Question about Lexmark X6170 All-In-One InkJet Printer
When I try to print, misfeeding occurs, one side gets stuck.
I have checked for items that may have fallen into paper slot but found nothing.
  • meltdaddy Jan 02, 2009
    I have the same problem...when I try to print, the paper feeds but every time it gets stuck on the right side of the margin and then it won't finish printing the document.
    Genius:
  • 2,035 Answers
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
If the printer still misfeeds then its hardware problem..
Posted on Dec 15, 2008
Canon pixma mp495 error
Solution 2 is correct there is either a paper jam, or somthing obstructing the print path. First check to make sure you don't see no paper jamed, if not look in were you would put the paper to see anything that may have fallen that is causing jam, gentel turn printer side to side to see if u see hear or see anything moving around. If u see nothing then somthing has surly has fallen in printer has gotten stuck in printer rollers more then likly. To find out what's stuck find a piece of thin cardboard, I used the front cover of my phonebook and push cardbord through printer and what ever is jamimg the paper should pop out on the other side. In my case it was a flower seed and I was able to use twizzer to remove and issue was resolved. Printer is working fine
Feb 25, 2012 | Canon Office Equipment & Supplies
Paper misfeeding on one side but printer keeps printing with no paper
Look for any foriegn objects or old torn paper from an earlier jam. Something is either obstructing or mis-guiding the paper. If nothing is found, use a can of compressed air to blow thr paper intake area out, then test print again.
If still not solved, use a cottom swan soaked in alcohol to scrub clean the rubber paper pickup roller. Over time it gets slick from paper dust and the paper will notget grabbed evenly, causing it to skew as it's pulled in.
Jul 26, 2011 | Lexmark X2470 All-In-One InkJet Printer
Hi I have a cannon mp470 and it will not pull paper through to print. It either doesn't catch at all, or it will jam to one side.
Hi
There is something stopping the paper feed process. Try the following
1. Check and make sure nothing is fallen inside the paper tray
2. Remove anything stuck
3. Even if you are not able to see anything stuck tray to use a air blower and blow air in the tray this will remove anything stuck.
Jul 15, 2011 | Canon PIXMA MP470 All-in-One Printer
Will not print a test page also unable to find or adjust spool settings and cannot change Priority settings. Some things will print but many items will not, even then it seems very slow.
Printing Problems
? The machine beeps while printing.
The machine may have a paper jam.
• Clear the paper jam (1 p. 13-3).
? Nothing prints.
The power cord may not be plugged in securely.
• Check that the power cord is plugged securely into the machine and into the wall outlet (1 p. 2-9). If the machine is plugged into a power strip, make sure the power strip is plugged in and turned on.
You may not have removed the plastic seal from the cartridge.
• Make sure you install the cartridge properly (1 p. 2-13).
The cartridge may need to be replaced.
• Replace the cartridge (1 p. 12-7).
? Printout does not match the print media size.
The print media may not be loaded correctly.
• Make sure the print media is loaded correctly in the multi-purpose tray (1 p. 5-4).
? Printout is skewed.
• Make sure the paper delivery slots are clear.
? Print media jams occur.
You may not be using the correct paper delivery slot.
• Select the correct paper delivery slot (1 p. 5-7).
? Printout is not clear.
You may not be using the correct print media type.
• Make sure you load print media that meets the requirements for the machine
(1 p. 5-2).
You may be printing on the wrong side of the paper.
• Some papers have a "right" side for printing. If the print quality is not as clear as you would like it to be, try turning the paper over and printing on the other side.
? Printout has vertical white streaks.
Toner may be low or unevenly distributed.
• Redistribute the toner inside the cartridge (1 p. 12-7). If the problem persists, replace the cartridge (1 p. 12-7).
Jan 03, 2011 | Canon FAXPHONE L80 Laser
How do I access the rear tray roller feeds to check if anything is stuck all of a sudden the paper is skewed on the right side and paper doesnñt enter the feed
You say the paper is scewed to the right which means absolutely nothing if you think about it, isn't the left hand side also scewed? Usually one side of the paper is pulled down leaving the other side up thus scewing it.
Firstly make sure nothing has fallen down the paper slot, secondly make sure the sliding paper adjuster to the left of the paper is up tight against the paper, even a 1 millimetre gap can cause this problem, thirdly look down the paper slot with the paper in and make sure there is no gap between the bottom edge of paper and plastic shute or case, you really shouldn't be able to see much of the two pieces of white plastic, now press the green start button.
Dec 27, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
When printing paper gets jammed immediately gets so far and tears
this is likely something fallen down the back of your paper feed, tip it up and see if you can dislodge it, when the paper feeds see which side gets stuck and which side is pulled in. the problem behind one of the rollers on the side that the paper gets stuck, so if you can get inside with a spatula or wedge to lift the roller/rollers onthat side and tip the printer backwards youve got a fair chance of removing the problem. alternatively the problem could be with the front set of rollers check that there is nothing within the printer behind these rollers also.
Sep 26, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Paper Feed Problems
Hello sir; Try to remove all the paper out of the tray look inside of the bottom on right side , if you find something ( such as; paper clip, stapplers,paper chip etc) remove it , otherwise find a piece businese card stick reverse way from paper exit to clear up.
Jan 02, 2009 | Lexmark X6170 All-In-One InkJet Printer
Hi, I'm Ron a Disabled Frustated Senior Citizen. I have or the AX is going to get it. HP Photosmart 8050. 1, ONE Peice of paper Jamed. Now the RED Light is Blinking? No Idea. Also it says Print Cartridge...
Good luck..
Dec 30, 2008 | Office Equipment & Supplies
Printing Fault
Remove the paper and look inside, you will see some rolelrs that pick up the paper.
Take a cloth with some soapy cleaner, like fantastic or something alont that line.
Dampen that cloth with them and clean the rollers. May have to clean them 3 or 4 times to get all the comtaminants off of the rollers.
If they still are misfeeding. run your fingertips across them and see if they have a "slick smoothe" feel to them, if so, the are wonr out and in need of replacing.
Dec 20, 2007 | Epson Stylus DX4850 All-In-One InkJet...
Lexmark X6170 All-In-One InkJet Printer Logo
75 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
