Question about KEF Audio KHT 2005.2 System
Kef subwoofer kht 2005:2
Subwoofer is on, but absolutely no sound. Can't see the green light which indicates that it is on. all configurations are checked.
  • 75 Answers
Check for the connection og the main wire is cut.. or check the supply..
Posted on Dec 08, 2008
Subwoofer cuts out kef (2010)
a capacitor could be overheating and cutting out.then,when it cools you get sound again.this will go on and on until you take it to a tech to get fixed
Aug 04, 2013 | KEF Audio Audio Players & Recorders
What is the finish on the black matt speakers
Unscrew the front of the speaker, hold the casing over a baking tray, repeatedly wash and work the thinners into the casing with a clean paint brush.This will gradually remove the sticky coating leaving the surface smooth and clean. Don't forget to wear rubber gloves.
Apr 27, 2012 | KEF Audio KHT 2005.2 System
I have a sony str-de475 and a kef PSW1000, i have the line in the left on the sub connected to the sub out on the amp, and the sub powers up, but im getting absolutly nothing from the amp and now all of a...
It's not clear if this has EVER worked or what is new in the scenario. The STR manual has setup instructions for supporting a sub. If you want to prove the sub itself works you could jack any source like, say, a CD player, into it to prove its amp will respond BUT IT WILL BE LOUD if it works.
Oct 05, 2011 | KEF Audio PSW 1000 Subwoofer
It states the power is on due to the front panel green light. I can move the sound bars up and down but there is no sound from the unit. I checked the cable etc but still no sound. I love this sub....
I wrote to Kef support about an identical issue. Their replay is below.
By the description you have given, it sounds like the power amplifier
board in the subwoofer has failed.
Unfortunately your subwoofer is no longer covered under warranty as the
electronics inside comes with a one year warranty as with all KEF
electronics, and the warranty card would have been supplied inside the
box.
However, you can return the amplifier section to us by removing the
screws on the very outer edge of the back of the unit and disconnecting
the cables inside. Once removed, carefully package the amplifier and
then contact the Service department on 01622 672261 with the serial
number to hand, they will then give you a returns number. Once you have
a returns number, you can send it to the following address with a
covering letter. When sending the parcel, please make sure that you send
it recorded delivery or get a tracking number if sending by courier.
PLEASE NOTE THAT ITEMS NOT BOOKED IN WITH THE SERVICE DEPARTMENT BEFORE
DESPATCH, MAY INCUR FURTHER DELAY.
The address is as follows:
F.A.O. SERVICE
GP Acoustics
Eccleston Road
Tovil
Maidstone
Kent
ME15 6QP
Mar 21, 2011 | KEF Audio PSW 4000 Subwoofer
I have a KEF KHT 2005.2 Subwoofer that does not produce sound any more, it makes a slight pop sound when i switch it on and thats it, no further sound. The system is about 5 years old but has not had a lot...
The KEF-Subwoofer range (from the PSW1000 up to PSW 3000?) have some built-in flaws in the electronic design.
I just fixed my PSW2000 working along the repairing instructions from:
http://lug.demon.co.uk/kefrepair/
Works! Costs have been about 35,- Euro for spare parts and some (too many) hours of work. If you are used to electronics and soldering you may make it in 2 hours.
Nov 07, 2009 | KEF Audio KHT 2005.2 System
KEF Speaker Sticky
My Dad had the same problem. KEF admitted it was a paint problem and replaced the speakers.
Sep 22, 2009 | KEF Audio KHT 2005.2 System
KEF Subwoofer PSW2010 (KHT2005.2) - No power
chik power sours first
thaen chik transformer inside
u will see it burned if so chang it
Aug 18, 2009 | KEF Audio KHT 2005.2 System
Sub doesnt put out a sound
go into your sound properties and make sure your sub is turned on or not muted there should be a seperate one for sub just like you have one for speakers
May 26, 2009 | KEF Audio KHT 1005 System
KEF KHT 2005.2 SUBWOOFER
You have a bad set of Audio output IC's for the sub. There is two of them. TDA7293 REPLACE BOTH!!!
There is 4 on one side of board,and 2 on other "also 1 small one" The the two are for the sub,the other 4 are for the main speakers/surround. They sell on Ebay for $6-10 each or a kit of all 6 for $25.
Dec 06, 2008 | KEF Audio KHT 2005.2 System
Subwoofer not working
if u are a technician then its easy to check, problems are, blown fuse, power amp IC output transistor may be blown, check for burnt componenets. changing and blowing a fuse means ur output IC or transistors are shorted.
May 15, 2007 | KEF Audio KHT 2005.2 System
KEF Audio KHT 2005.2 System Logo
748 people viewed this question
Top KEF Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Greg Cann
Greg Cann
Are you a KEF Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
