Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
No cold coming to fridge or freezer
There is a snapping sound under the fridge.. like a fuss snapping
    Sergeant:
  • 302 Answers
I woud say your heater has malfunctioned and it has frozen your fridge, you will need to remove the inside plastic wall on your freezer side if its side by side and get a blow dryer and melt all the ice if this is the case. You would need to change the heating element which defrosts your freezer/fridge everyday to prevent freezing up. You can get this heating element from an appliance store where all the appliance repair people get them specific to your model. Its less than a hundred bucks.
Posted on Dec 07, 2008
Freezer not freezing clicking noises
Almost certainty you have a rear control board fault these boards where notorious for capacitor faults causing relays to click and water dispenser to be erratic , the board can be repaired by a confident electrical engineer or you can buy a complete unit
Mar 31, 2017 | Whirlpool Refrigerators
Fridge is running but not getting cold. Line underneath feels very cold but air coming in fridge is not cold. Fan under the freezer and fridge is running.
Hi
If refrigerator is not cooling properly it can be due to a defrost timer, which is causing the fridge to go into defrost cycle. Usually it takes 45-60 minutes for refrigerator to come out of defrost cycle. If the timer is bad then it will not come out of defrost cycle and can result in this kind of issues. It can also occur due to a bad defrost thermostat, it allows current to pass through it at temperatures of 20 to 30 degrees Fahrenheit and prevents current from passing through it at 40 to 60 degrees. This is difficult to test, though, because it takes a prolonged, very-cold temperature to turn it on. The defrost thermostat is snapped onto the top portion of the evaporator. The thermostat sends temperature information to the processor. The defrost heater must be replaced when replacing the thermostat.
1. Remove the lower fan duct work from the evaporator cover.
2. Remove the 1/4-in. evaporator cover screws and remove the evaporator cover.
3. Disconnect the defrost thermostat wiring connector.
4. Remove the defrost thermostat from the evaporator.
Hope this helps...please post back for further assistance.
Daniel
Jul 17, 2011 | Refrigerators
Fridge is warm with no cold air.
Unless there are 2 thermostats, one for freezer and one for refrig, it's not the thermostat if the freezer is ok. Sounds like the small fan that blows the cold air from freezer into refrig is not operating.
Jul 23, 2010 | Refrigerators
Freezer Cold Fridge not cold, vents clear of obstructions. Vent at top left of fridge making a clicking sound, some cold air coming out of vent, probably not enough,Freezer control on 2 ,Fridge control on...
Need to defrost fridge completely for about a day then switch on again. Possibly door was left ajar on freezer, or auger motor iced up due to product being to close to outlet..
Sep 21, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator not working but freezer is
You have two vents between the freezer and fridge. The one the cold air from the freezer comes through(blown by the fan) and the other vent is a return vent back to the freezer. On a side/side they're at the top and bottom. It sounds like the bottom one may be blocked by food or frosted closed by ice.
Aug 22, 2009 | Refrigerators
Odd sound from freezer area
If it is still under extended warranty I would have a service call made. It sounds like the dc motor on the circulating fan is starting to ware out.
Jul 14, 2009 | GE Americana 15.6 Cu. Ft. Top-Freezer...
Leak in fridge from between fridge roof and freezer, fridge is still cold as is freezer however will not stop leaking
Hi, The drain hole located in the freezer defrost drain is plugged. Get me your model # and I can assist you further.
THanks
Vic
May 17, 2009 | Refrigerators
Haier HRF10 Fridge weird motor sounds
hi. thanks for the question. leaving the door open ,would let a lot of moisture to enter the freezer, and cause it to frost up. to clear frost. cut power to fridge, open the doors .,let thaw over nite clean up the water mess. dry the inside of fridge & freezer turn power on good to go. to stop the door from being left open .lift the legs under the front so the fridge has more weight, and it will close by self . no more doors left open. thanks the appliance doc
Sep 28, 2008 | Refrigerators
Fridge and freezer not cold
It happenedn to my performa fridge just yesterday. It was bought in 2005. Now there is humming and clicking sound from the lower back side once in a while and the fridge is not cold. the compressor is hot/warm and it seems to be where the noise is coming from.
Jun 21, 2008 | Maytag Performa PAV2200
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
75 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
