Question about JVC KT-SR2000 SIRIUS Radio Receiver with Car Kit
LCD screen back light doesn't work
I've had my JVC KT-SR2000 for a little over a year and the red backlight for the LCD screen just stopped illuminating. The LCD still works but you can't see it unless you are an inch away from the screen. I have both the car kit as well as the home dock so I really don't want to change units. Any help would be greatly appreciated
  • 5 more comments
  • Anonymous Dec 10, 2007
    jvc backlight doesn't work, afer 3years. why?
  • MrGreg Dec 12, 2007
    Yep heres another have the same issue. Have multiple car kits and a home kit. Works fine just cant see the display. Any one know where parts might be purchased? ive had it apart. the lcd wouldnt be too hard to replace. May try picking one up cheap on Ebay.
  • Anonymous Dec 17, 2007
    Me too! The manufacturer has absolutely no interest in helping either.
  • Anonymous Dec 28, 2007
    Mee too all of a sudden red diplay disapeared and to view anything you have to have the lite rite???? anyone come up with a fix for this.. JVC told me I would have to buy another one uurrggghhhhhhh
    mike from mass.
  • Windsearcher Mar 25, 2008
    backlight just died today. About 2 years old. Have 2 auto kits and a home kit with extra long cable.... really don't want to replace it. Any help??
  • Anonymous Apr 03, 2008
    Backlight went out. I purchased the unit from Best Buy. They no longer have the JVC. I tried to contact JVC, went through their phone menu and was finally told if it was under warranty, which it is not, to send it in amd they will look at it. I am using the radio without the light as best I can.
  • lswaters Oct 04, 2008
    I've bought the JVC KT-SR2000 about 3 years ago, and the backlight went out after about 3 months. It was replaced. The new unit lasted for about a year, then the light went out again. I've so far invested in the unit, the boombox, the car kit, and otherwise it works fine, and I don't want to go out and buy something new. So I guess I just have to live with it.
  • JVC Expert
  • 509 Answers
Sirius Radios got VERY HOT and it would destroy the LED lighting in the units. XM seemed to get it under control by using a 5volt or 6volt power supply, but the 12 volt Sirius radios were almost fire hazards to the point that I had to run a small computer fan on mine to keep the display working; until I junked the radio.
Posted on Apr 13, 2015
Great solution! I only got as far as opening up the unit to the sirius tuner and then ran out of time.
Thanks for the "key" to the puzzle!!
Posted on Mar 31, 2008
Ditto - JVC KT-SR2000 backlight doesn't work (watched die yesterday), after 2 years, 10 months. Sadly JVC no longer represents quality.
Note: Original JVC KT-SR2000 was a fire hazard - defective from start - overheated hardly describes it. BestBuy replaced first month.
Posted on Jan 29, 2008
I was able to fix mine, and blogged the process:
JVC KT-SR2000 backlight repair
Of course, opening the unit voids the warranty, but if it was still under warranty, you wouldn't need to know how to fix it yourself, would you? :)
Hope this helps!
Natasha
Posted on Mar 30, 2008
Backlite display on JVC sirius radio stopped working?
Typical Sirius junk - overheats and display goes out. Buy a new XM Onyx Plus radio instead.
Dec 28, 2012 | JVC KT-SR2000 SIRIUS Radio Receiver
Citroen c15 van i have fitted a radio only when you turn the side lights on it blows the fuse
Does the radio work if the dash lights are off?
I'm wondering if the power and lamp wires are reversed in the 3 wire connector that plugs into the side of the radio.
satellite radio receiver
Aug 24, 2012 | JVC KT-SR2000 SIRIUS Radio Receiver with...
My sirius kt-sr3000 also works fine in car dock, but when inserted into it's plug+play boom box,boom it displays "antenna not detected"
Try swapping the boombox antenna with the car dock to see if you get the same problem. If yo do, you know the boombox is bad. Otherwise, its the antenna and you just need to get a replacement.
Jun 13, 2011 | JVC KT-SR2000 SIRIUS Radio Receiver
Display does not work
HI. I lost my code for radio ford focus serial number M227636
Feb 03, 2011 | JVC KT-SR2000 SIRIUS Radio Receiver with...
Disassembly of JVC KT-SR3000
Did you get it open? remove the two screws. Those are all the screws on the outside. Gently pry the halves apart at the bottom of the unit. Gently try a flat screwdriver. GENTLY! Theres some tabs that hold the rest together. You may break one or two but will be ok in the end. Do the prying at the bottom so you dont break the tabs at the top.
Apr 09, 2009 | JVC KT-SR2000 SIRIUS Radio Receiver
KT-SR3000
Had this problem with mine. turned out to be bad solder joints. Take the unit apart and solder these joints and it should fix the display problem.e0ae4d7.jpg
Jul 31, 2008 | JVC KT-SR2000 SIRIUS Radio Receiver
Backlight
My JVC does the same thing. i called sirius to cancel my subscription because of this reason and they are sending me a free cheap InV as a replacement.
Aug 18, 2007 | JVC KT-PK2000 SIRIUS Radio Receiver with...
Antenna not detected / Searching for signal
I have the same problem. It's happened twice now. Each antenna has lasted about 1 year. The connection is good, the antennas just stop working. It's almost like there's some built in life span. Who knows. It's ridiculous either way.
Antenna Not Detected. Now I have to buy a new one AGAIN $39.00 and re-wire thole whole thing in my car. PITA
Jan 19, 2007 | JVC KT-SR2000 SIRIUS Radio Receiver with...
JVC KT-SR2000 SIRIUS Radio Receiver with Car Kit Logo
2,197 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
shaun taylor
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
