My washer doesn't spin
I have an Estate washer by Whirlpool model #TAWS850PQ0 purchased 2/05 that doesn't spin. I thought it would need a v-belt but I don't think this model has a belt. What could be the problem? Thank you
    Sergeant:
    Champion:
  • 291 Answers
If it will pump out in spin cycle then the motor coupler is most likely bad / larryyb
Posted on Dec 07, 2008
Washer broke
that is just a dampening ring. Does nothing with the funtioning of the machine. if the machine stays full of water and doesnt drain
May 27, 2013 | Washing Machines
ESTATE TOPLOAD WASHER MODEL#TAWX700JQ3, DOES NOT SPIN FAST ENOUGH TO EXTRACT SUFFICIENT WATER FROM CLOTHE
Check if the belt is good and tight enough. If that washer uses a spring tensioner on the belt, make sure it travels freely and applies sufficient tension.
Jan 01, 2010 | Estate TAWS800JQ Top Load Washer
Whirlpool Estate etw4300sq squeaks during spin
WASHER IS FINE, SOMETIMES SQUEAKS WHEN THE TEMPERATURE CHANGES
Nov 08, 2009 | Crosley CW5000 Front Load Washer
My Estate Whirlpool Washer, model #TAWS850PQ0 fills the tub but does nothing else. It does not agitate or spin, just hums.
if it cuts off the water ok and motor running
it could be a coupling .
possible transmission.
if no motor noise
could be motor .
wiring,
timer.
Jun 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
ESTATE TAWS800JQ1 WILL NOT SPIN
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
May 27, 2009 | Estate TAWS800JQ Top Load Washer
Washer stops after the tub fills, agitator and tub do not spin
Your lid switch is bad. If you give model number I can give you the part number you need.
May 18, 2009 | Whirlpool Washing Machines
Washing machine spin problem!!!!!
whirlpool estate washer is dun the clothes are ring Wet
Jan 13, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Water leaks from inside of machine
TAWS850PQ0 WITH SAME ISSUE...found it to be the water pump located bottom front of machine...looking for replacement now...
Nov 13, 2006 | Estate TAWS850PQ
Washing Machines Logo
144 people viewed this question
Top Washing Machines Experts
