Question about HP PSC 2210 All-In-One InkJet Printer
Paper Jam There is a small piece of paper jammed in the back of the printer (hp2210) that I can not reach. Are there any elements in the back of the printer that I can remove in order to get to the paper. Thank You Jack Rubin
  • HP Master
  • 13,433 Answers
Cannot get printer to work keeps saying paper jam but I cleaned it out don't see any jam will not print? i inplugged it also still does not work ?
This happens if the jammed paper tears during removal and a small piece is stuck in the jam sensor or the jam bent or broke the jam sensor. Can you remove the paper tray or open any doors on the back to see any pieces left behind? A visual inspection perhaps with a flashlight may show something in there. The paper path is very short so you should be able to see something. If you can't reach it, you can try inserting a few sheets of paper or something thin and flexible to push it out.
Feb 03, 2011 | Brother MFC 240C All-In-One InkJet Printer
It always says paper jam and it has no paper jam
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
if the problem remains, some of the sensor / switches might have become stuck or are out of place, or there is still a small piece of paper or something else inside the machine and its coming up as a paper jam.
The machine would need to be taken apart and cleaned to solve the issue.
Nov 03, 2009 | Dell Photo 964 All-In-One InkJet Printer
Paper jam: cannot reach the paper, how do I get
This video was created for the C7280, but works the same for your printer.
Jun 10, 2009 | HP Photosmart C5180 All-In-One InkJet...
PAPER JAM
give this a shot
try this, its probably a small part of jammed paper or then theres a problem with the pickup, try cleaning it.
alternative :
Apr 14, 2009 | Canon imageCLASS® MF4150 All-In-One Laser...
CONTINUING PAPER JAM. I OPEN DOOR, CLEAR THE JAM, AND PAPER STARTS TO FEED, THEN AGAIN ANOTHER PAPER JAM, AM I USING WRONG PAPER?
I know the problem, Its the Exit paper sensor! if u make a short circuit on the pin 2 and 3 of the CN2 when the paper reaches the sensor it wont jam. Chainging the sensor resolves the continous paper jam or try to clean it!
Apr 08, 2009 | Samsung CLP 315 Laser Printer
Paper jam up in top of printer Tray one wadded badly -
Try using the cardboard backing of a large writing tablet by sticking it down into the tray where the paper goes. If there is a small piece of paper there, it will be pushed out.
Marie
Jan 26, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Paper jam
try this....
alternative :
Jan 19, 2009 | HP LaserJet 2820 Printer
Paper jam.
try this, its probably a small part of jammed paper inside or then theres a problem with the paper pickup, try cleaning it.
alternative :
Oct 26, 2008 | Lexmark X83 All-In-One InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
14 people viewed this question
Ben Johnson
