Question about Toshiba TDP P4 Multimedia Projector
Black bar on bottom of image when i turn on projector
Heay guys just got this projector form someone who told me that the main pwb board is broken, as a result i am getting a black bar under the screen of the projector, anyone knows where i can get this repaired? i got it free so dont mind spending some money to get this fixed :)
    Problem Solver:
  • 9 Answers
Projector Doctor in San Diego can do PS and board level repairs on this projector.
Posted on Jan 22, 2008
F9-88 code on arm317
F9-88 = Print PCB to Main MFP Board Comm Timeout
You can clear this by turning your copier off and then on. Try turning it back on with the network cable unplugged, run your machine, then plug the network cable back in. If the error code comes back, its: 1) bad network cable 2) ungrounded electrical plug for copier or router 3) noise on network line 4) copier needs firmware update 5) replace the print board
Apr 02, 2014 | Sharp AR-M317 Black and White Copier
Optical engine replacement for Epson 6500 projector
USD500
We supply original projector parts: lamp, bulb, Lcd
panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and
competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Feb 10, 2014 | Epson PowerLite HC 6500UB OEM Projector...
Optoma PCB MAINBOARD MODULE FOR 8EG
My HD20 also broke after about 1000 hours. Their estimate is $703.00 to replace main board and lamp module. Image shuts off automatically after 3 mins of starting. Lamp fail led goes solid red.
Nov 10, 2011 | Optoma HD20 DLP Projector
Projector will display image, but it has vertical lines running through the image. If a heavy object is placed on top of the projector, the lines disappear and will not come back.
This likely a conncetion problem between the main board and the light engine. The added weight could be making the connection complete. You could open the projector and remove the ballast, power input board, and shield to remove the main board and clean the part that connects it to the bottom of the rear of the engine and then reseat the connection, BUT, this is a major task if you don't know what you are doing and is best left to a tech or living with the weight being on the unit.
Oct 28, 2010 | InFocus ScreenPlay 4805 Multimedia...
Model SF2530 photocopy Erroe F1 how to reset
F1 00 Content Sorter communication trouble Detail Communication line test error occurs when power is turned on or after the exit of a simulation mode. Improper communication with sorter Cause Improper connection or broken wire of connector or harness between copier and sorter Sorter control PWB defective Control PWB (PCU) defective Malfunction due to noise Check and remedy Clear by turning the power supply OFF/ON. Check communication line connector and harness. Replace sorter control PWB or PCU PWB. F1 02 Content Sorter transport motor error Detail Transport motor drive trouble Cause Motor lock Check and remedy Check transport motor operation with SIM3-3. F1 03 Content Sorter guide bar rocking motor trouble Detail Sorter guide bar rocking motor drive error Cause Motor lock Motor speed error Overcurrent to motor Sorter control PWB defective Check and remedy Check guide bar motor operation with SIM3-10. F1 04 Content Sorter indexer lower limit detected Detail Indexer has exceeded lower limit. Cause Sensor defective Sorter control PWB defective Check and remedy Check sensor with SIM3-2. F1 05 Content Sorter indexer upper limit detected Detail Indexer has exceeded upper limit Cause Sensor defective Sorter control PWB defective Check and remedy Check sensor with SIM3-2. F1 06 Content Sorter bin shift motor error Detail 1) Bin shift is not completed within 2.5 seconds after bin shift request Cause Motor lock Improper motor speed Overcurrent to motor Sorter control PWB defective Check and remedy Check bin shift motor operation with SIM3-4.
Jan 11, 2010 | Sharp AR-5316 Advanced Digital Imager...
Parts
Which board are you refering to as the main circuit board? The power supply PWB ? The Deflection / Convergence PWB ? or the Signal PWB ? respond to this same post and I can help you out, but there isnt a PWB called " main" In that chassis hitachi.
Jul 31, 2008 | Hitachi 46F500 46" Rear Projection...
Black pop-up screen when pressing any menu features on remote
check for closed captioning. make sure it's set to off.
C-Dog
Feb 03, 2008 | JVC AV-48WP30 48" Rear Projection...
White vertical lines in image w/ 2 inch black bar horizontal.
the black bar is from the light tunnel collapsing. the white lines are from the colorwheel or the main board has a cold solder joint. replace the tunnel and colorwheel and have the main board looked at.
Nov 12, 2007 | InFocus ScreenPlay 7205 Multimedia...
Toshiba TDP P4 Multimedia Projector Logo
137 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Timothy Van Der...
Adorjani Laszlo
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
