Question about Samsung SyncMaster 244T 24" LCD Monitor
Samsung 244T Monitor
Recently installed Windows Vista. When I bring the system up from a low power mode (i.e. screen saver active, and move mouse) the LCD has red horizontal lines flashing all over the display. If I power off the monitor, wait 3 to 5 second and power back up lines are gone. Other than the red lines the monitor works excellent. I have the monitor driver installed, along with the latest Vista ATI X1900 series video card driver. Any ideas, have updated motherboard BIOS and chipset drivers as well. Thanks in advance.
    Habit-Forming:
    New Friend:
  • 11 Answers
Try to use a different monitor, do the lines go away?
Sounds like that display is going bad.
Posted on May 16, 2017
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 93 Answers
Try changing your vga cables
  • 624 Answers
SOURCE: LCD 19" Samsung - one half od display has yellow vertical lines
Vertical lines are typical of LCD panels that have failed. I would certainly try the monitor on another machine; however, if the problem follows the monitor this is probably going to require some repair work. Unless you have the tools and skills to work on fairly delicate and potentially dangerous components this will be a job for an authorized repair shop. If you have any more questions let us know otherwise please don?t forget to rate this post.
Posted on Feb 09, 2007
SOURCE: Screen goes blank when I move the mouse
Did it work properly using a VGA (analog) cable? If so, check your DVI (digital) cable against the pictures at the bottom of http://www.datapro.net/techinfo/dvi_info.html.
You probably have one of the two at the left. Each has a different bandwidth, translating to a maximum resolution. The native resolution for your monitor might be marginal if you have a single-link DVI-D cable.
My 204B seems very picky about signal-level. It blinks when connected by DVI, even though it should be fine with a single-link cable, and complains about the settings even though the settings are optimal. Maybe yours is similar. I have ordered a dual-link cable and will try that myself.
Posted on Mar 10, 2008
viziks
  • 220 Answers
SOURCE: Samsung SyncMaster 510N LCD TFT Monitor
Does the monitor remain on does it switch off?
Problem seems to be hardware related ie monitor itself is defective.Try connecting to another known working system.If monitor is defective it could be a power/inverter related issue or panel could be defective.
Please provide feedback and rate the solution.
Samir
Posted on Jun 16, 2008
SOURCE: Trouble with Samsung 2233RZ
The same to me
I think the monitor is broken
Posted on Dec 09, 2009
SOURCE: Rotation of Samsung SyncMaster 2243BWX
They are referring to the video card in your COMPUTER, not the monitor. There is a supported list of cards at http://www.samsung.com/Products/Monitors/magictune/magicrotation_06s.htm
Posted on Feb 01, 2010
Samsung syncmaster 244T. Powerlight blinks and no picture for about 5-7 minutes then steady light and monitor works fine.. Any suggestion?
monitor is power saving mode
when taking a monitor out of this mode is move the mouse or press keys on the keyboard You can buy a used from eBay for $100 or I would buy a new one for about the same price 24 inch monitors are around $100
May 14, 2018 | Samsung Computers & Internet
Chromebook crashes after an hour on youtube if there is no other activity
Good day;
Question: after the screen is dark. did you try to press any key or moving your mouse to return the normal screen?
Try this: in your desktop windows right click on your mouse then choose properties to entering the display properties.
- select "screen saver"
- select the "power botton" to entering the (Power Option Properties)
- On the Settings for Home/Office Desk power scheme
- select never to avoid automatic turn the monitor, hard disk, system standby or hibernates:
apply then ok
Let me know if the has been solved
Feb 19, 2013 | Samsung Chromebook Series 3 XE303C12
Screen comes on for a second then goes black. It
its just ur monitor setting or the setting in ur pc for stand by mode or power saver mode.
if u still could not figure it out pl say me which system u using(platform)
Jun 01, 2010 | Computers & Internet
Monitor keeps switching itself off
Switching itself OFF to me it means even the LED light at the front goes OFF. If that's the case, you may have a hardware problem. However, if the LED changes color, chances are your monitor is gone to "sleep mode" in order to save you money on energy. If the latter is the case, simply moving the mouse of pressing any key on your keyboard brings the display back. Try that.
Energy saving is controlled by your Operating System, Windows or Mac. Look in the Control Panel for Power Management or similar category. In Windows, these settings can be found and are related to Screen Saver. Look there first.
Aug 25, 2009 | Xerox Computers & Internet
Dell Inspiron 1100 screen goes into power saver mode after 45 sec
it sounds like your most likely having trouble with the hibernate feature try this
start>>control panel>>power options>> click on the hibernate tab
un check enable hibernate mode
this should fix your issue
Apr 10, 2009 | Dell Computers & Internet
Monitor won't stay on
Your computer may be in screen saver mode, it has instructed the monitor to go to power saving mode, or the the monitor's video cable is not properly connected to the computer. Another possible cause of this is a locked-up or in-operative computer since the computer is what supplies the monitor with all the display data or information. Move the mouse or press a key to de-activate the screen saver or power saving mode. Check the monitor's video cable and make sure it is snugly connected to the computer. To see if the computer is operating properly, press the CAPS LOCK key on the keyboard repeatedly while checking the CAPS LOCK light. If the light is not turning ON & OFF, the computer is non-functional. Contact your computer manufacturer for help.
Dec 02, 2008 | Computers & Internet
Screen shows no signal
Hold down the power button for about 6 seconds continuously, this should wake it.
Sep 19, 2008 | Compaq Presario 5000 PC Desktop
My screen acts as if it's on energy-saving-mode but doesnt activate...
Check and reset the Screen Saver to the settings you want, even if its set properly. Did this work?
If not, reset the monitor to factory defaults to flush its memory.
If that doesn't work unplug the monitor for a minute and replug.
Sep 02, 2008 | Samsung SyncMaster 930BF 19" LCD Monitor
Digital power saving mode
check your monitor power settings.
right click on your desk top then left click on 'properties' in the white box that appears.
this will bring up a 'display properties' box which should have a tab headed 'screen saver' amongst others.
select the screen saver tab.
in this tab there are 2 sections. one to select which screen saver you want to use (and what settings are applied to it), and another section which should be called 'monitor power'.
click the button here which says 'power...' to adjust your power settings.
in the next window there are 4 tabs. select the first tab (power schemes - which should be already selected by default) and you now have 4 options. leave the selected 'power scheme' in the top of the window as it is and just alter the settings for the selected power scheme.
your 4 options are: 'turn off monitor', 'turn off hard disks', 'system standby' and 'system hibernates'  i would recommend setting all of these to 'never', and don't forget to click the 'apply' button after you've done this.
i would also recommend disableing hibernation in the 'hibernate' tab (this is in the same window as the power schemes tab).
once you've adjusted your power settings, don't forget to activate one of your screen savers.  this is only important if you leave the monitor on for a long time with no changes taking place in terms of what is being displayed. if you leave a static image on for hours you will end up with permanent screen burn. (a ghost image that is always there - even when the monitor isn't switched on!).
i don't bother with screen savers personally as i find them annoying, and find it much easier to simply turn the monitor off whenever i'm not going to be using it for the next hour or more.
hope that solved your problem. apologies if it doesn't.
by the way, the tabs etc i described are what i have on my OS (windows XP pro) and may be named differently if you're using a different version of windows.  the 'power options' settings will still be accessible via 'screen saver' tab in desktop properties though.
good luck!
:o)
Oct 11, 2007 | Gateway FPD2275W LCD Monitor
Samsung SyncMaster 244T 24" LCD Monitor Logo
97 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
ismael castillo
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
