Question about Singer Featherweight 132Q Mechanical Sewing Machine
Quit working I was sewing and the machine just got slower and stopped altogether. I oiled it throughly and plugged it back up, turned it on and it wouldn't do a thing except the light worked.
  • 27 Answers
The 132Q ahs a problem in the hook drive gear ,this is where it is seized up ,happens all the time ,from the back of the machine you can add lubricant to the hook gear and shaft but you will probably have to grab the gear with pliers etc and try to turn it once it loosens up it will be fine ,do not look elsewhere this hook drive shaft is the source of the problem.
Posted on Jan 10, 2009
Husqvarna sewing machine freezes and stops sewing
Is it a mechanical machine or computerized? If mechanical, it could need a good cleaning and oiling. Mechanical machines need to be oiled, and if not, the old oil solidifies and prevents the mechanical parts from moving.
Mar 15, 2015 | Husqvarna Sewing Machines
Singer Touch-tronic 2000 makes loud humming/buzzing noise, stitch selector lights quit working, needle bar stopped moving.
Sounds like you've got a thread jam going on in the bobbin case area. Good cleaning and a new needle will probably fix it. See:
Apr 20, 2014 | Sewing Machines
Bl4-736d serger foot control very hot and speed of machine slow to stop
sounds like the foot control needs to be replaced.
Jan 24, 2013 | Sewing Machines
Feed dogs won't move
No info on the sewing machine make or model. It sounds like something is binding up, is bent, or is tangled in the machine. Look around the front and back of the sewing area for a switch to lower the feed dogs.
Good luck
Oct 05, 2012 | Sewing Machines
My singer 9410 machine isn't working the wheel doesnt work anymore
it's possible that either a part is worn, broken, or damaged only a sewing machine repair shop can tell what's wrong
Jan 24, 2012 | Singer Sewing Machines
Sewing slows after use
The manual:
Jan 08, 2012 | Singer 5050 Mechanical Sewing Machine
Baby Lock bl 5280ED runs and gets slower and slower. Replaced motor and foot control and oiled throughly. The problem persists. I can see no visible cause for the motor laboring after running less than...
The problem is likely the stitch length adjustment cam. You will need to remove the cam. The cam is located on the left side of the machine (there is a screw under the plastic arrow cap) also remove the cam sleeve (looks like a steel bubble wand) resurface the sleeve until the cam turns freely, oil with sewing machine oil (NOT WD40!) or lithium grease. reassemble machine and adjust timing.
Jul 03, 2010 | Sewing Machines
My sewing machine starts sewing good and then it seems to
Providing the machine has been oiled if the machine is still running slow then the chances are the motor is on the way out.
Apr 25, 2010 | Sewing Machines
Machine wont move
I just found out that if you still have the bobbin winder on, the machine won't turn at all. So make sure that you have the winder slid over.
Dec 22, 2007 | Singer 8280 Mechanical Sewing Machine
Singer Featherweight 132Q Mechanical Sewing Machine Logo
113 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
