object this unit will pass items through the pump into the hose causing blockage.
2.) The Drain hose is not raised above the machine outlet to create a siphon effect. See your manual for proper hose positioning. The hose needs to have a loop in it to work correctly.
3.) The pump is a third possibility which you should hear the impeller spinning during the drain cycle. There is a coin catch after the diaphragm of the pump that looks like a rubber boot that should be inspected for objects if you remove the pump. The pump is about $60.00 and is accessible after removing the front panel under the door. It is easy access from the front and the hose clamps will be the most difficult problem. I have a ratcheting hose clamp tool designed for this type of clamp but channel lock pliers will work.
Jan 18, 2010 | Frigidaire GLTF2940ES Front Load Washer
We have an Ariston A1636S Washing Machine. When
COULD BE SOMETHING IN THE DRUM UNDER THE CROME PIECE THAT THE CLOTHES GO ONE
Dec 30, 2009 | Ariston Technologies Washing Machines
Frigidaire GLTF2940FS...does not do a final spin/clothes wet
If water remains in the drum the unit will not go into the final spin.There may be a couple of reasons for your problem.
3.) The pump is a third possibility which you should hear the impeller spinning during the drain cycle. There is a coin catch after the diaphragm of the pump that looks like a rubber boot that should be inspected for objects if you remove the pump. I believe the pump is about $60.00 and is accessible after removing the front panel under the door.
Sep 10, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washing machine doesn't spin
if machine doesn't drain, then it won't spin!
check the filter and check no foreign object stuck in pump impellor
Jul 09, 2008 | Washing Machines
Ariston Washer Dryer AML 105
i know it sounds simple but have you checked the filter and also check for foreign objects in the pump impellor
Jun 26, 2008 | Washing Machines
Fills washes rinses but wont spin properly or empty out washer, ends cycle half done, wont pump water out or spin out. i can hear the machine hum while trying to do so. Please any ideas. THanks
its likely the pump is blocked (hence the humming) with a coin or some foreign object. To check, lower the outlet hose to ground level to allow the water to empty. Tip machine back & lean against a wall, remove the pump & remove object if there is one! Reassemble & try machine again
Oct 19, 2007 | Hotpoint Aquarius WF215 Front Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
Richard Roth
Richard Roth
