Question about HP Officejet 4110 All-In-One InkJet Printer
Won't print the document
It doesn't seem like there is a connection and the printer doesn't print. The document is in "queue" but there is no activity
    President:
  • HP Master
  • 990 Answers
1, make sure this printer connect with your computer
2,do you down load the driver.
3, follow the instruction on screen to finish installation
Posted on Dec 07, 2008
Dell v515 printer
Several immediate things come to mind; check to make sure that the printer drivers are up-to-date; there maybe a possibility of an IRQ conflict; check to make sure that the printer is set as the default printer in control panel; make sure that the printer you want to print from in the <file>, <print> menus screen is selected and not a virtual one. Absent more info like OS and how your printer is connected to your computer (e.g., is it through a serial cable, then make sure com port is active in BIOS and is checked off in the properties menu [control panel, printer, properties, port tab]; or are you using an LPT-printer port or USB connection- make the same check. Sorry that I can't be more specific without additional info.
Nov 22, 2013 | Office Equipment & Supplies
HP LaserJet 4100 for all applications in windows 7. When I go to print a document and click on print. The print screen exits, the print job doesn't processes, and the print queue stays empty. Noth
Ideas? Yes. I had this happen on an LJ 1000 while trying to print my tax return. I tried emptying the queue, removing power from the printer, etc, etc. What finally worked was to empty the queue (again), disconnect power from the printer, shut down the computer, plug in the printer again, restart the computer, queue up a print job again, and hit PRINT.
Hope this works for you
Apr 11, 2013 | HP LaserJet 4100 Printer
HP Photosmart Plus 209a-m doc in queue won't delete
using windows explorer, go into windows/system/spool/printers and erase contents in last item
Sep 14, 2017 | HP PHOTOSMART PLUS B209A All-In-One...
I have a document stuck in the print queue, which won't cancel or restart, help!
Turn off printer for 2 minutes @ least, turn back on, or delete printer and re-install printer. Go to HPsupport website enter your printer model info update drivers.
Jan 28, 2012 | HP PSC 1510 All-In-One InkJet Printer
As soon as you turn on my printer it already wants to print what i have printed previously how do i stop that from happening
You need to clear the print queue from the (any) workstation that is printing to it.
  • go to Control Panel/Printers
  • Open the printer in question
  • highlight any documents awaiting print
  • press 'delete'
The documents may not all completely delete until the printer is turned back on.
If this doesn't fix it then please reply before rating this answer as I can detail a manual method of clearing the queue, but I recommend using the above process first.
Please take the time to rate this answer.
Many Thanks Don.
Sep 05, 2011 | HP DeskJet 932c InkJet Printer
My printer, HP 8500, has been trying to delete a document for hours with no apparent results. I am unable to print anything else although it does put a new document in queue. I do not get any error...
There are 2 simple methods to resolve any print job stuck in queue issue. However, both the methods will not fix printing issue if the HP Printer is in Error mode. Make sure your printer is able to print self test page to prove its functionality,
First method.
This Utility program resolve all the printing issue for HP Printers Only ( Network and USB connection )
This Utility will Resolve :
1. Check Connectivity between the Pc/laptop and HP Printer
2. Check if there any Documents stuck in Queue
3. Check if all the software/Drivers are correctly Installed
4. Check if the HP Printer icon is the default icon to print
5. Will Resolve Printer Spooler Issue and few more issue
Download the file on Desktop and Run the program ( Ex. File name = HPPDU.EXE )
Click Here to download the Utility and save on Desktop location
Run the HPPDU file and follow the instruction on screen to fix.
If this does not fix, try the 2nd Method given below ( this is manual process to clear the print job stuck in queue )
This works for all brands of printers ( HP, Canon, Epson, Brother etc )
Click Start > Programs > Accessories > then select Command prompt, then the black window will open and there type NET STOP SPOOLER and hit enter that will confirm service is stopped , after that on the black window type NET START SPOOLER and hit enter. Repeat this step 3-4 times and end the command with NET START SPOOLER and hit enter. Open the Printers folder and Refresh the Window ( Press F5 on the keyboard )
The service will be started and all print queue should already be remove.
// Above given solutions help in resolving print queue issue, however check the printer functionality if it is working fine ( the printer should be in working condition and should be able to print self test page, this utility cannot fix printer hardware issue //
Regards,
Ron
* Please rate this solution with Thumbs up and comment to help us improve providing support
Jul 02, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
When I click print the document goes into queue then when I troubleshoot it says the printer wont print because a document is in queue. When I clear all documents it says "printer ready" but then it says...
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken .
Sep 18, 2010 | Epson Office Equipment & Supplies
DOCUMENTS FOR PRINTING DON'T GO INTO A PRINT QUEUE
If you mean that when you go to print a document it doesn't hang in the Windows print queue and leaves quickly, then it is because either the printer has grabbed the document into its memory or it has sent the document to what it thinks it another printer. It might also be that the drivers you are using are not set correctly or that the connection to the printer is incorrect.
Jul 09, 2009 | Lexmark E232 Laser Printer
Document goes to the print queue, then errors
To start with You check the data cable is properly connected to your printer than you open the printer dialogue box and remove the documents pending in the queue and retstart the computer and before giving the print command select the printer that you are going to use(if more printers are connected to the computer).if all this does not work i suggest you to reinstall the printer after uninstalling it
May 27, 2009 | Office Equipment & Supplies
HP Officejet 4110 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
