Question about Kenmore 23822 Top Load Washer
Kenmore 110 washer does not agitate motor was replaced a few month ago
  • 91 Answers
There are small pcs called dogs run about 10 .00 at parts sotres they are inside agitator
Posted on Jan 04, 2009
Help! I replaced the clutch and motor coupling a month ago. Ran great till this week. The wife washed tennis shoes, it quit agitating and spinning-i could hear the motor running fine. I again replaced the...
Have you checked for any damage on the lid switch at all? Washers won't engage the cycle you're having issues with if the lid switch is faulty. usually a magnet or plastic piece that pushes down the piece to engage agitation.
Sep 21, 2017 | Kenmore 22622 Top Load Washer
Kenmore agitates doenst spin
You will have to look at the inside of the washer when in spin cycle to see what is going on. Is the spinner motor not engaging the drum? Is the spinner working at all? It sounds like the spinner isn't being moved against the drum before the spin cycle starts. Most washers use a seperate spinner motor, which is lifted off the drum by a relay and / or solenoid and if one or more of those is malfunctioning, it will cause your described problem.
Dec 22, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore washer wont agitate
i would look at your lid switch this could be faulty
Feb 23, 2010 | Kenmore 22422 Top Load Washer
Washing machine operates sporadially
What made you replace the motor? Sounds also like a transmission problem. You motor reversing in spin but gears for agitate stripped in gearbox. Double check motor/coupling alignment. Pull the motor back off and turn the gearbox drive shaft both directions. One direction makes the basket turn, the other direction makes the agitator turn. If the agitator does not move, the gear case is bad.
Feb 17, 2010 | Washing Machines
Kenmore Model 110 washer humming/popping breaker
Good day,
Anytime an appliance knocks a breaker down, the motor is the obvious culpret.
The first thing to do is remove the motor and take it to an appliance parts house for testing.
If the coupling broke, it is just sometimes just happenstance. In other cases it could be a transmission starting to lock up, which would overtax the motor, and eventually cause it to fail.
Lastley, most models are 2 or three speed. If the timer screws up and tries to run the motor on high and medium or low at the same time it will fry the motor.
Dec 10, 2009 | Kenmore Washing Machines
I have a Kenmore top loading washer model #110 and won't agitate
First, see the Sears parts site for your washer.!retrieve.pd?pop=true&modelNumber=110.23912100
Also see the Whirlpool (Kenmore) Service Manual for top load, direct drive washers.$FILE/L-55.pdf
The first thing I'd try is using a different cycle. If the washer works as it should, the problem points to the timer.
I'd also check to make sure that when replacing the switch, the connections to the timer haven't come loose.
Since you've replaced the Lid Switch, the motor has power for the drain and spin cycles.
These washers use a reversing motor. The motor turns one way for agitating and reverses for the drain and spin.
Since you cannot hear anything when it is supposed to be agitating, the problem does point to the timer or motor.
Nov 14, 2009 | Kenmore 22422 Top Load Washer
Rubber coupling is getting shreddedprevents agitator from working
no it's not a recurring problem. Q. Can you spin the agitator freely in both directions when the machine is off? Please post the entire model number 110 is just the first 3 didits.
Apr 11, 2009 | Washing Machines
Washer will not agitate
if only the lower part of the agitator is moving, then you need to replace the agitator dogs, if lower agitator is not working then it is a prob with your gear case.
Dec 07, 2008 | Kenmore 23822 Top Load Washer
Agitator problem
Check to make sure connection by motor are good sometimes one phase of the motor will go bad that might be the case try the selector switch for agitator speed on different settings
Jul 11, 2007 | Kenmore 24032\24036 Top Load Washer
blaker, check the lid switch, no spin, no drain, usually a broken lid back.
Sep 15, 2006 | Kenmore 23012 Top Load Washer
Kenmore 23822 Top Load Washer Logo
85 people viewed this question
Sal De
 Brian Main
Brian Main
