Question about Sony PlayStation 3 40GB System
I made a mistake and had my av and hdmi cords pluged into my tv and ps3 at the same time. The screen turned red. I got scared and had put my finger over the power button for five seconds now I have a blank screen.
  • 275 Answers
Turn the system off then turn it back on and keep holding the power button , when you hear the system beep let go watch the light blink or look for any changes on the screen display, if no change in screen yet turn off and back on again. If no change i would advice that you get it contact with Sony and consider getting a replacement.
Posted on Dec 07, 2008
Playstation 3 works fine useing the av hook up but won;t work with hdmi cable hook up.
First, make sure your TV is on the appropriate input for the plugged in HDMI cable. Once this is completed, turn your ps3 on. If the screen comes on and is black, turn the ps3 to standby (red light is on) and hold the front power button until the console beeps a second time. This will usually force the ps3 to recognize the hdmi input and will bring up the menu to configure the AV settings.
Aug 13, 2014 | Sony Playstation 3 (PS3) Console
How do i connect a playstation 3 to a philips tv
The PlayStation 3 (PS3) is a high-definition gaming console that supports both standard AV connections and high-resolution connections (such as HDMI). Most of the older Philips TVs come with a standard AV input. Newer, flat-panel Philips TVs include standard AV inputs and high-resolution inputs. To get the best video quality out of your PS3, using an HDMI connection is recommended if the option is available. The PS3 does not include an HDMI cable, only a standard AV cable
Standard AV
  • 1 Turn off the PS3.
  • 2 Connect the flat end of the PS3 AV cable into the "AV Multi Out" port on the back of the PS3.
  • 3 Connect the "red," "white" and "yellow" prongs on the opposite end of the PS3 AV cable into the corresponding "red," "white" and "yellow" AV inputs on the TV (usually located on the side or in the back).
  • 4 Press the "Source" button on the Philips TV remote.
  • 5 Select the "AV" video display mode.
  • 6 Turn on the PS3. The PS3 logo will appear on the screen.
  • HDMI Connection
    Dec 08, 2010 | Philips Televison & Video
    Yesterday, i played my PS3 on a hd tv using the hdmi cord for the first time, then when switching back to a regular tv and using the red, white , and yellow rca cord, the ps menu didn't show?
    There are a few ways to remedy this situation.
    1) If you have access to that HDMI port on the TV, plug it back in and switch the settings back to composite. Your screen will go black which means you did it right.
    2) I've only done this once and it was a trial-by-error step. Plug it into the tv, turn it on, hold your finger over the power button to turn it off. Hold your finger over the power button when turning it on. After a few cycles it worked for me. Key thing is to keep reseting it.
    The safest thing to do is get the HDMI tv to switch your settings back
    Apr 16, 2010 | Sony Playstation 3 (PS3) Console
    When i plug my hdmi cable into the back of my PS3, it says no input on my TV ?
    you need to connect both the yellow red white cable and the hdmi cable into your ps3 and go the yellow red white av channel
    go to the ps3 settings and change the video settings (ithink) to hdmi and also change the sound to hdmi
    the screen will go blank and then the tv should change to the hdmi av channel if not change to it and accept the changes
    Dec 13, 2009 | Sony Playstation 3 (PS3) Console
    My ps3 will not show a display of my tv
    it might be the video cord depending on what your using, if you are using a HDMI cord you may want to use the normal AVI cords to set your ps3 for HD and them go back to the HDMI
    Aug 23, 2009 | Sony Playstation 3 (PS3) Console
    How do you change the output setting from hdmi to the rca cable setings? I have no picture screen on my crt tv.
    you have to reset the ps3 because you have it with hdmi before and the ps3 is looking for an hdmi connection is very easy and there is nothing wrong with your ps3 ok so do the follow
    turn the power switch off on the back of the unit then put your finger in the on/off switch now turn the main switch on the back of the unit you will heard a first bip sound this is when your ps3 turns on ok keep your finger there in the on/off switch until you heard another bip sound now remove your finger from the on/off switch and bingo this will reset your video settings now you can see picture again using regular av and every time you use hdmi you have to do this again
    Jun 05, 2009 | Sony PlayStation® 3 (80GB) Console
    No signal on my TV
    try connecting the ps3 to the HDMI only, now when the ps3 is off and all but the single red light is on rest your finger on the on button for about 8 seconds, as soon as you touch it it will turn on but just wait a bit and you'll here the a second beep- this should reset your ps3's video output settings. Try it out, it works for me when i go back and forth from av to HDMI.
    Please remember to rate my response if helpful.
    May 30, 2009 | Sony Playstation 3 (PS3) Console
    No picture displayed on screen
    OK, I am assuming you are using the same TV, PS3, cables etc that you were using before you went on vacation. Turn off the PS3...we are going to reset the video display. make sure everything is connected properly before we start. now here we "kinda" gonna turn it on, except you will hold your finger on the touch sensative power button until it beeps several times in a row with about a half second between beeps. It should reset the PS3 and the resolution.
    If you get nothing on the screen after trying this several times, you should gather up 150 bucks and call sony for hardware repair.
    May 04, 2009 | Sony Playstation 3 (PS3) Console
    Turns on then off with blinking red light
    turn on your ps3 but keep your finger on the touch sensitive on button for 5-7 seconds, the sytem will beep again and all pictures are back to standard def. worked for me, so should work for you. good luck.
    Jan 18, 2009 | Sony Playstation 3 (PS3) Console
    Ps3 wont show up on tv
    Hey i just posted i have the same problem as you do but then I checked the SONY PS3 website and it solved my problem. Try resetting your video output. I'll paste what it says on the PS3 website but if that doesn't solve your problem go to the website. They have a bunch of troubleshooting solutions for this problem...
    If while manually changing the Video Output Settings, the screen remains blank for more than 30 seconds, you may need to perform the following steps to reset the Video Output Settings.
    1. Make sure the Component AV Cable is connected to the [AV MULTI-OUT] port on the back of the PLAYSTATION 3 system.
    2. Connect the other end of the Component AV Cable into the video and audio RCA jacks of the TV or display monitor.
    3. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
    4. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically be reset to the standard resolution (or detect the current display output settings of your TV/monitor).
    Nov 03, 2007 | Sony Playstation 3 (PS3) Console
    Open Questions:
    Sony PlayStation 3 40GB System Logo
    42 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
