Question about GE Profile¿ 26.5 Cu. Ft. Stainless Side-by-Side Refrigerator with Icemaker, PSS27SGRSS
I have a GE side by side refrigerator model # PSS26SGRD and the water and ice dispenser stops working without any warning or symptom intermintently. It will be working find for days or weeks and suddenly stop dispensing either water or ice. Frig is 3 years old approximately and problem started occuring about two months ago.
Well, the solution to this problem was posted in this thread
http://www.fixya.com/support/t1295372-ge_profile_ref_ice_despenser_motor_not
It seems that the bulb in the front panel is pulling to much current as it ages and it makes the control panel in not work properly. Removing the bulb will fix the problem - just fixed mine.
Also seems to match your symptoms (works sometimes and then not others - bulb current is inconstent, light dims when dispense lever pressed - again wrong current draw).
Good luck
Posted on Apr 19, 2009
I have the exact same problem with mine. Ice/water dispenser operates intermittently and sometimes light is dim, correct? Something may be aging in the control circuit but I don't believe that it is the bulb. An aging incandescent bulb would have a higher resistance and therefore would draw less current. I'm thinking that removing the bulb may alleviate some of the current draw on the power supply circuit for the control board but will replacing it fix it? Anyone done this and has this worked for a long period of time?
Thanks to all.
Gerry
Posted on Jan 25, 2010
    Habit-Forming:
  • 41 Answers
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Posted on Dec 07, 2008
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE Fridge PSS26SGRD has a moaning howling
The fan is hitting on ice buildup...unit is not defrosting...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 12, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water and Ice dispenser quit functioning
the solution to this problem is so simple it makes me laaugh out loud. the bulb in the door that illuminates when a glass is placed under the water dispenser draws too much current when it gets old. just remove the bulb and it will work fine. you can then replace the bulb whenever you find it at a hardware store. I had the same problem, and spent hours online looking and was ready to buy a new motherboard to fix it. I have alot of faith in GE, and all of the bashing is a horse ****. GE makes turbine engines that power alot of the airplanes we fly in and i think they know a thing or two about engineering.
Jun 10, 2009 | GE Profile¿ 26.5 Cu. Ft. Stainless...
Ice maker dispenses ice without anyone pushing button.
Possible fault with the electrical connector at the bottom of the door as these can corrode or the microswitch behind the paddle has got jammed , try pulling the paddle forward a little . You should hear the switch click when you push the paddle back .
Mar 05, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water Dispenser works intermintently, Ice dispenser never works
Called GE Service Dept. My refrigerator was way out of the warrant period. They came out and replaced the main circuit board at NO CHARGE.
Jan 12, 2009 | GE PSW26SGRSS Side by Side Refrigerator
In door ice dispenser does not work but the water dispenser does.
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
Nov 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
PSS26SGRD GE side by side
could be just the board on the dispenser only. not the main board or mother board.
just a little bit hard to replace because of the problem on how to open the front dispenser.
tnx 4 using fixya,
drcool
Oct 21, 2008 | GE Profile¿ 26.5 Cu. Ft. Stainless...
GE Arctica (PSS26NGSB) ice and water dispenser
need to call ge at 1800-386-1215 some of these sxs have a door insulation issue that they will either send replacement doors to an authorized service company to exchange at no cost to you or offer a rebate for a newer model. yours might be in this group
have your model and serial number out of the ref located in the refrigerator section, about 4-5 inches from the celing down the right side and call and see
Apr 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile¿ 26.5 Cu. Ft. Stainless Side-by-Side Refrigerator with Icemaker, PSS27SGRSS Logo
538 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
