Question about Panasonic DVD-LS50 Portable DVD Player
DVD-LS5 WHEN I PUT THE DISC IN MY DVD PLAYER, IT SAYS READING AND EVENTUALLY IT WILL SHOW CODE HO3. NO PICTURE SEEN. PLEASE HELP. THANKS
  • pettech76 Nov 24, 2007
    Player worker great for a cuple years. Then suddenly started showing the "reading " followed by HO3 error code. No help for this??????
  • jayson42 Dec 03, 2007
    when i put the disc in my dvd player.its says reading and eventualy it will show code H03.what can i do?
Had same problem here but then i found a soloution might help you helped me
I purchased my LS50 over 16 months ago. I had a H03 error before and it went away after sitting on the shelf for three days. It worked ok for another couple of months and then stopped again. The screen says reading but the motor is not spinning. , then i spotted that the laser lens is in the wrong place. When at resting location, the lens should be parked near to the spindle in the middle. The mechanism to move the lens backward and forward sometime get stuck at the end of its travel - furthest away from the spindle. If your player is out of warranty, then you maybe able to try this. Open up the bottom cover by taking out the screws - 10 or so. This will reveal the lens and motor module. Flip over the model and you should see the gear and shaft for the lens. Move the gear so that the lens move towards the centre. Click the covers back into place , reconnect the battery and try. If it works, put all the screws back. Mine was fixed this way but this is not a gaurantee that this will work on yours. Good luck.
Forgot to mention. You can also clean the gear shaft in case there are small particules stuck to the grease and affect the movement. After cleaning, apply a tiny bit of grease just to lubricate the moving shaft. Not too much. I am glad that the instructions help.
it helped plenty of friends hope it helps you
Posted on Dec 12, 2007
  • chalet-choco Sep 05, 2010
    Wow! It worked, thank you so much for this advice!
I am having the same problem. I went to Venezuela by Air Canada, and as I was waiting at the Airport, before checking in, I popped in a movie. I watched about half of the movie, I turned off and went to check in. I passed through customs, including those X-rays machines, and I aboarded the airplane. In it, I got bored and I decided to keep watching the movie I was seeing, then I found out that my portable DVD player wasn't working. I am getting the same message: Code H03. Did you go on trip too? Because think the X-rays machines broke the DVD player.
Posted on Jun 13, 2007
Whate causes Error H03 on a PANASONIC DVD-LS5?
the is not able to read the disk that's why you get that error message.the cause of error reading disk are busted dvd lens and the spindle motor it is the motor that holding the disk and spins .first try to replace the motor you can buy that in an electronics supply store next is try to replace the lens
Jul 17, 2010 | Panasonic DVD-LS5 Portable DVD Player with...
Player does not read disc-code HO3
I followed a few, of the already suggested answers. The first one I tried was to open up the back and use compressed air to blow out lint, food crumbs and dog hair that had found there way into the machine. This seem to have worked just fine. Now the machine is working, much to my daughters delight.
Sep 29, 2009 | Panasonic DVD-LS90 Portable DVD Player
Error code HO3
On most Panasonic, error code HO3 indicates a mechanical problem, more specifically, the cradle that supports the laser eye could not traverse along its patch. Corrective action requires opening the unit, cleaning the slider bar, plastic cogs, worm gear/drive. It may help to use a can of compressed air and re-lubricate appropriate parts. Since the unit is open and expectantly dust would be swirling after the use of the compressed air, it may be to your advantage to swab/clean the lens itself prior to closing.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 18, 2008 | Panasonic DVD-LS90 Portable DVD Player
Error code HO3
On most Panasonic, error code HO3 indicates a mechanical problem, more specifically, the cradle that supports the laser eye could not traverse along its path. Corrective action requires opening the unit, cleaning the slider bar, plastic cogs, worm gear/drive. It may help to use a can of compressed air and re-lubricate appropriate parts. Since the unit is open and expectantly dust would be swirling after the use of the compressed air, it may be to your advantage to swab/clean the lens itself prior to closing.
Aug 04, 2008 | Panasonic DVD-LS90 Portable DVD Player
Code ho3
Jan 05, 2008 | Panasonic DVD-LS90 Portable DVD Player
HO3
See my post on this http://www.fixya.com/support/t160505-hd03_error
Jul 28, 2007 | Panasonic DVD-LS5 Portable DVD Player with...
No Picture
i think this means it is dying. mine started to skip and then promptly stopped reading the disks too. i was told it may be the optical lense and it may be better to buy a new one than have it fixed. my problem now is that i can't find a replacement that is not upconvert (i see no difference in the component cables vs. hdmi). i am sad to lose this player. love it.
Jul 25, 2007 | Yamaha DV-C6480 Multi-disc DVD Player
CODE HO3
check my response here http://www.fixya.com/support/t160505-hd03_error
Feb 20, 2007 | Panasonic DVD-LS5 Portable DVD Player with...
Panasonic DVD-LS50 Portable DVD Player Logo
307 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
