Question about Samsung WEP200 Headset
Wont' pair with BB 8830
I have tried pairing the headset with my BB 8830, but my phone will not recognize the headset.  I don't know why (frustrated!)?
  • dstefanidis Dec 07, 2008
    My BB 8830 does not find the headset. Same is true for my Sanyo Katana cellphone and my Dell home PC. What is this about?
    DS
  • racrjr70 Dec 27, 2008
    I cannot get my BB8330 to set up with my samsung wep 200 bluetooth
I had the same problem. Here is what you do:
When your headset is off push the multifunction (on/off) button and keep it pressed until the blue light turns solid blue (i.e. is not blinking). Now you can pair it and your BB will detect it. If you do not wait until the light remains lit it will not happen. Unfortunately this point is not well emphasized in the instructions of use for the device.
Enjoy
Posted on Dec 07, 2008
Em227 wont pair with samsung intensity... phone will recognize but continually get failed pairing message... please help!
make sure that the code you enter in to the phone as the pairing code is correct. most of them are 0000 or 00000, some of the samsungs are 1234.
this code must be entered in correctly to pair the device. If you are using an iphone, there are some issues with it people report.
Aug 24, 2011 | Southern Telecom Emerson Bluetooth Headset...
I am trying to pair my 220 with my blackberry 9600. This is my 3rd BB. It won't let me pair this phone. Do I have to clear the other pairings? I no longer have these phones. Is there something else I need...
Shut your Explorer 220 off. Shut your phone off and take the battery out for about 30 seconds. Put the battery back in and turn your phone and headset back on and try re-pairing them. This should take care of the problem for you.
Here is a link to the Plantronics Explorer User's Guide.
Good luck from Headsets Direct!
Apr 19, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Samsung WEP 450 was working ok for its 1st 24 hrs paired with Samsung B2100, however will not connect now. I've gone through the pairing up process again and the device cannot be found. The only other...
normally, the pairing has to be done once. If successfull, you can not pair the device a 2nd time withou removing it from the "paired devices" list in your phone. In order to get it recognized you should do the following.
1. check that BT is off on both devices
2. turn BT on on your mobile phone
3. power on your headset. In case, you have paired the headset successfully before, it has to be registered in your phone. It should then automatically find for the paired device (your phone in this case) and connect.
Dont try to power on the headset before turning BT on on your mobile phone.
If you have no success try to navigate to the bluetooth settings, check "paired devices" and make sure that your headset is deleted. Do the pairing and the 3 stepps above once again.
Don forget, that the headsets also have to be charged..
Jan 13, 2011 | Samsung WEP450 Bluetooth Headset - Retail...
Phone wont recognize bluetooth
When you say "phone wont recognize bluetooth", do you mean that the phone can't find it, or that it finds it but doesn't complete the pairing? It could be that that headset is not completely in pairing mode. It should have either flashing blue or flashing red/blue or solid blue.
Sep 09, 2010 | Motorola Mobility H710 Bluetooth Headset
ST3 will not pair to any phone. Phones recognizes St3 but will not pair
I had similar problem with Motorola and Blackberry Perl. It seems that the device may have been used or demoed at the store, and had to be re-set to factory defaults. The procedure is simple.
  1. Make sure that the device is OFF
  2. Press and hold Volume UP and green ON buttom at the same time
  3. After reset, power the device OFF and wait for approximately 10 seconds
  4. Power the device ON, select a language, and follow voice prompts to complete pairing
Sep 06, 2009 | Blueant Blue Ant 091193 Supertooth II...
How do I pair the h7oo witt the bb 8830
Depending on the phone... try and remove the current bluetooth device. Go to the Manage connection app and choose blue tooth. Or go to options, Bluetooth. you will then see what is or isnt connected. Close the headset. Go to the phone and choose discover, or search. Open the headset and press and hold the big button. It should then turn purple and should be recognized. After this, it will ask for a passcode.
Also make sure the battery on theheadset is charged before doing this.
The passkey will be 0000, four zeros.
Aug 04, 2009 | Motorola Mobility H700 Headset
Pairing my motorola h710 to my 8830 Blackberry
Depending on the phone... try and remove the current bluetooth device. Close the headset. Go to the phone and choose discover, or search. Open the headset and press and hold the big button. It should then turn purple and should be recognized. After this, it will ask for a passcode.
Dec 23, 2008 | Motorola Mobility H710 Bluetooth Headset
Pairing NOkia BH-207 with Blackberry 8120
Power it off
Press the power on button for at least 10 seconds, until it keep the blue ligth on and then pair it with your BB
Dec 14, 2008 | Nokia Bluetooth Headset BH-207 Wireless...
H12 able to pair but no sound
Yes I would think that the unit is bad. If it is paire and you see volume level then there should be sound.
Dec 03, 2008 | Motorola Mobility Motopure H12 Bluetooth...
Pairing WEP200 w/BB Curve (8330)
Just make sure when you're first syncing this to your cell phone, hold the main button for a REALLY long time. NOT till it flashes (keep on holding it). It will eventually go from flashing to a SOLID blue light, and that's when you sync. It'll probably take like 30-60 secs of holding.
That's what worked for me, my phone wouldn't recognize the headset until this.
Jul 02, 2008 | Samsung WEP200 Headset
Samsung WEP200 Headset Logo
83 people viewed this question
Top Samsung Radio Communications Experts
sonic boom...
sonic boom...
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
