Question about Apple iBook G4 (Z0AZW13397068) PC Notebook
Need location of U28 circuit in iBook G4 motherboard
New hard drive on iBook g4
it is not an easy job to change a HD on an old iBook G4.
you need some experience in handling microelectronics.
step-by-step guide is available here:
https://www.ifixit.com/Guide/iBook+G4+14-Inch+933+MHz-1.33+GHz+Hard+Drive+Replacement/189
iBook G4 14 933 MHz 1 33 GHz Hard Drive Replacement 24100867-eger5opjetenbdaollq52u3v-5-0.jpg
Apr 12, 2014 | Computers & Internet
Dell latitude cpi
Need to check if there is fault in the OS or there is a memory issue or within the motherboard.
Sometimes a reset could solve , clear memory and suspected files and reboot.
Apr 10, 2012 | Apple iBook 12 iBook G4 1.33GHz,...
Ibook g4 screen issue
That screen will most likely be compatible - I work on these for a living. The G3 laptop screens are usually not compatible with the G4 laptops, but all G4 laptop screens are compatible with eachother (provided they are the same size, of course.
Nov 10, 2009 | Computers & Internet
While is was searching on the internet my iBook G4 locked up. I tried to reboot and it locked up again. I tried to reinstall OSX but during the install it locked up. I replaced the memory and hard drive...
Dude, if you have all the current updates for your OS and applications, then you got a logic board issue. Especially if you you keep seeing the spinning beach ball of death or the dreaded white screen of death.
The iBook G4 is the poster child for logic board defects, because it has to do with the way the circuit boards were flowed.  Apple won't fix this for the iBook G4.  You got to do a big class action lawsuit like they did with the iBook G3 before they will replace the logic board.
Best bet is to sell this thing on e-bay as a non-working unit and get you a better laptop.
Oct 18, 2009 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Ibook g4 speakers dont work
Ibook g4 have speakers in the Top Case assy. You need new top case assy.
Oct 05, 2009 | Apple iBook G4 1 GHz 12" w/ Combo Drive ...
Ibook g4 rebuild
Hi there.
Make sure you have the voltage and amperage right first before you try and power up the motherboard.
Most laptop motherboards run on 15, 19 or 20 volts and take a different amperage like 3.42A for example.
The power in will be displayed underneath the ibook so take a look there.
Don't plug a 24 volt power supply into it unless it specifies that because you could damage the board.
Good luck with project
May 25, 2009 | Apple HQRP Replacement Laptop AC Adapter /...
Ibook G4 continually freezes.
reinstall your system.  what system are you using?
Mar 09, 2009 | Apple iBook G4 Mac Notebook
How to replace clock battery of ibook G4 laptop
Replace the on board capacitor with a Panasonic Capacitor 5.5V 0.22F Model number:EECS0HD224H cost about $3 . You will need to desoldier and soldier the new one on, it's easy even for a novice.
It is a kind of on board battery contrary to what most idiot mac users say as a battery IS a form of Capacitor.
Feb 12, 2009 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Water damage to iBook g4
You fried your motherboard. It would have taken at least a week if not longer to get all the moisture out of your computer but since you started it while there was still water in it, it fried it. You will have to replace your motherboard.
Jul 06, 2008 | Apple MacBook Pro Laptop Computer with...
Computers & Internet Logo
281 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
