Question about Microsoft Windows XP Professional
LSASS "Unable to Load Component" Error
My computer went out when there was a power circuit overload that tripped the breaker. After that windows gave an error "LSASS - Unable to Load Component ?????" error. I should have ran the System File Checker as everyone in Google recommends, but where I was I didn't have an internet connection to look it up. I started the Windows XP in-place reinstall instead, but now when Windows Setup loads it gives the same LSASS error except it doesn't mention any file, it merely says "lsass.exe: unable to load component" at the top of the error window, and the dialog says, sic: "the application has failed to start because." No matter what I do, it will keep popping up.
  • 2 more comments
  • Justin Goldberg Dec 07, 2008
    Also Windows Setup won't complete, it just reboots the computer.
    Spinrite did find a bad sector, so I will try a new reinstall in the meantime.
  • Justin Goldberg Dec 11, 2008
    the only problem is that a format of any kind will reset the registry and all my program settings. Perhaps I should image the drive, then reinstall (eg an inplace reinstall) then copy the old filesystem over the new install except the registries SECURITY file. It can't hurt, and will be less work than doing a complete bare metal format, reinstalling all the old programs, etc....
  • Justin Goldberg Jan 30, 2010
    okay, I have this exact same problem again, except I am putting a hard-drive into another computer because the old motherboard has bad capacitors. Upon attempting the in-place reinstall I get the xp pro setup lsass unable to locate component error dialog. I don't know what to do. Microsoft recommends replacing the ntdsapi.dll file within windows, but this isn't a problem, it's a re-install problem. I've heard that you need to replace the hdc ide drivers and also something about replacing the HAL, but afaik there's no way to do it other than the reinstall, besides starting over from scratch.
    Scholar:
  • 111 Answers
I think because of the power failure, some parts in your hard drive are broken, bad sector may be.
So, when reinstalling, I suggest you to do full format, not a quick format. That way, the installation will recognize the place where bad sector is located, and will not put anything at that place.
Can not load component, usually because windows can not read from the disk.
Posted on Dec 08, 2008
Outlets not working all fuses are good
120-
VOLT
AC
SYSTEM
The following electrical components (if so equipped) will only operate when your
RV is connected to shore power: 120 to
12-volt power converter, air conditioner,
120-volt refrigerator, microwave oven, television(s), fireplace and appliances
plugged into convenience receptacles.
SECTION 6 - ELECTRICAL SYSTEM JAYCO TOWABLE
6-2
120-
VOLT
CIRCUIT
BREAKERS
The 120-volt AC circuit breakers located in
side the main load center protect all
120-volt wiring and components in the RV fr
om circuit overloads and short circuits.
Should a circuit overload or short circui
t occur the circuit breaker protecting the
affected circuit will "trip" preventing the flow of electricity through that circuit.
If a circuit breaker trips, shut "off"
the appliance on that circuit (i.e., power
converter etc.) and allow the circuit breaker to cool down for a brief period of time.
After the cooling down period, reset the circuit breaker by moving its lever "off" and
then back to the "on" position. If the circuit breaker re-trips or frequently trips,
contact your dealer to have the electrical problem diagnosed and repaired.
A circuit breaker identification label is permanently attached to the inside surface
of the 120-volt load center.
Maintenance and Replacement
At the beginning of camping season, inspect the circuit breakers and replace as
needed. Test by turning each circuit breaker "off" and back "on". Circuit breakers
are wearable parts and must be replaced
as needed, as part of your RV
maintenance. If you have any questions, consult your dealer.
Please contact your dealer for repair assistance when replacing circuit breakers.
CONVERTER
The power converter converts 120-volt AC power to useable 12-volt DC power
when the shore power cord is connected to an external power source.
The converter has a built-in protective thermal breaker that will shut it down should
overheating occur. Overheating can be
caused by operating the converter above
its maximum power output for an extended period of time, or by an obstruction to
its ventilation air flow. To reduce converter heat build keep unnecessary 12-volt
lights and motors turned "off"
Keep the converter cooling fins and fan clear of
obstructions.
Inspection and maintenance
If the 12-volt power converter is not working (auxiliary battery not being charged)
check the reverse polarity fuse(s) in the converter fuse panel.
There are no
customer serviceable parts inside the converter case and the
manufacturer's warranty will be void if
the case has been removed
. If you
have further concerns contact your dealer.
Nov 16, 2014 | Jayco 2013 Jay Flight Swift 264BH
Volvo Penta Marine engine 5.0 GXI 2004
there should be some loose connection or short circut, that is the only thing that can cause it.
Sep 23, 2008 | 2004 Volvo V50
My fridge keeps tripping the power
Your solution is one of two things.
First is the circuit you have plugged the refrigerator is either over its limit and the breaker is tripping because it is overloaded. In this case you will have to determine what load also share this circuit and eliminate the extra loads or move the cord to another circuit which is not overloaded. Most home circuit are wired with 14 gauge and is rated at 15 amps. When the circuit gets to 15 amp and more, the associated breaker trips to prevent overload.
Second, Your refrigerator may have a short and needs troubleshooting to find the cause. To see if it is a bad circuit try plugging into a circuit via extension cord to circuit in another room receptical. The reason I say another room, when electrical installers wire circuits, you can put several recepticles on the same circuit. If you plug your refrigerator in the same circuit you had it on before then you will get the same problem, your refrigerator tripping again. If your frig trips on a different circuit then troubleshooting the cause will normally require a tech.
Good luck and hope this helps.
Oct 28, 2014 | Refrigerators
No lights upstaires circuit breaker keeps tripping
Jan 2013
1) Move wire to another same-size circuit breaker to eliminate bad circuit breaker as suspect.
Do NOT increase size of breaker or it will cause fire.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
http://waterheatertimer.org/Troubleshoot-household-electricity.html
2) Put hand on each appliance and outlet to see which ones are warm. Outlet should never be warm or hot. Replace outlet. Inspect wires for loose and burned connections.
3) If the breaker is good, then add up total watts being used by checking watt rating on each device. 100 watt light bulb is 100 watts. Big screen TV has a label that shows 300 to 500 watts. Computer has label. Space heater has label showing 1500 watts. Iron has a watt rating label. Take total watts and divide by 110Volts and this will give amp load. Total watts used = 2000 and then divide 2000 by 110 volts = 18.8 amps
Compare amp load with circuit breaker.
20 amp circuit breaker has 80% safe maximum, or 16 amps.
If amp load is 18.8 amps, then 20 amp breaker is starting to get hot, and weak breaker will start tripping.
If amp load is 18.8 amps, and breaker is 15 amps, then you are overloaded and breaker is feeling the heat, and tripping because of heat.
Solution is to reduce amp load.
4) If you have short circuit, that can also trip breaker.
Unplug everything and then plug things back in slowly to see which plug or appliance is causing the problem.
Jan 18, 2013 | Electrical Supplies
GE electrical house breakers keep tripping. Any problems or recalls
You may have overload that power circuit with too many appliances.
Check the load of each of the appliances on that power circuit, add them together and check to see that it does not exceed the rating of the circuit breaker.
OR
You have an overload or short/fault on an appliance on the power circuit that is protected by that circuit breaker.
To identify the faulty appliance, disconnect all the appliances on that circuit and then connect each appliance one at a time to see when the circuit breaker trips out. When that happens you have identified the faulty appliance.
Jan 21, 2012 | GE Hammering
Main breaker doesnt stay turned on
Tripping of the main breaker could be an indication of a short or an overload. To check for an overload you will need an amprobe to test the amperage load on the breaker. Turn all the secondary breakers off. Attach the amprobe by clamping it around one power wire. Turn the breakers on one at a time and check the reading of the amprobe. Most breakers will handle about 80 % of the breaker rating before tripping. If it trips below this point the breaker may be weak and will need to be replaced. If the amprobe pegs out at any time and the breaker trips the secondary breaker that was last turned on probably has a short in its wiring somewhere. Cuasing the breaker to trip. Underground wirng that has gone bad can sometimes take a while to trip the breakers so if there is any underground feeders it may be more difficult to track down a short. If the problem is an overload check both hot wire to see if the load is equal if the load is a lot higher on one leg than the other switching some circuits to the lower side may help. If the total load is just too high you may have to increase your service to a larger size. Hope -this helps
Bob
Nov 04, 2011 | Cutler Hammer 100 Amp Main Breaker...
Breaker installed on generator. Keeps tripping under no load after approx. 1 minute of generator running
A tripping circuit breaker is an indication of an overload. You say there is no load on the breaker - how are you making this determination? Are you using an amprobe or some other meter?
A circuit breaker with NO load shouldn't ever trip. Likewise a circuit breaker carrying up to 80% of of the current it is rated for shouldn't trip either. Circuit breakers that carry more than 80% of their load will trip - if the load remains connected long enough. This is called "duty factor" or "service factor" The greater the load is in excess of 80%, the less time that the breaker will carry it before tripping.
An example of a 100 amp breaker with different loads on it (this 100 amp value was chosen for ease of doing the math):
80 amps - never trips
85 amps - trips after 48 hours
90 amps - trips after 16 hours
95 amps - trips after 8 hours
100 amps - trips after 4 hours
105 amps - trips after a few minutes
120 amps - trips after a few seconds
150 amps - trips instantly
This is only an example to show how a certain circuit breaker might trip under a load less than the rating stamped on the body or handle.
A circuit breaker that trips with no load or a load equal to or less than 80% of its rating is most likely defective. You need an amprobe or ammeter for amp readings. If the load is found to be 80% or less, there may be an issue of harmonics that is causing the tripping. You'll need to have special equipment and qualified persons to check harmonic problems. Most harmonic problems occur when the loads are not linear device (transformers). Examples of non-linear devices are "switching" (or solid state) power supplies like those in computers.
I hope this helps and good luck. Please rate my reply. Thank you.
Apr 07, 2011 | GE Tjk436f000 3pole 400a 600vac Circuit...
Is there a way to safely load test a breaker to make sure it will trip correctly
Short of using expensive load test equipment about all one can do is purposely overload the circuit. Usually 2 heavy loads will do it for a 20 amp circuit, such as 2 microwaves or a toaster oven. Turn both on at the same time and it won't take long for the breaker to trip. If the breaker trips on overload it will trip on short circuit, so, DO NOT purposely short circuit the breaker as that is a lot of unneccessary wear and tear on the breaker.
Dec 14, 2010 | Hammering
I have a 1995 Buick Century that out of the blue last night, the dash lights, headlights, radio, and dome light quit working. Today I checked the fuses, unplugged the battery to reset the ECM, and fished...
There could be a timed circuit breaker:
Circuit Breakers The headlights are protected by a circuit breaker in the headlamp switch. If the circuit breaker trips, the headlights will either flash on and off, or stay off altogether. The circuit breaker rests automatically after the overload is removed. The windshield wipers are also protected by a circuit breaker. If the motor overheats, the circuit breaker will trip, remaining off until the motor cools or the overload is removed. One common cause of overheating is operation of the wipers in heavy snow. The circuit breakers for the power door locks and power windows are located in the fuse box.
Oct 13, 2010 | 1995 Buick Century
Lsass.exe-Unable to locae component
Boot from your WinXP CD and repair your existing installation. That is the component that controls security on your computer. When done with the repair and you can boot into your operating system again, you should do a full virus scan on the computer since there are several viruses that can cause this problem.
Apr 12, 2009 | HP Compaq Presario V2000 Notebook
Microsoft Windows XP Professional Logo
171 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
