The Mazda MPV is 2005 dx with a v6 engine and I think a 3.0 litre.
YES
Mazda MPV 1999-06 Fig. Never bend or twist a timing belt excessively, and do not allow solvents, antifreeze, gasoline, acid or oil to come into contact with the belt
Timing Belt
General Information
Interference Engines
Engines, chain- or belt-driven, can be classified as either free-running or interference, depending on what would happen if the piston-to-valve timing is disrupted. A free-running engine is designed with enough clearance between the pistons and valves to allow the crankshaft to rotate (pistons still moving) while the camshaft stays in one position (several valves fully open). If this condition occurs normally, no internal engine damage will result. In an interference engine, there is not enough clearance between the pistons and valves to allow the crankshaft to turn without the camshaft being in time.
An interference engine can suffer extensive internal damage if a timing belt fails. The piston design does not allow clearance for the valve to be fully open and the piston to be at the top of its stroke. If the belt fails, the piston will collide with the valve and will bend or break the valve, damage the piston, and/or bend a connecting rod. When this type of failure occurs, the engine will need to be replaced or disassembled for further internal inspection; either choice costing many times that of replacing the timing belt.
Inspection
NOTE
For manufacturer-s recommended service interval, refer to the maintenance interval chart located in this manual.
The average replacement interval for a timing belt is approximately 60,000 miles (96,000 km). If, however, the timing belt is inspected earlier or more frequently than suggested, and shows signs of wear or defects, the belt should be replaced at that time.
WARNING
Never allow antifreeze, oil or solvents to come into with a timing belt. If this occurs immediately wash the solution from the timing belt. Also, never excessive bend or twist the timing belt; this can damage the belt so that its lifetime is severely shortened.
Inspect both sides of the timing belt. Replace the belt with a new one if any of the following conditions exist:
Hardening of the rubber-back side is glossy without resilience and leaves no indentation when pressed with a fingernail
Cracks on the rubber backing
Cracks or peeling of the canvas backing
Cracks on rib root
Cracks on belt sides
Missing teeth or chunks of teeth
AbnDoes my 2005 mazda mpv have a timimg belt or chain - 0996b43f8022cdaa.jpgides-the sides are normal if they are sharp, as if cut by a knife.
Fig. Clean the timing belt before inspection so that imperfections or defects are easier to recognize
Fig. Inspect the timing belt for damage, such as a broken or missing tooth, which may be dDoes my 2005 mazda mpv have a timimg belt or chain - enlarge_icon.gifpulley
Does my 2005 mazda mpv have a timimg belt or chain - enlarge_tooltip.gifuploads/images/0996b43f802095a7.jpg" alt="0996b43f802095a7.jpg" class="h_mi" />
Fig. Back surface worn or cracked from a possible overheated engine or interfeDoes my 2005 mazda mpv have a timimg belt or chain - 0996b43f802095a9.jpgcover
Fig. Side wear from improper installation or a defective pulley plate
Fig. Worn teeth from excessive belt tension, camshaft or distributor not turning properly, or fluid leaking on the belt
If none of these conditions exist, the belt does not need replacement unless it is at the recommended interval. The belt MUST be replaced at the recommended interval.
WARNING
On interference engines, it is very important to replace the timing belt at the recommended intervals, otherwise expensive engine damage will likely result if the belt fails.
SOURCE: 1997 Mazda MPV, 3-Ltr. V6, destroys Timing Belt
i need help install a timebelt in a mazda mpv? please help me out
SOURCE: Where can i find a belt diagram for a 1994 mazda
here is a link to the pdf catalog of all belt diagrams, it is huge file so allow time to load
http://www.daycoproducts.com/daycoweb.nsf/cf652a4feb630ad0862571a4005ae40c/1120b6e8f406fd3e862574c000569a91/$FILE/SerpentineBeltRoutingGuide.pdf
