Question about GE 24 in. GSD6260JSS Built-in Dishwasher
Dishwasher buzzing when plugged in
I have just moved into this house and the dishwasher has never been used, it is brand new. However, when I plug the dishwasher in, it makes this high pitch buzzing noise. No buttons work, all it does is buzz.
SOURCE: dishwasher not always draining
If the dishwasher drains through the vent pipe on your sink it may be clogged. I had that problem as well. Unscrew the vent cap and look for junk. In my case of all things it was dog hair!!
Posted on Nov 24, 2007
SOURCE: GE Nautilus Dishwasher No water when i turn it on
You need to prime the dishwasher by placing two large cups of water into the bottom.
Posted on Jun 18, 2008
SOURCE: Our Nautilus dishwasher won't turn on. I can hear
The same thing happens with my dishwasher. I have made it work by doing the following. When you start up the cycle, turn the dial to just a tick before "start." If you hear the buzzing, but no water is running, unlock and then lock the dishwasher door again. This usually gets it running. If it's still not running water, unlock, advance the dial a little bit, and lock again. This should work. You need to be around for the early parts of the dishwashing cycle because this machine tends to stop up and buzz without running water until it gets past "short wash." Every time this happens, do the same thing, unlock and lock, and advance the dial a little when necessary. Once you get past "short wash," it should complete the wash without intervention.
Posted on Mar 04, 2009
  • 1543 Answers
SOURCE: I have a GE dishwasher with the following model
The part you are referring to is the pump out solenoid. ( part # WD21X10071) When the dishwasher is suppose to pump out, power is applied to the solenoid and it swings a flap inside the pump assembly to divert the pumped water out the drain instead of up into the dishwasher. If there are no signs of water leakage at the solenoid arm, I'd just ignore the noise. Note: Newer models use a separate drain pump and no longer use the pump out solenoid.
Posted on Apr 19, 2009
  • 10865 Answers
SOURCE: Had the power go out in our house. When power
hello. thanks for choosing fixya. honestly I do recommend that you get a new one. By the time you get your current one repaired you will have almost as much money in it as a new one and you will miss out on lots of things the new ones offer now such as: much more efficient use of power, much more efficient use of water, much quieter. and a much better wash. Regards, J.
Posted on Nov 05, 2009
Testimonial: "I was hoping for some magic answer, but I think he is right, time for a new dishwasher!"
SOURCE: Problem with GE Profile Dishwasher
My delay start switch does not work and the dishwasher beeps periodically throughout the day. Also, I have it set for a 109 minute cycle and after about 20 minutes it says that I only have 35 minutes left in the cycle! Any suggestions?
Posted on Jan 27, 2010
0 characters
1 Points
KitchenAid KUDS30FXSS Dishwasher won't complete cycle
Press the Cancel/ Drain cycle for a few seconds. The dishwasher should reset itself. See if this makes any difference. Also first turn the mains power to dishwasher off and back on.
Apr 13, 2014 | KitchenAid KUDS30FXSS Builtin Dishwasher
Dishwasher is brand new, never been used , plugged in, won't star
Maytag's quality control CANNOT check every unit that comes off the assembly line, so occasionally a bad unit can pass thru, it is fully covered under the manufactures warranty, contact your nearest Maytag authorized service center for repair or replacement.
It would be my recommendation to call the phone number in the back of your owners manual to contact Maytag directly also, just to let them know.
Good Luck !
Mar 22, 2010 | Maytag MDB8601AWB Built-in Dishwasher
Dishes are coming out dirty
Look for buildup over drain screen. Also, look for plugged squirt discharge nozzles on the spray arms. These get plugged.
Sep 18, 2009 | Roper 24 in. RUD3000 Built-in Dishwasher
Maytag MDB3700AWE bottom wash arm does not move Freely by hand
Yes, the wash arm should spin freely. Recommend that you remove the arms and search for what is stopping it.
In addition to hard water, the ultra-cheap dishwasher powder really does/can leave calcium-like deposits behind. Use brand name powder for 30 days and you will see a difference. Never use gel or tablets in any dishwasher.
Adding a whole-house water softener would eliminate 90 % of your problem. The other 10% will be taken care of by not buying ultra generic powder.
Mar 12, 2009 | Maytag MDB9600A Jetclean II Built-in...
Dont know how to clean the dishwasher
go to the dishwashers brand site,click help for your solution.
Jan 05, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
Dishwasher shorts out our electricity supply
this problem is not common specially in dishwasher..ur dishwasher might be stuck in running mode with the motor overloaded and that is the cause that ur house electricity suply is tripping.. i suggest u replace it .. for a new one... it might be harmful for ur house appliances.
Dec 29, 2008 | Neff 24 in. S5456 Built-in Dishwasher
im in the usa and not familer with that brand but under the kickplate at the bottom should be a tech manual id assume nd was for no drain by new house you mean its brand new or new to you
Jan 29, 2008 | Dishwashers
Meale dishwashers
check that you have water supply to the pipe that connects the dishwasher to the wall, when you switch the dishwasher on, dose it buzz quietly, if so there is no water coming to the machine, the fault is with the plumbing, if there is no quiet buzz when switched on then check the water solenoid for open circuit if i have helped please rate me
Sep 27, 2007 | Miele 24 in. G646SC Plus Free-Standing...
GE 24 in. GSD6260JSS Built-in Dishwasher Logo
22 people viewed this question
Top GE Dishwashers Experts
Mike Cairns
Mike Cairns
Michael Thomas
Michael Thomas
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
