Seth Thomas Thomas & Friends Percy Train Toy Logo
Posted on Dec 07, 2008
Blinking light on thomas the train
There is a red blinking light on the battery operated train. There are brand new batteries in it. What is the problem?
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Dec 09, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
0
Helped
1964
Points
10
Its defective there was a recall 4 days ago
I bought a used battery operated Thomas. Uses 4 AA batteries, has on/off switch on base and has four coloured buttons on the top,of the cabin. What are the buttons supposed to do?
if i remember right 1 makes a train whislte sound, 1 makes a sound of a train, and the other 2 had phrases spoken by thomas. my daughter had one a few years back
Blinking green light
Check to make certain that the batteries in the remote are good. Make sure that when using the remote, you orient the antenna in an upright position and are within 6 to 8 feet of the locomotive.
If the train has been running successfully and the problem has only just started, clean your wheels and the pick up roller on the locomotive removing any fluff etc. then clean the track. If the loco is still not working contact the Lionel Service Department on
586 949 4100 or use their website contact service. Contact Lionel Trains
Hi. Need to purchase a battery for train. What retailers carry the battery and what is the cost? Thanks.
41kwnm4q8pl._sl75_.jpg National Products 6V Battery Operated Talking Train with Track
Buy new: $129.99 $129.00
6 Used & new from $127.78
4.3 out of 5 stars
$129.00 & this item ships for FREE with Super Saver Shipping. Details You Save: $0.99 (1%)
In stock but may require an extra 1-2 days to process.
Ships from and sold by Amazon.com.
its better to buy from a recommended marketer, with guarantee
2helpful
How do I change the battery in a motorized wooden railway engin for thomas the train
2 options.
1.if its the kind that fits on the wooden track look for a screw (philips/star screwdriver) on the underside of Thomas near his face. The body shell should lift off.you will then see the battery.
2 If it's the plastic blue track you have to squeeze the right center wheel and left center wheel. Thomas has 6 wheels so the 2 center/middle wheels, after squeezing this will then make the top portion pop off.
How do you replace the batteries in James the train?
James the train has a tender attached to him. On top of the tender there is a black plastic piece that looks like coal. Slide the black plastic piece towards you and you will see the battery underneath it.
Toy can't work after changing battery
Make sure that ALL the batteries are good, right size and voltage and are the right way around in the battery compartment.
1helpful
Thomas train charge battery has music and sound effects, but does not move?Does it need a new motor
It might need a new wire connection to the motor.
I would contact
http://www.shopjandl.com/
They help me with my ride on toys.
hope this helps
9helpful
9answers
Peg Perego Thomas Train Track Rider
I cannot promise that this is the problem, but this is where mine was broken, and you may be able to fix yours this way.
I was able to remove the plastic around the tender and access the motor. Using alligator clips, I was able to connect the battery directly to the motor, bypassing the circuit board. The motor functioned, therefore the only component that seemed to be defective was the circuit board, located behind the speaker in the engine unit.
As far as I know, the only place to buy a replacement circuit board is from www.tigerimports.com. Search for part number MEVA0024. Cost is around $15 + shipping (around $6 or so).
I should be receiving this part by the end of the week and will report if it fixed the problem.
Thanks for using Fixya. If I didn't help your situation, please DO NOT label this advise as "inappropriate".
Mar 12, 2009 • Toys
2helpful
The red button on the right must be held down for anything to move. It turns the lights on, makes some train noises, then moves forward. If you don't hold the button down, nothing will happen. Note that when the train is underway, the left red button becomes a train whistle. Otherwise, when the train is not running, that left button produces music. Hope this helps.
Top Seth Thomas Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Seth Thomas Toy Expert? Answer questions, earn points and help others
