Replaced bulb on akia 46" fan comes on mow but no light do i need to reset a timer on bulb and how and where or what
  • 4 more comments
  • tj6866 Dec 07, 2008
    model # pt46dl10
    model pt46dl10 akia tv, i have replaced bulb, picture still dark
    the green light that says power is flashing but there is sound
    i assumed the bulb was blown
    46" akia tv green light flashing, good sound, black screen i eplaced the bulb, still balack screen
    wow and how do i find all of that technical gobble
    Genius:
  • 1,142 Answers
Check the bulb first if its been seated properly.
Posted on Dec 07, 2008
    Genius:
  • 1,239 Answers
Hi
here the steps
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected
2 - 1 = X-ray protect (high voltage or beam current)
2 - 2 = Short protect (short protect monitors low voltage supplies)
2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection)
2 - 4 = Vertical protect (usually loss of vertical from the source)
1. Shutdown at power with self diagnosis error
2-2. Check for open fuses F9A04 and F9A05 part # 283P144080 on the +24 and -24 volt lines. If the fuses are open the convergence output circuit would be suspect.
2. Shutdown at power with self diagnosis error
2-1. At power on check for 12-volts DC at connector KH pin 8, if missing check IC9C51 part # 270P990010 and L9C52 part # 441D009020 on the Signal PCB.
  • 1 more comment
  • ABHISHEK.C
    ABHISHEK.C Dec 07, 2008
    HI AGAIN YOU TOLD GREEN LIGHT FLASHING BLACK SCREEN
    12 No error detected
    22 Recovery from momentary Reset
    32 Lamp Cover open
    33 Air Filter Cover open
    34 Lamp abnormality
    35 Chassis Fan failure
    36 Exhaust (Back Cover) or Lamp Ballast Fan failure
    37 Engine (DMD or Lamp) Fan failure
    38 Excess Lamp Temperature
    39 Excess DMD Temperature
    41 Short Detected
    44 DVI Cable (between Chassis and Engine) disconnected
    YOURS IS ERROR 12 SO IT IS EXACTLY POWER PROBLEM...IT IS CONFORM
  • ABHISHEK.C
    ABHISHEK.C Dec 08, 2008
    Could be a few things. Bad bulb? Just like anything, some are just not made correctly. Could be the ballast that powers the light, or you may have a component on any board that is failing causing it to go into a protection mode.
  • ABHISHEK.C
    You have to have a Panasonic remote (one that came with the tv, or a similar model), and if it doesn't have the PIP button (or Split-Screen button), then you will have to use the '0' (zero) button.
    Power on the tv, (and wait for the lamp replacement text, and press ok or enter or whatever it tells you to make that go away.) then press and hold the zero button on the REMOTE, and AT THE SAME TIME, press and hold the 'vol -' (volume down) button on the TV.
    Zero button on remote AND
    Volume button on TV AT THE SAME TIME.
    This worked for my PT52LCX16 ( PT-52LCX16 ) which came with a remote without the PIP button.
  • 106 Answers
Was the lamp blown before it was replaced? Is this model 46DL10. Are any lights flashing on the front of the set?
  • tvguy171
    tvguy171 Dec 07, 2008
    Is the lamp door cover back in place after lamp replacement? Was the set working before you replaced the lamp?
  • 19,396 Answers
You need to give us the exact model to find the counter reset.
  • Ginko
    Ginko Dec 08, 2008
    I did not find any counter reset procedure or free service manual for this model. Here you can get the service manual, I do not know if registration is free. There you should find counter reset procedure, if there is any.
    In any case, ensure that the lamp is placed correctly and that the door is closed properly.
Timer display says "Lo Battery". I put two new
Intermatic timers might require reset-and-reprogram after battery replacement.
To reset, hold down on-off button and push reset button once.
Keep holding on-off button until display changes.
Release on-off button, and display should blink 12:00
Try cleaning battery carriage contacts with alcohol and make sure battery polarity is correct.
If functionality is not restored, then replace timer.
Intermatic EJ500 comes with 1 year limited warranty and is rated for incandescent light bulbs only.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
Aug 08, 2011 | Intermatic Inc. EJ500C Digital Wall Switch...
Timer has worked in the past as programed. However, upon resetting timer to correct time of day then setting "ON" & "OFF" porch light seems to come "ON" two hours...
I test timers.
Timers go bad.
EJ351 has 1 year limited warranty.
Wiring is correct or timer would not operate.
Bulb is good.
I would reset timer again and re-program.
If timer still will not function, then timer has gone bad.
Following page has manual:
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/in-wall%20timers/ej351c.aspx
Reset instructions: Move the control lever to the OFF-CLEAR position for about
20 seconds. The red indicator light will go off and any previous
time settings will be cleared from memory.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 23, 2011 | Intermatic Programmable 24 Wall Switch...
My Samsung HLP4663W 46 in was making a buzzing noise for several months. I know it could have been either the fan(s) or the color wheel, but I never opened it up to determine which it was. Now the TV quit...
Great reasoning work! In fact, the lamp will not light if the color wheel does not spin-up. Fans will not stop the process of lamp ignition. Instead, a fan will be detected and a message will appear on the screen telling which fan has stopped. You need to have the color wheel replaced.
Mar 15, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Optoma hd65 projector new bulb wont turn on...cant reset timer!
I think it's a lamp driver issue from what I've seen others have gone through. I also read that if you go through the sequence of unplugging, plug back in, wait 20 seconds and try to turn on, multiple times, it will finally kick on and work. I just got mine to turn back on by doing this and waiting through the fan cycling without the light turning on. After the 4th sequence the light flickered. After the 7th sequence it finally turned on and is working. Now I can watch the Super Bowl and will look into replacing soon.
Jan 31, 2010 | Optoma HD65 DLP Projector
How do i reset the lamp light once i have changed the bulb. red light is still on.
Replace Lamp first it should reset itself,if not go to Lamp Timer in Menu and hit reset timer to lamp.
Oct 05, 2009 | Akai PT46DL10 46" HDTV-Ready Television
My 50 Viore dlp tv turns itself off after just a
HI, this may be a simple cooling issue. try inspecting the cooling fans that are located near the power sector. if these cooling devices are not operational, they will cause the power board to shut down periodically, due to heat build up.
If the fans are operational, this will confirm a weak and defective power power board.
Jul 20, 2009 | Televison & Video
XR-10x bulb timer has timed out. How do I reset the projector?
you need to reset the lamp timer see http://www.ercservice.com/PDF/Lamp-Sharp-XR10-XR20.pdf
Apr 07, 2009 | Sharp XR-10X Multimedia Projector
How to reset lamp timer
Go to the menu and you'll find lamp timer section.
Aug 27, 2008 | Vivitek V37835 46 in. LCD Television
Sanyo XU50 not coming on after lamp replacement
Hi oatesy13
You will have to reset the lamp timer to resolve the problem.
Consult ypour user's manual on how to do this.
Should do the trick , If you do however need any further assistance , please send me a request and I'll respond to it.
May 13, 2008 | Sanyo PLC XU50 Multimedia Projector
Televison & Video Logo
Top Televison & Video Experts
