Question about Panasonic DVD-LS5 Portable DVD Player with Screen
CODE HO3 WHEN I TURN THE UNIT ON, IT SAYS READING AND CODE HO3. NO PICTURE SEEN. PLEASE HELP
  • varsky Mar 05, 2008
    when I try to play a dvd or cd it has code ho3 on the top right hand corner and then it goes back to the loading screen.
  • SHANASS Feb 05, 2009
  • 3 Answers
Check my response here http://www.fixya.com/support/t160505-hd03_error
Posted on Jul 29, 2007
Error code HO3
On most Panasonic, error code HO3 indicates a mechanical problem, more specifically, the cradle that supports the laser eye could not traverse along its patch. Corrective action requires opening the unit, cleaning the slider bar, plastic cogs, worm gear/drive. It may help to use a can of compressed air and re-lubricate appropriate parts. Since the unit is open and expectantly dust would be swirling after the use of the compressed air, it may be to your advantage to swab/clean the lens itself prior to closing.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 18, 2008 | Panasonic DVD-LS90 Portable DVD Player
H03 Error
This problem is the laser optics in the wrong position.
Try to move it carefully by hand to the left near the spindle.
It may be stuck on the right side.
Please let us know what you see!
Jan 05, 2008 | Panasonic DVD-LX97 Portable DVD Player
Error code HO3
On most Panasonic, error code HO3 indicates a mechanical problem, more specifically, the cradle that supports the laser eye could not traverse along its path. Corrective action requires opening the unit, cleaning the slider bar, plastic cogs, worm gear/drive. It may help to use a can of compressed air and re-lubricate appropriate parts. Since the unit is open and expectantly dust would be swirling after the use of the compressed air, it may be to your advantage to swab/clean the lens itself prior to closing.
Aug 04, 2008 | Panasonic DVD-LS90 Portable DVD Player
HO3
Panasonic portable dvd player - error code HO3
Apr 05, 2008 | Panasonic DVD-LS50 Portable DVD Player
Panasonic portable DVD player
Mar 29, 2008 | Panasonic DVD-LS90 Portable DVD Player
Code ho3
Jan 05, 2008 | Panasonic DVD-LS90 Portable DVD Player
HO3
See my post on this http://www.fixya.com/support/t160505-hd03_error
Jul 28, 2007 | Panasonic DVD-LS5 Portable DVD Player with...
DVD-LS5
had same problem here but then i found a soloution might help you helped me
I purchased my LS50 over 16 months ago. I had a H03 error before and it went away after sitting on the shelf for three days. It worked ok for another couple of months and then stopped again. The screen says reading but the motor is not spinning. , then i spotted that the laser lens is in the wrong place. When at resting location, the lens should be parked near to the spindle in the middle. The mechanism to move the lens backward and forward sometime get stuck at the end of its travel - furthest away from the spindle. If your player is out of warranty, then you maybe able to try this. Open up the bottom cover by taking out the screws - 10 or so. This will reveal the lens and motor module. Flip over the model and you should see the gear and shaft for the lens. Move the gear so that the lens move towards the centre. Click the covers back into place , reconnect the battery and try. If it works, put all the screws back. Mine was fixed this way but this is not a gaurantee that this will work on yours. Good luck.
Forgot to mention. You can also clean the gear shaft in case there are small particules stuck to the grease and affect the movement. After cleaning, apply a tiny bit of grease just to lubricate the moving shaft. Not too much. I am glad that the instructions help.
it helped plenty of friends hope it helps you
Feb 20, 2007 | Panasonic DVD-LS50 Portable DVD Player
Panasonic DVD-LS5 Portable DVD Player with Screen Logo
256 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
