Question about JVC AV-48WP30 48" Rear Projection Television
Buzzing and static
Ihave a Toshiba 37" tabletop and it just started having static and occasionally buzzes about every 30 seconds.Picture color is fine but picture itself looks like little dashes running thru picture.
  • 2,920 Answers
You have a short in one of your tubes
Posted on Dec 07, 2008
I have a loud buzzing noise on my Toshiba DLP 46" projection TV. It is not the fan, it works fine. In fact the TV works great and has a good picture. The buzzing used to go away after awhile. Now it...
In some cases the buzz is external. The vibration of the unit may just cause a tray, flat surface, or other surrounding attachments to rattle and buzz. Look for anything that may be loose or laying on or about the TV.
Dec 09, 2014 | Toshiba 46HM94 46" DLP Projection TV 46" -...
Samsung model HLP4663WX/XAA with loud buzzing noise, need to know which part to replace.
See attached photo: you have a bad color wheel----it turns at about 12,000 rpm and bearings in the tiny motor go bad.
High pitched or fan like sound is classic symptom.
The wheel is available on the internet and You Tube has video instructions by model number for replacing it---Google the model number for the part number for your set to locate the part and instructions.
This for most people is a do it yourself job---takes like 45 minutes start to finish.
If color wheel slows too much set will shut down as its speed is monitored and the wheel can even shatter causing shutdown of the set.
Feb 28, 2012 | Samsung DLP HL-P4663W 46" Rear Projection...
Makes buzzing sound and no picture lamp?
Buzzing sound is the Color Wheel # BP96-00250A $83.25 Encompass Parts has them in stock 1-800-638-3328 and for Lamp Call FOX 1-800-227-5369 I got my Lamp off of E-Bay $85.00 I have the Same TV.
Dec 24, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
My TV model #HD50LPW628YX2 is buzzing I do get a picture, and the buzzing gets quieter after 30 sec of being on
Well that buzzing sound usually can be 2 things. First of all a color wheel but you have a good image, so there's a possibility it might just be the fan. If you start getting funky colors then it would be best you replace that
Aug 04, 2009 | RCA Televison & Video
Repetitive Buzz
Need to check the cooling fan.
-- open the back cover & unplugg two of cooling fan socket(black & red wires or yellow & red wires)
If the noise still remaining, need to exchange the color wheel.
Jan 29, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Buzzing and poor recption
I wish I had a solution--My DVD picture and sound is fine, but it takes about 30-40 minutes to get any kind of picture but it is broken--not clear at all - and the sound is all garbled, totally stops for seconds to minutes a a time. It is only a little over a yr old. I finally isconnectexd today and am going back to my cheap-o but dependable tv.
Aug 08, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
In play-back, buzzing/static after 10+ seconds of recorded message
unplug power adapter for about
30 minutes (this solved my problem of a buzz on the outgoing message)
Mar 09, 2008 | AT&T 1717 Digital Answering Machine
Toshiba 56HM195 56 in HD DLP Loud Buzzing and color distortion
If the sound, sounds more like a Hum with some vibration chances are the Cooling fan located behind the lamp is going bad, about $20 to repair, if its a high pitch hum most likely the Color Wheel and if thats the case about $30.
Good luck, my fan just went bad now seeing green dots everywhere, so debating on just junking it out or fixing it, with winter coming on might just breakdown and buy LCD and say the heck with DLP from now on.
Good luck to you..
Jan 27, 2008 | Toshiba 56HM195 56" Projection HDTV
No picture, buzzing sound
It sounds like the horizontal output transistor may be shorted....Can you feel any static charge on the face of the pix tube?
Nov 15, 2007 | Toshiba 36A43 36" TV
JVC AV-48WP30 48" Rear Projection Television Logo
32 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
