Question about E-Machines Computers & Internet
I have an emachines mx4624 laptop that wont turn on. The power cord has tested good but won't turn on or charge the battery. Can it work with a dead battery and a good power cord?
  • MRTech40 May 11, 2010
    I am not familiar with e-machines, but good luck. It sounds like you have an internal power problem in the Power Distribution or motherboard. Like I said e-machines are not my strong side.
    To answer your question. From my experience, laptops can boot with a power cord only, as a matter of fact, lots of people remove the batteries to avoid heat while using the power cord. i just wonder how they expect their battery to get charged.
    Note: most batterries have power indicators that you need to depress to see its charge.
  • 72 Answers
Hi there, Sounds like your Power Jack is Broke... Take a small screw driver and lightly check to see if theres any play in the jack. if you are getting play don't panic its a cheap easy fix but my require some desoldering/soldering to install new jack. if you do find this is the problem i can give you step by step directions on opening up your laptop and installing a new one and where to buy one. good luck
Posted on Dec 07, 2008
Laptop battery light won't stay on
The battery might be dead. Batteries only have a useful life and after that they have to be replaced.
Does your laptop work ok off the AC Adapter Power Cord? If so, your battery is dead and your power cord is good. If the laptop does not work off the Power Cord then either your Power Cord is bad or the DC Power Jack where the power cord plugs into the laptop is bad. In either case a good battery will not charge if the power cord or the DC Jack is bad.
Check your DC Power Jack which is where the power cord plugs into the compute. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Jun 03, 2012 | Toshiba Satellite Computers & Internet
New battery HP g61 is fully charged but not working \
Maybe the AC Adapter Power Cord is not working. If you can't get on the laptop with the power cord then it is bad and the battery might be drained so you have no power source to power up the laptop.
If the laptop works only off the Power Cord and the batteryis not charging, then the battery is dead.
To check to make sure the Power Cord is working remove the battery and let thelatop run for 10 minutes or so.
To check to see if the battery has any charge left in it put the battery in andremove the power cord. If it won't boot or shuts down then the battery is deadand needs to be replaced if the power cord is ok.
Apr 30, 2012 | HEWLETT-PACKARD HP G61A50US 156 AMD Athlon...
T will indicate charging but it won't charge actor
Apr 23, 2012 | HP Compaq nc6400 Notebook
How to test laptop output to the battery
Click Start Control Panel and go into the Power Options to check the Battery Meter. Batteries on last for so long. Maybe it's time you buy a new one.
Apr 20, 2012 | HP Pavilion Dv9910us Notebook PC
Batterie ne charge pas
Apr 02, 2012 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Hi I have a Toshiba laptop model no.psl2xu-ookoof and it doesn't charge anymore so what do I do
If the laptop works only off the Power Cord and the battery is not charging, then the battery is dead.
To check to make sure the Power Cord is working remove the battery and let the latop run for 10 minutes or so.
To check to see if the battery has any charge left in it put the battery in and remove the power cord. If it won't boot or shuts down then the battery is dead and needs to be replaced if the power cord is ok.
Mar 26, 2012 | Toshiba Computers & Internet
Why is my acer emachine charging blinks in red
That is a signal that your battery is almost dead or drained. If you have the power cord plugged in and the battery is not charging at all, that means the battery is dead and you need to purchase another one.
In windows xp you should be able to click Start/Control Panel/Power Options. When the power options window opens click the Power Meter tab. It will tell you if your battery is charging.
Now to isolate if it's really the battery that's dead or if it's the Power Cord that's bad. You might really be operating on battery power even though you have the power cord plugged in.
1) Turn the laptop off and remove the battery. Turn it back on with only the power cord plugged in. If it comes and and boots up ok, then your power cord is ok.
2) Turn the laptop off and this time put the battery in, but leave the power cord off. Now hit the power button and see if it boots up. If it does that means you might have a little power still left in the battery, but since it was not charging when the power cord was plugged in, the battery is bad because you verified in step one that the power cord is good.
Mar 21, 2012 | Computers & Internet
Laptop Battery Won T Charge on a laptop dell inspiron 1525
Battery could be dead and won't hold another charge. Batteries only last for so long until you have to replace them. If you laptop is ok with the AC Adapter & Power Cord meaning it boots and allows you to work in windows, then the battery is definitely dead.
Mar 19, 2012 | Dell Computers & Internet
Battery wont charge on a dell anspion1525
Will the laptop power on with the AC Adapter and Power Cord plugged in? If so, the battery is probably dead and won't hold a charge. Batteries don't last forever.
Compaq presario C501nr wont charge battery
its in your power jack its a common problem try to check and change.
May 06, 2009 | Microsoft Compaq Presario C501nr Notebook
Computers & Internet Logo
71 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
