Error 5020 scanner lock switch will not turn off.I am using printer pixma mp810
  • mikemisery Jan 27, 2009
    where is the scanner lock swith?
  • WalterinOz Feb 20, 2009
    Cartridge tanks are locked in starting positiuon. Error is 5020
    Can't get out of it. Anyone any advise?
Does anyone know how to fix error 5020 release the scanner lock switch and turn the power off & on.The Cannon MP810 Printer. Please Help!Thanks
Posted on Jun 10, 2009
Where is the "scanner lock switch" located on a Canon Pixma MP980 printer? I cannot seem to locate the switch "under the hood" so I need assistance.
The scanner lock on the MP980 is on left hand side of the scanner unit. It's closer to the hinge of the document cover and almost centered between the scanner glass and the edge of the printer. If you lifted the entire scanner unit, you won't see the switch. You should be able to push the switch towards the open lock symbol with your finger or thumb. The Getting Started guide has a pretty good picture of where the switch is in Step One. The guide is available on the product page, http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp980#BrochuresAndManuals , in the Brochures & Manuals section. The current link to the Getting Started Guide is http://gdlp01.c-wss.com/gds/2/0300001552/01/MP980_GS_EN-US_V3.pdf . After moving the switch, turn off the all-in-one. Then unplug the power cord to clear the error message from the printer's memory. After a few minutes, plug the power cord back in and turn on the printer.
If the error persists and the scanner is unlocked, the scanner mechanism may be damaged. If that's the case, your MP980 needs service. If the unit is under warranty, contact Canon. (If it isn't under warranty, you'll need to decide if the unit is worth the shipping and handling fees and the minimum $50 or so charge just to determine the problem at a service center. (That fee will be applied to the cost of fixing the printer, if you decide to have the technician continue to work on the unit.)
I hope this helps.
Sep 21, 2015 | Canon PIXMA MP980 All-In-One InkJet...
How do ] f[nd the scanner lock switch to unlock it
Do you mean the mechanical lock switch on the side of a scanner that stops the mechanism from moving while being transported?
Mar 02, 2015 | Canon PIXMA MP810 All-In-One InkJet...
How to remove cartridges when no power
The printer needs power to remove the cartridges. There is an assembly that moves and locks the cartridges and covers the ink nozzles to prevent the ink from drying out. Without power this assembly is locked in place and will not release.
Aug 21, 2012 | Canon PIXMA MP810 All-In-One InkJet...
Hello, I have a Canon MP810 printer and the screen shows there is an error with that number: 5020. It says that I have to unlock the locker of the scanner and then restart. I have done it many times...
I have just read it on the other forum..try this one
Error Code 5020:
Scanner lock switch locked. [5020] Release the scanner lock switch and turn the power
off and back on.
Turn the machine off, unlock the scanner lock
switch, then turn the machine on again.
Hope it helps.
Sep 09, 2011 | Canon PIXMA MP810 All-In-One InkJet...
Mon imprimente pixma mp810 donne un code erreur 5020 et demande de deverouiller le scaner
This correction is listed on the Canon website. Lock Switch Make sure to unlock the scanning unit before turning the machine on.
  1. Lift the document cover open.
  2. Slide the scanner lock switch to the release mark.
    Caution : Make sure to unlock the Scanning Unit (Printer Cover) before turning the machine on.Before transporting the machine, always lock the Scanning Unit (Printer Cover) by moving the Scanner Lock Switch towards the lock mark.
  3. Close the document cover.
  4. Press to turn off the machine.
  5. Wait approximately 5 seconds then press to power back on the printer.
Mar 27, 2011 | Canon PIXMA MP810 All-In-One InkJet...
How to trace and release scanner lock on Canon MP810 printer
There's a lock switch, left side near the scanning glass.
Lift the cover ( 1 ) and
switch the lock switch to the open padlock indicator ( 2 )
For online support on the MP810, look here:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp810
Jul 22, 2010 | Canon PIXMA MP810 All-In-One InkJet...
An error message 5020 appeared and the machine is not working, how to solve (to reset)?
error [5020] is not big problem. You just need to release the scaner lock switch and turn the power off and on back. Then you may enjoy to use your PIXMA MP810
May 29, 2010 | Canon PIXMA MP810 All-In-One InkJet...
Printer canon mp810 displaying 5020 error How do I fix it?
Hi
This maybe a small bit of paper in the rollers somewhere you need to find it or it is need of a good clean.
You can also try this.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 01, 2010 | Canon PIXMA MP810 All-In-One InkJet...
3,848 people viewed this question
jasbo
jasbo
