Lots of black smoke when accelerating, but computor saying 44.5mpg around town
SOURCE: black smoke from exhaust
This is almost certainly a split hose - mine was the large hose coming out of the bottom of the EGR valve.
Speaking to a parts guy at my local Jaguar dealer, he said that the new part is uprated as Jaguar are aware that this is a problem.
The split allows more air in and results in the ECU changing the mixture and over fuelling - Black smoke is an indication of un-burnt Diesel. As well as the black smoke you may also notice a whistle/whine or sucking noise when you accelerate and a lack of power / lumpiness at around 2000rpm.
Hope that helps!
Graham
SOURCE: white smoke coming from exhaust when accelerating
This is usually an indication of a bad head gasket.I gasket. The white smoke is the coolant leaking out of the engine and winding up in the oil passages, due to a bad head gasket. To confirm this,
1. check oil. Is level increased, or milky appearance?
2. Is coolant level dropping, but u don't see any signs of leaks?
The above indicates a bad head gasket, causing the white smoke u describe. Let me know how u make out.
SOURCE: 2006 VW tdi black smoke while accelerating
Hi
The only sensible way forward is to get a list of fault codes from the onboard diagnostic system and take it from there. You could either go to a VW dealer, or if you are technically minded you could buy a £15 interface cable, download some free "VAG diagnostic software" and run it on a portable computer.
There are lots of possible reasons for the problem and guessing will not really help. If these suggestions turn out to be sound, please give my reply a "Fixya!"rating, If they do not, please hold off rating and add a comment with more details so I can try to help you further. Cheers, D
SOURCE: 2001 Mercedes E220 CDI exhaust black smoke on acceleration
hello,according to service information;smoke formation or si 07.16-p-0004a (service inform) from mb ,your engine have normal function,if you want ,ask your dealer about the service inform with number 07.16-p-0004a,you can read the explanation regarding your problem,ty
SOURCE: mk3 mondeo,diesel,lack of power
try your MAF which is on the intake pipe with the black box that is screwed down the sensor gets dirty and doesnt read as it should.There is a how to remove and clean on utube with an older mondeo try that
black smoke when accelerating gently from low revs, no power loss, infact really quick for 115 bhp. good mpg according to computor
