Question about RCA HD52W59 HDTV Projection Television
Okay let me know what you think
Okay we put the last fuse in within an hour it blew. I asked my husband you did solder the fly back. He said yes. Okay, just because I myself don't have a clue what the fly back is. I'm assuming it's the two wires attached to the fuse? Okay, back to my problem. Last fuse blew so I mentioned someone else on this site jumped it so we tried that. Everything started working fine then about an 1 1/2 later we lost sound. So we unplugged for the night. So today we turned it back on picture still fine, sound was available. After about an hour the TV started shutting itself off and on. Something is over heating. I refuse to give up on this TV, we have to be doing something wrong.
  • 1,030 Answers
The flyback transformer is the large black component simalar looking to a disrtibitor of a car it has a large red wire coming out of top and a black wire. On the bottom of the board it has about 10 pins arranged in a circle. this is flyback is located adjacent to the fuse.
Posted on Dec 07, 2008
How do I remove the main fuse in an 02 Suzuki Grand Vitari XL7?
Sparks do fly, the last connection on the cables is ground
to a metal , on engine not battery,
this will make a small, spark. all do, that. done right.
but if done backwards, a huge spark with the 2 batteries bucking each other, and damage will happen.!
yes you may blow the main fuses,
my guess you blew the 80amp fuse in the main fuse box under hood.
did you put the new battery in correctly Plus to PLUS
and NEG to NEG lugs, if not, BOOM AGAIN.
open hood,
fuse 1, if it ok, then the others fuse to the right blew.
when fuse 1 blows, all things die. zero power to anything in car
including head lights, (head lights are always the first check)
Nov 17, 2016 | 2002 Suzuki Grand Vitara
Blew fuse in survellience camea
Yes. There's a fuse inside soldered to the circuit board
Jan 14, 2014 | Home Security
Could a bad ground be causing my turn signals and blower motor fuses to be burning out?
short in one of the bulb sockets for the backup lights is the most likely cause, water getting into the light is another. the only other thing i can think of is if there is a short in the neutral safety switch.
Oct 11, 2012 | 1997 Plymouth Voyager
I can't find auto converge choice in menu of rca 52" rear projection tv.model # R 52 WH 74.
You have 3 pico fuses by your fly-back transformer. One of them blew that controls your convergence circuit. Your TV now thinks that it is a Basic CRT set with 1 tube. Find the bad fuse and replace with a 1/2 amp pico fuse, and re-solder all the pins of your fly-back transformer. Your menu should have the convergence option again.
Apr 27, 2011 | RCA HD52W59 HDTV Projection Television
Fuse on control module blows when calling for cooling
Disconnect the the red and the yellow wires at the outdoor unit. Then replace the fuse and turn on the power.......see if the fuse blew. If the fuse blew, your problem is most likely a short in the low voltage wiring. Check for crimped or damage wire or wire insulation and repair as necessary. If the fuse is okay, then the problem is within your outdoor unit.......again inspect all wiring for any damaged insulation or crimped wiring.
Check these items and let us know.....we can guide you further after you perform these checks. :-)
May 26, 2010 | Goodman CLQ36AR49 Air Conditioner
Convergance is off
I have an RCA 52” HDTV Model R52WM24 the other day it developed a convergence problem (The picture took on a 3D effect and it the screen had an hour glass type of shape)
This appears to be a common problem or a pattern failure.
I wanted to confirm that I did find the fuse p/n FL231 to be blown.
I think it said the RCA part # is 259213 and it is a 400 ma, 125V fuse, Looks like a square capacitor by the fly back xfmr.
I bought a generic part from Digi Key and it seems to be the identical replacement part to the fuse that was in the circuit.
The Digi-Key part is part # WK4440BK-ND (99 CENTS EACH).
THIS IS A 125V, 400 MA ( 0.4 A FUSE). Digi Key PHONE # IS 1-800-344-4539
I am watching the TV right now for last 3 hours and it seems to be a good fix.
The fly back transformer solder connections looked good but it is recommended to re solder these part ( so I did).
Good luck
Dec 27, 2009 | RCA R52WM24 52" HDTV Projection Television
Our TV picture is bowed inward and lettering is 3D. How do we fix this problem?
Go to Menu then to setup if you do not see Convergence in the menu then you have a blowed Fuse FL231 it will be on right hand side of FBT flyback Transfomer there is 3 in a roll it will be the Middle one they are small brown rectrangler Looking caps but are Fuses Located on the Deflection board Bottom Left hand Board.
Dec 24, 2009 | RCA Televison & Video
Hi, thank you for visit fix ya.
Common problem on this tv, Loose connections-and open fuse.
Re solder all connections around fly back, and replace a little fuse located beside fly back ( is a little brown box), you will See 3 fuses parallel beside fly back; replace fuse 400ma.
Thank you
Jul 28, 2009 | Televison & Video
Rca 52wh73 i replaced the fuse for the convergence and it worked for 2 days. then blew again i replaced the fuse again , now there is no power it wont turn on
your initial problem was the fuse blowing. this is usually caused by bad solder connections on fly back transformer. resolder to solve blown fuse for convergence problem. now for no power check horizontal-output transistor for short. if unit tries to cycle off&on fly back is defective. if no start-up, check capacior in 6v-line center of deflection module in-between heat sink, the top will be raised up . 2200uf/25v replace mch
Mar 09, 2009 | RCA R52WH73 Projection Television
Hd52w59 - Me again....
sorry havent got back got some personal issue going on. So its cycling off. my fist instinct is to check the ribbion cables that go between boards. and most connectors. theres a cable that runs from the back green booard to the front center crt board in the front. this could be a problem. does the set make any noises?
Dec 28, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
51 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
