Question about Tascam Audio Players & Recorders
TASCAM 80-8 DECK NO VU LIGHTS NO REEL MOTORS CAPSTAIN MOTOR RUNS VU METERS THUMP WHEN SWITCH /MAIN POWER IS DEPRESSED
  • Tascam Master
  • 1,267 Answers
This would be a symptom that the power supply is compromised. It probably needs all new capacitors to allow it to work again. I have two of those model in my shop now.
Posted on Jul 02, 2017
  • 71 Answers
The machine vu lights were dim the reel motors ran then the lights got dimmer and the reel motors stopped its quite old now but never let me down . best regards kirk
Posted on Dec 08, 2008
Why is my Tascam MS-16 only powering the VU meters and capstan?
That complexity of the unit can not be repaired remotely. It needs to go to a Technician that is capable. Teac people that are still in the business are Russ at New Jersey Factory Service and Skywave Tape Deck repair in Chicago area. I am the Skywave guy.
Sep 04, 2014 | Audio Players & Recorders
First this is a large unit with a separate power supply. Check all fuses and make sure all cables are plugged in. The manual can maybe be obtained from Stereomanuals.com This is where I get manuals when I don't have them.
I have a teac 2300s tape deck. My problem is when i press the rec / pause or rec play the 2 meters slam to the right. They don't move while recording,but the deck will record and playback. Putting the...
The leads to the VU meters have shorted out. The fact that it only happens when you push "Record" sounds like part of the mechanism is actually causing the short.
Jul 15, 2017 | Pioneer Rt-1011l Reel To Reel Tape Deck...
My sony tapecorder tc-330 vu meter shows only one side working with the needle fluctuating, what causes that?
I have had that in a TC-366, the diode and a capacitor were the reason but you will need Technician tools, meters ans a soldering station to get the unit fixed. Sometimes the meter movement gets
knocked out due to abuse or shock. Does it move at any time as when you turn on the deck?
Sep 07, 2012 | Audio Players & Recorders
Tascam 644 When I press play it won''t stay on play, it stops. It will rewind and fast forward but that too stops by itself.
Scott has a point. You need to determine what is causing the unit to stop and it could be a bad cam motor belt if it has one or the lack of take-up die to the bad idler or even a dead spot on the reel motor. The reel motor will work normally at high speeds due to inertia but at low speeds as are used in play the dead spot of the motor can become much more apparent.
Sep 17, 2010 | Tascam 122MKIII Single Dual Cassette Deck
Tascam midstudio 644 powers up and can rewind and fast forward.
You have not mentioned the model. Hope you have checked the belt and the motor that drives teh main capstain and the reel drives. If this does not work then replace and proceed. Also the pinch roller could be defective and not holding pressure to the spindle. Check the roller for hardening of the rubbers. replace if this is faulty. I hope with the set loaded with a tape you can find which drive is not spinning to take up. This should be able to confirm you with the right section. Hope this helps. Good day
Jul 12, 2010 | Tascam Audio Players & Recorders
Tascam 238 tape deck
Common problem with these decks-the capstan motor needs to be replaced- A DIY job if you are careful and have some mechanical common sense- Tascam still sells these motors, around $100
Mar 21, 2008 | Tascam Audio Players & Recorders
Tascam 22-2 no sound
Yes you need to hook it up to an amplifier and speakers through RCA cable on the back. And or you can use headphones if there is a headphone jack?
Also make sure there is something recorded on the reel tape in the first place. You can do a test recording of something like a CD from your CD player or record something, then play it back, make sure you turn the record input volume knob up and make the RCA connections on the back of the reel unit and connect to your playback source you want to record. When you playback the reel tape, the db meters should be moving on the front of the reel deck, if they move then you most likely have some sound recorded on the reel tape.
If you still can't hear any sound and the db meters are moving, then check all your connections again and volume output knob on the reel deck. Hope this helps?
Sep 26, 2007 | Quantegy 456 Tape Reel(1/2 in. x 10 1/2...
AG-DV1000P that powers off when tape is put in.
hi sir one of the reel or capstain motors should be not allowing to work something prevents it from rotating check with hands for fluidity of capstain or reel motor that power off is a conclusion of a short while motor tries to spin check for any thing broken in the guides or the path regards please don't forget to rate ,thx
Mar 30, 2007 | Panasonic AG-DV1000 Mini DV VCR
221 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
