Question about Compaq Presario uWave2 K7 Socket 462 Motherboard (232148002)
I reciently aquired a new case for my hard drive and stuff. Everything works correctly except the front usb ports. What do u think is wrong?
  • 20 Answers
THERE PROBABLY JUST NOT CONNECTED, LOOK AT YOUR MOTHERBOARD MANUAL AND SEE WHERE THE USB-PINS ARE ON YOUR MOTHERBOARD FOR THE FRONT OUTPUTS...
Posted on Dec 07, 2008
How to remove front panel to repair the front usb ports on an Acer Aspire E380 -?
The front USB connectors are usually either molded into the front case or held in via a clip or screws. Unfortunately, when they go out due to the tab within the USB port breaking, they are not easily replaced as each manufacturer creates their own proprietary connector...not the USB part but the hardware to hold the USB in place. So you will find the hardest part of this project finding the right connector or "jerry-rigging" the new one to fit.
Another alternative is to remove everything from the old case...the mainboard, all the drives and whatever else can be moved, and put it into a new case. If your current power supply is good and of a standard size, etc...you can get a used case for around $10.00 and put all the other things from the old one in it. Fortunately, this series of Acer seems to be pretty much generic so everything should fit....just make sure the "new" case has good front USB ports.
Jul 12, 2014 | Acer Aspire E380 ASE380-UD500A PC Desktop
My Free Agent Go shows up with a yellow exclamation point in "other devices" in device manager. It's not recognized anywhere else. I also notice that my computer says I have another hard drive...
> Seagate ST3200826AS
This is a Seagate 200GB SATA-interface disk-drive.
Open "My Computer", and point at the icon for 'C:' drive -- is it a 200GB disk-drive?
Double-click that "yellow exclamation" item. Click "install new driver" or "update driver".
If Windows asks permission to access the Internet to search for a new driver, allow it.
Note that the USB ports on some laptops are "weaker" (same voltage but lesser amperage) than USB ports on some desktops. So, your FreeAgent might not be getting enough power to function correctly. There exist 'Y' USB cables -- connect the 'Y' to 2 USB ports on your computer, to draw twice as much power.
Oct 31, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
My two front usb ports cant read usb hard drives
Some external USB drives require external power sources. Typically this is done either with an external power supply that connects to the drive or a second USB cable that connects to the drive and a second usb port on the pc. I have even seen one drive that comes with a Y cable. one end goes to the drive and the 2 usb plugs go to the pc.
Dec 12, 2008 | Linksys Wireless-G WRT54G Router
Why wont my front usb ports work
My guess is that the cable from the front usb isent connected properly since everything els working from the front
Dec 07, 2008 | Compaq Presario uWave2 K7 Socket 462...
GETTING INFO FROM OLD HARD DRIVR TO NE LAPTOP.
Hard Drive requires lots of power to load. If you have purchased only the IDE cable to connect it to USB port, USB port will be unable to initialize the Hard Drive.
To make it work,you require an external casing for IDE Hard Drives with external power support. Like this one --
http://shopping.rediff.com/shop/productdisplay.jsp?3.5Inch-USB-2.0-EXTERNAL-Casing-For-SATA-/-IDE-Hard-Drives&prrfnbr=10209520&source=browse&frompg=Hard%20Disk%20Drives
If you already have this casing with external power support, please let me know.
Nov 15, 2008 | Computers & Internet
Won't recognize my USB
i have a feeling its not the hard drive thats bad i think it sounds like the case .
you can try buying another case and transfering the hard drive to it the case is around $20.00
Nov 30, 2007 | SimpleTech 250GB USB2.0 7200 RPM External...
Flashing led light on my hard drive
well the best thing i figured out to do was to purchase a new case. i think the case burned up. i pulled the hard drive out and hooked it up to another drive so to see if it would work. the drive works just fine in the other device, so i ordered another case.
Nov 06, 2007 | LaCie 301103U 500 GB USB 2.0 Hard Drive
PC won't recognize external usb HDD
You may not have installed the HDD correctly in the case... I had the same problem with my Thecus N1050 enclosure, the green power light on the enclosure would come on and the drive would spin up but my PC would not see the HDD!!??... I thought, becuase i could hear the drive spinning that i had it installed correctly but this wasn't the case, when i removed the enclosure again and FIRMLY pushed the HDD into the connector (all the way in) and connected it back up to my PC, it recognised it instantly. Hope this helps!
Jul 25, 2007 | Seagate USB 2.0 External Enclosure + 400GB...
Compaq Presario uWave2 K7 Socket 462 Motherboard (232148002) Logo
112 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
