Question about GE Interlogix Dvmre Pro 10 Channel Triplex Dvr with Cdrw
Unable to connect remotely to dvr unit
Error message unable to run direct x with current security setting
wave reader control could not be loaded
  • Anonymous Mar 18, 2009
    I can't seem to run the ActiveX either...even with the security settings changed.
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 14 Answers
I'm presuming you are using Internet Explorer. You may need to change your browser's security settings to solve this problem.
Using Internet Explorer, click on TOOLS, Internet Options, Security, Local Intranet, then move your slider all the way down to Low and click Apply.
Posted on Dec 28, 2008
I have an Eyemax DV-9060 that I am unable to remotely view from my iPhone 6. I currently have the DVR set to a fixed local IP of 10.0.1.13, and have my router (modem/router combo unit from Comcast)...
If you are setting this up as a static IP then you need to have the router IP address input into the DVR to allow it to pass through. You also need to have a gateway set up to allow incoming and outgoing signals to the host site.
Mar 23, 2015 | Gateway Computers & Internet
How to solve the error: please check the digia2.ocx installation. current version is 1.0.0.80. that apper when i try to connect to the GE DVR Digia2 remotly.
First you need to be using Internet explorer as your browser as it does not support anything else.
Second, temporarly reduce your security settings in the browser. You may need to manually customize the setting rather than using the preset slider bar. Low/Medium/High etc.
The software is trying to install itself using active x but I believe the software is unsigned and will not install unless you reduce the security settings in the browser accordingly.
You will need to click the custom section, then find the box that says "download UNSIGNED activeX controls and chose the "PROMPT" setting. Hit apply, ok then restart the browser and try to log in to the DVR again.
Once the software installs on the machine and you are able to log in, reset the security setting back to the default levels. (THIS IS IMPORTANT)
DONT LEAVE THAT SETTING OR YOU MAY BE EXTREMELY VULNERABLE TO VIRUS, BROWSER ****** and TROJANS!!!!!!
Aug 22, 2011 | General Electric GE Security Digia II DVR
Remote access to Digia II return error : Check Digia2.ecx installation. Current version is 1.0.1.0 Firmware on Digia II is 1.0.87
Go to: Controlpanel -> Internet Options -> Security (tab)... Chose ''internet'' and press the ''Costum levle'' button.. Set alle ''active X controls to ''(not secure)'' and press ok, and apply.. UNDO THESE SETTING ONES U HAVE INSTALLED THE ACTIVE X ADDON, FOR YOUR ONE SAFTY!
Jul 21, 2011 | General Electric GE Security Digia II DVR
I need access to manual for the Image Pro 8758. We are getting no picture output from Projector. currently using the component to 15pin VGA wiring. Which is connected to the Computer 2 input terminial on...
Try pushing the source button either on the projector or the remote. It will tell the projector to look for another source. It may currently be set on one of the other sources. If you look up the manufacturer on-line, you should be able to download the manual.
Jan 13, 2011 | Dukane ImagePro 8755A Multimedia Projector
What steps do I take to configure my 2wire 2701 hg-b to connect directly by ethernet cable to my Directv HD DVR and pick up the dsl signal being transmitted by my primary westell router? Both are wireless...
Connect the cable at both ends and do a red button (inside card door) reset of the DVR. To test the connection, do thus: Menu -> .....setup -> system setup -> network setup -> test connection. If it shows not connected then "reset defaults" and run "connect now"
As a basic security feature the ATT DSL 2Wire 2701HG-B router/gateway requires you to enter its pre-assigned WEP key to connect beyond the unit itself and then to the internet. Since the Direct TV DVR HD24D only does a basic connection without having a place to enter the 2701HG-B WEP key it never actually reaches the internet.
The 2Wire 2701HG-B has the ability for one attached unit to "pass through" its firewall and internal security settings using a so called "DMZplus" mode. I set the HR24D DVR to such a mode within the 2Wire unit and the DVR connected with the internet flawlessly.
Dec 30, 2010 | 2wire (2701HG-B) Wireless Router
I want 2 configure a DVR from remote place and not from the intranet. kindly help me out in solving the issue
To configure the DVR from a remote location you can do it one of two ways:
Create a vpn connection through your router if it supports it or an external units to the remote location. This will make the remote location appear to be local to the dvr.
You can also setup the dvr's internal IP and port on your router through port forwarding. This way certain network access or traffic will be passed directly to the dvr from outside your local network.
Nov 12, 2009 | Dome 4 CCD CCTV Camera Surveillance...
E000732-0001 Error Message
E732 Error code details
  Main cause
 The cable connector has poor connection. The reader controller PCB is faulty.
Condition
 0001 The main controller PCB detects a fault in the communication between the reader controller PCB and the main controller PCB. Connectors
1) Connect the cable [1] for the environment heater.
ir7200-f04-309-01_e.png 2) As needed, connect the reader unit anticondensation heater cable [1].
ir7200-f04-309-02_e.png PLS RATE ME!!!!!!!THANKS MATE.
Sep 23, 2009 | Canon imageRUNNER 8500 Copier
New RC64 will NOT setup with R16-500 Direct TV DVR
The Direct TV remote control I'm currently using is a RC64RB I guess the RB stands for radio broadcast? I learned from researching on the internet that the Direct TV DVR receiver has a different setting for each type of remote. The "RB" remote (the one I'm currently using) has an FCC sticker on the back. Direct TV sent me the wrong type of remote control. AND they have wasted hours of my time. The DT technician that I sought answers from is an idiot!!
Dec 31, 2008 | Televison & Video
Activex blocking usage of speco remote
Open the "internet options" menu through tools. Click on "security" tab. Then select the "internet" and click on custom level. Here, navigate to the "Activex controls and plug-ins" section. Change "Download Unsigned ActiveX Controls" to "prompt" and do the same for the setting directly below that. This should clear up your problem
Nov 03, 2008 | CSi Speco DVR-PC8 Video Recorder
Harmony 880 Logitech tv remote - won't change channels on direct tv
you may need to reprogram your remote, or, if you have your profile setup on the harmony website, reload from there
May 11, 2008 | Logitech Harmony 880 LCD Remote Control
GE Interlogix Dvmre Pro 10 Channel Triplex Dvr with Cdrw Logo
1,686 people viewed this question
Top GE Home Security Experts
Michael Galve
Michael Galve
Are you a GE Home Security Expert? Answer questions, earn points and help others
