Question about Acer Aspire 5610-4648 Notebook
Acer Aspire 5100 black screen, I foolishly reset memory for video
Laotop was working perfectly until I reset memory for video in bios, then black screen, can't remove cmos bat b/c it is soldered to board bios v3.13. Vista Ult. 4gb
  • 9 more comments
  • Robert Love Dec 07, 2008
    Already removed bat. no results, black screen. Tryed to short cmos bat. w/screw driver,no results, maybe I didn't do it right. All I did was change memory for video frm 256 to 128 in bios, accepted change and hit F10, then bam..black screen. Haven't tryed external screen, but will right now
    Not sure I'm that good, but I have a practise board. Any other way around this?
    Acer Aspire 5102 Vista 64 Ult. 4gb Crucial. Removing bat and holding power button had no results..black screen..no prompt, no nothing. External screen, same..nothing. This laptop was working flawlessly..then nothing..can't reload anything..no beeps, just the light on the dvd drive flashes 4 times and clicks
    Tryed fn+esc and power button. Nothing, unit turned off. Powered back on and still nothing
    Have tryed all basics. Will not post w/ or w/out HD. Black screen, no response except dvd light flashes and dvd clicks
  • Robert Love Dec 08, 2008
    Maanita, Can't reset b/c I have black screen. No way in yet
    Marked, I tell folks that all the time. This time laptop was working perfectly, I changed the video memory, hit F10 and nothing. I was sitting right in front of machine. There were no power problems, no lightning, no rain. The unit just went black on repost. This is very weird
    Okay Ginko, this one I accept.Removing cmos bat. may be the only way. Rad. board obviously balked at being forced. If I blew it, I have another card. Thanks much guys, I assumed all this, was just hoping I was wrong
    Haven't tryed blind flash. Flashed this bios with Vista 32 boot disk b/c Acer refuses to give us a phlash 64. Worked perfectly Have never tryed blind flash, don't know how to flash without a post and program
    I don't like having to accept this, but welcome to the world of computers is what I say a lot. Don't know how to leave a rating, but you guys have all been helpful. I'll figure out how to vote. Since I see these all the time, you'll hear from me again
    This is for all the guys that helped me today. FYI shorted the bios with a screw driver at Jopen1 jumper, pulled the 4gb and replaced w/512mb, 5102 posted and went through a successful boot. Made sure of all bios settings. Checked memory in another 5100. System is running fine w/2.50gb. Won't post with all 4gb. Don't know what it is , but I'm not griping. You folks were great. Went back through all threads and made notes. I'll have another challenge tomorrow, I've got four of these. Thanks again
    New Friend:
Hi, i have similar problems, when i turn on the laptop, it only goes black and no text would appear but later on, there is a sound indication that it passes the loading of os. Where can we possibly fix the problem?
Posted on Oct 27, 2016
    Top Expert:
  • Acer Master
  • 77,499 Answers
Have you tried the manufacturer tech line? they have email support free of charge. Most software issues are covered for life as far as tech assistance goes, that excludes live assistance, so email only, also have you checked the data base of problems at the Acer web site?
Posted on Dec 08, 2008
  • 72 Answers
Have you tried checking the cords going to internal gpu? try unplugging them and then booting up and then shutting it down and plugging it back in. that should force the system to reinstall the device. I hope that helps I ran into that problem at the shop once and thats the only thing i could do to get system to boot. remember to remove all power sorces before unplugging anything since the constant 5v.
    Sergeant:
    Novelist:
  • 192 Answers
It sounds like the FSB/Memory module has failed. I have an Aspire 7520, and had the same problem a few months ago with the boot failure. Due to me having an almost identical problem recently, I decided to give Acer a call, after reading your post. They agree that it's more than likely the FSB. It shouldn't have been caused by you changing the memory size, the only way it would have failed, is if it was faulty anyway.
Acer also told me (off the record), that this is a common problem across most of the Aspire range.
The Solution:
Unfortunately, after speaking to two seperate systems engineers, the only solution they can see is to get it tested and repaired/replaced.
Sorry I couldn't be of more help.
  • Acer Master
  • 19,396 Answers
To start, changing video memory from 256 to 128 in bios should not affect the native video mode used in post , and also on bios menu.
That means that the video card is not working at all.
What probably happened is that the internal radeon 256 had ceased working when forced to 128 MB.
Try the following:
Connect an extenal montor.
  1. If you have picture on external monitor , restore settings.
  2. If you have no picture, my diagnosis was correct, the video card is not working after it had been forced to 128 MB.
You can try unplugging the power cord and removing laptop battery for ten minutes, this will drain power from the video adapter.
This probably does not work.
The only reliable solution is removing the CMOS battery, that is the thing to do.
You can get the job done at a local repair shop for a small fee, or do it yourself.
Find here disassembly instructions: Taking apart Acer Aspire 5100 laptop
Posted on Dec 07, 2008
  • 2 more comments
  • Ginko
    Ginko Dec 08, 2008
    Be careful if you do it yourself, remove the laptop battery before removing the screws, and try not to touch boards and components.
    Also ribbon cables are very delicate and easy to break.
    Always follow the order in the diagrams, do not force parts, and collect all screws in a cup.
    As usual DIY at your risk.
    Here is an upload of the service manual, pretty useful.
    If Video does not restart after resetting CMOS, then it is a damaged motherboard, forcing the card to 128 may have fried something, weird but possible.
    Good luck.
  • Ginko
    Ginko Dec 08, 2008
    One last thing, before disassembly, test the laptop on an external monitor snd see if it works.
  • Ginko
    Ginko Dec 08, 2008
    And don't do blind flash, that is a last resort, if you mess up the blind flash you fry the CMOS.
    Start from connecting to external monitor.
    Then reset bios.
    Then if it still does not go there is probably a fault. Try blind flash just in this case, it can fix a BIOS fault, but it can also damage furtherly the computer if it fails.
  • Ginko
    Ginko Dec 08, 2008
    Well mate, our solutions were great and you gave the reward to a guy saying: "Unfortunately, after speaking to two seperate systems engineers, the
    Sorry I couldn't be of more help."
    That is not great at all, isn't it?
    Have a nice day.
  • 6,487 Answers
It seems that a mobo replacemnet is needed here already because of all the symptoms that you have , the mobo is the prpblem here already...
    Genius:
  • 1,142 Answers
Reset the bios to default setting, save changes and exit and tell me the status.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, let's go back down to the basics:
  • remove, clean, re-seat the memory underneath;
  • remove, clean, re-seat any add-on cards underneath;
  • remove the HD and try booting without it.
Good luck and Thank you for using FixYa. Happy Holidays.
  • Louie  Role
    Louie Role Dec 08, 2008
    Appreciate your quick postback.
    But have you tried with only one (1) memory?
  • Louie  Role
    or a blind BIOS flash.
    Genius:
  • 1,239 Answers
HI Thinking about this one I really think the video had nothing to do with the black screen. I would try to things one is reset the power management. Not know exactly what Powerbook you have I will give the most common way. Remove the Battery and the power cord from the powerbook, wait a few minutes then hold the power button for about 40 seconds. Then put the battery and power cord back in and restart it. The second thing to do is boot from the install disk that came with it and run the disk utility. I have also seen bad RAM do this but you would get at least a chime on startup.
  • Acer Master
  • 13,433 Answers
Hey,
Unplug the laptop, remove the battery for 5 minutes and try starting again. Try using a external monitor see if you get picture.
Just a start report back with results.
  • 3 more comments
  • Ekse Dec 07, 2008
    Acer laptops are famous for vga failures, but it sounds unlikely in your case. can you solder the battery out from the motherboard?
    I have a service manual for another model I'l look into it and see if it has any instructions for this.
  • Ekse Dec 07, 2008
    press FN+ESC and POWER BUTTON. this function will force the bios to enter a special bios block, called BootBlock. It may start up
  • Ekse Dec 07, 2008
    BIOS Recovery: Boot Block is a special block of BIOS. It is used to boot up the system with
    minimum BIOS initialzation. The user can enable this feature to restore the BIOS to a successful
    one if previous BIOS flashing process fails.
  • Ekse Dec 07, 2008
    Comment posted on Dec 07, 2008press FN+ESC and POWER BUTTON. this function will force the bios to enter a special bios block, called BootBlock. It may start up
    Comment posted on Dec 07, 2008BIOS Recovery: Boot Block is a special block of BIOS. It is used to boot up the system with  minimum BIOS initialzation. The user can enable this feature to restore the BIOS to a successful  one if previous BIOS flashing process fails.
  • Ekse Dec 07, 2008
    I will return in around 8 hours sorry, I hope if my solution doesn't solve the problem that someone will have solved it with you by then.
Aspire acer 5100-3959 notebook bios password
step 1. try entering bios setup and get the error code for example 23456
step 2. in other machine use hirens boot cd and open bios password generator
step 3.- choose te option 2 and put your error code.
it works for me on acer 2920 whit phoenix bios.
Jul 26, 2012 | Acer Aspire 5100 Notebook
How can i allocate more memory to video card of acer aspire 5100
You can only do that with onboard video cards. If you have an onboard you can choose how much ram to assign to it in your bios settings. However it is limited and if you already have 128 assigned to it, that's probably about all it's gonna give ya. But hey it never hurts to check Assigning your physical memory to your graphics card will result a shortage of your total system memory and your whole system will slow down a bit.
Video cards meant for better processing the graphical content of your system and free up your system's physical memory.[via]
So, if you buy a new and better video card with more memory you will have a fast system with better performance.
Apr 27, 2010 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Laptop Screen Works Intermittently
Since you have video with an external monitor your lcd panel is going out.This is not hard to repair only costlyhttp://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Apr 06, 2010 | Acer Aspire 5100 Notebook
Update: Acer Aspire 5100 black screen post by daddysangelg.
yes, check first the inverter, then vga cable connection, or the video card...
Jun 07, 2009 | Acer Aspire 5100 Notebook
Resetting bios password.
Visit this link : http://www.tech-faq.com/reset-bios-password.shtml
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
Apr 03, 2009 | Acer Aspire 5100 Notebook
How to increase the video memory of my laptop
This is done in the BIOS screen. Upon startup of the computer, press the key or key combination the screen tells you to in order to enter the BIOS. Somwhere in there there will be a selection for video memory that you can change. Thanks and please don't forget to give this solution a fixya rating. :c)
Jan 08, 2009 | Acer Aspire 5100 Notebook
How to reset bios password
open the laptop and disconnect the cmos battery.wait for a minute then then replace back the battery.then post screans messages will appear.follow screen instructions.u
Aug 30, 2008 | Acer Aspire 5100 Notebook
Acer aspire 5100 - screen is turned off, cant turn it back on
The bios beep codes indicate the video card is not working, so you won't see anything on the screen.
Your video card is either dead, or is not contacting the board correctly.
If you are keen to open it up I will offer instructions to assist you. But in reality, your safest bet is to take it to a laptop shop and get them to do it. There are a lot of tiny screws in these things.
Apr 17, 2008 | Acer Aspire 5100 Notebook
Toshiba Satellite A135-S2376, black screen problem
first instinct u cooked sumthing
second try unpluging and removing both batterys ur nicad and the internal lithium 1
this shuld force bios 2 reset
if u cannot locate the internal battery un plug power and batt
w8 aprox 3days the internal clock will drain it 4 u
Apr 05, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5610-4648 Notebook Logo
4,357 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
