Question about Dell Inspiron 2200 Notebook
The "A" Key is stuck.
I'm trying to figure out how to get under the keyboard to clean out what ever is causing it to stick.
    Problem Solver:
  • 5 Answers
I know this sounds crazy, buy if your keyboard is NOT a wireless, you can clean it by running it through the dishwasher. It works great. Do not do this with a wireless. Otherwise try a spray can of air from a retail store.
Posted on Dec 07, 2008
Have a Toshiba Satellite L505. My key was sticking, so I removed it. Under the A key are two smaller plastic pieces. Now I can't figure out how to reattach the key. Thanks!
LOL, it's much easier to just replace the keyboard. You can spend hours trying to get that key back on even if it can be put back on. You might have broken one of the little plastic catches.
May 01, 2012 | Toshiba Computers & Internet
My logitech keyboard is locked up. I was cleaning the keyboard with a napkin and now it won't work.
Thank you for using FixYa
More than likely you have jammed a key and it stuck, try and see if a key is depressed and pull it up with your fingers or a toothpick or popsicle stick, use something that won't scratch it. You might try to turn it upside down and tap on the back with your hand. There may be a piece of paper stuck in the keys and in that case a pair of tweezers might remove it. The key tops will actually pop off and can be pressed back down. If all that does not get it then most keyboard has some screws on the back and can be removed. Look under the legs, sometimes they hide there. If that still does not work, check and see if the cord is plugged in or twisted.
I hope this was useful and please comment if this was helpful to you.
Mar 22, 2011 | Logitech 967461-0403-PK Keyboard/Mouse
Have a HP Pavillion 3163cl Entertainment Laptop and the Space Bar asks like someone is pressing down on it at all times. Like a stuck key and makes the noise when turning it on. The Laptop belongs to my...
To clean your laptop's keyboard you have to look under your laptop, you can see like keyboard icons with some scews, so, open them, they will let yout to remove your keyboard.
So now your can remove just your keyboard slowly for some connectors on the motherboard then clean it with a tooth brush.
You can only clean your keyboard with a toothbrush without rmoving it,
Try to remove the space bar key and clean under it.
Try to hard press the space bar for about 5 times, it can release the pusher under the key.
it some liquid was spilt on it you have to remove the keyboard and clean the plastic under ther keyboard.
Good luck
Jan 20, 2011 | Computers & Internet
Random keys will stick every 5-10 minutes of use
Usually caused by some liquid or dirt getting under the keys, you can try blowing a can of compressed air under them to try and clean them, or if you have the patience of a saint, can remove and clean each key in turn with ethyl alcohol (not advised), failing that, a replacement keyboard is the only solution
Jan 04, 2011 | Dell 0Y3740 Keyboard
When loading very unpleasant noise than when im typing in the search window /////////////////// this symbol appearer what can it be?
Loud repeating beeps?
Indicative of a stuck key on your keyboard. Try seeing if the keys all "bounce back" after being pressed. If they stick, get a can of compressed air and gently blow it under the keys. If that fails, try with an external keyboard, see if that works, if it does, then you may need to have the laptop dismantled to clean/ replace the keyboard
Jan 02, 2011 | Toshiba Satellite A65-S126 Notebook
Our keyboard keys stick. Nothing has been spilled,but I find all of the keys seem to react very slowly. If I don't tap each key deliberatly, the letters don't show on the screen. I could sure use your...
Hello and thank you for using Fixya's services.
A can of air will fix this problem. You can find this at any electronics store. Turn the keyboard upside down and blow the air into the keyboard. This will clean the keyboard and anything stuck inside. Dust, food, etc. generally, over time, tends to get stuck in the keyboard and causes the "sticky" keys.
Hope this helps!
Nov 30, 2009 | Dell 0Y3740 Keyboard
Keyboard sticking during playing world of warcraft
Sometimes mine does the same too. So, I took out the keys that stuck, I made sure that they were clean underneath, then put them back in, making sure that the metal bar, that some keys have underneath, is back under the key, in the right place. I hope this helps.
Jan 21, 2009 | Logitech Computers & Internet
My son spilled soda on our keyboard.Now the x and s stick. I took it apart and cleaned it, but it still sticks. Also, a wire fell out from the space bar and I cannot figure out how to put it back.Thus the...
You cleaned the rubber under the buttons and the buttons too? All you do is put the metal bars straight down then angle it about 10 degree towards you then put it in like a regular key, but if you lost the wire then.... might need to get a new one, heh.
Dec 22, 2008 | Computers & Internet
Logitech cordless keyboard erratic after cleaning keys
seems to be that you may have accidentally swept some dirt underneath the keys.
try pressing each key individually in word and narrow down the affected key or keys, then remove the affected keys (using a keyboard key removal tool, or very carefully by hand) and clean underneath the key with a small dry clean brush both under the key and the board section it lay in, then replace the key and type the key again, if that has no luck then try the process again.
hope this helps
kev
Dec 01, 2008 | Logitech 967437-0403 Keyboard
Dell Inspiron 2200 Notebook Logo
Alun Cox
