Question about Protron PLTV-4250 42 in. LCD Television
Pltv-4250 post I saw your post on repairing the 4250, I need to replace the power plug on mine, but I can't seem to figure out how to get the back cover off. All screws are out, base is removed, but something is holding it still, any suggestions? Procedures? Thanks
  • D B Jan 18, 2009
    I have the PLTV 42 inch and amg new to Fixya, my TV is having the power issue also. Power light turns on green then red, sometimes orange. Could you send or direct me to the link to that post on how to fix the problem.
    Much appreciated
    Sergeant:
    Champion:
  • 267 Answers
YOU NEED TO INSERT A FLAT BLADE SCREW DRIVER BETWEEN THE PIECES AT THE TOP OR BOTTOM EDGES. THERE IS A LITTLE EDGE ON THE INSIDE OF ONE PIECE AND A SLOT ON THE OTHER PIECE THAT LOCK THE 2 PIECES TOGETHER. EVERY 4 TO 5 INCHES THERE IS ANOTHER LITTLE LOCK PIECE.
Posted on Jan 16, 2009
  • Anthony Gonzales Jan 22, 2009
    PEOPLE, IF YOU SET IS NOT TURNING ON BUT THE LED COMES ON, IT IS NOT YOUR POWER PLUG. YOU HAVE A BAD BOARD INTERNALLY. A SERVICER IS REQUIRED TO DETERMINE WHICH BOARD TO REPLACE.
Protron pltv 4250 keeps shuting off
Main digital board should be checked. In most case, might need replacement. Contact any service technician.
Jun 27, 2013 | Protron PLTV-4250 42 in. LCD Television
I need a stand for 42
Hello.....Try this link....http://www.retechtv.com/products/protron-pltv-4250-tabletop-base-pedestal-stand.....They may have the replacement for you.....I hope this was helpful.....PEACE....
Feb 08, 2012 | Protron PLTV-4250 42 in. LCD Television
My protron pltv-4250 won't turn on. it was working fine and then it just wouldn't turn on. I unplugged it and waited for a while and tried again, but no luck. any ideas?
The power supply boards are known for having swelled capacitors and may not allow the set to start up.......these can be replaced by an experienced tech reasonable cost. If the entire board needs replacement,they are difficult to find........just to be safe..be sure the master power switch is on located near the power receptacle too!!
Jun 02, 2010 | Protron PLTV-4250 42 in. LCD Television
Protron PLTV 42 IN issue
I have had the same problem off and on since I purchased my protron 42" lcd. I have found that if I hold the power button to the tv a little longer, I rarely have the problem. Hope this helps.
Jan 22, 2009 | Protron PLTV-4250 42 in. LCD Television
Protron flat screen tv
Protron PLTV 4250- wont turn on-
Had the same problem with one here- The 110v end of the power supply board was found damaged, The following items may need to be replaced:
Fuse F1 (soldered in) . 6.5a @250v time delay
Mouser 576- 021506.3HXP – note this style is for a fuse holder instead of solder in- I added a fuse holder on the board
RT4 & RT5 inrush surge suppressors - I used shintron 8d-18 power suppressing thermistors
BD1 bridge rectifier - Mouser 627-D15 XB 60H Shindengen
If you want a little more protection modify the board as follows:
1.replace only RT5 in its original location & move RT4 into the other ac input line in front of the bridge rectifier. (cut trace & drill solder holes)
2. Add: MOV (metal oxide varistor) across ac inputs of bridge rectifier.
Maida mdc-z481-8oul or D69 ZOV 481 RA 105
This arrangment is copied from a samsung power supply.
Be careful when plugging in the I/O box on the outside cover, if any pins are inadvertantly bend loss of picture will result.
I have pics if anyone needs them
Oct 25, 2008 | Protron PLTV-4250 42 in. LCD Television
Protron Pltv-4250 42 Widescreen HDTV LCD TV NO SOUND
Try disconnecting from power for 30 mins and connecting back
Apr 05, 2008 | Protron PLTV-4250 42 in. LCD Television
HDMI connection
A downloadable copy of the manual for a Protron PLTV-4250 is available here.
I went through it to check up on your concern. It was mention in page 34.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Protron > PLTV-4250
Feb 13, 2008 | Protron PLTV-4250 42 in. LCD Television
Protron PLTV-3250 fried
remove pwr board--inspect and you will find a heavy current diode which has eatin its solder pad area--if diode checks ok,repair it's connection.Install board and hook back up.Check for shorts in circuit.Cross fingers and plug her up------good luck
Jan 26, 2008 | Protron PLTV3250 32 in. LCD Television
Protron PLTV-4250 42 in. LCD Television Logo
56 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
