Question about SanDisk 2GB Secure Digital Memory Card
I have a 4.0 GB SanDisk. When I insert into my camera it give me an error "Memory Card Error" then says the card is locked. I have checked the slide button on the card and it is in the unlock position and it will not allow me to format in my camera. Is this disk defective?
  • mdawlin Dec 07, 2008
    Is it possible to get it repaired or am I just out of luck?
  • Devlinman Dec 20, 2008
    says its locked when its not.
  • 4,472 Answers
Yes it sounds like the disk is defective and I have seen these bad so its definitely the most likely possibility. Sounds like the switch itself to unlock it is bad. Good luck and thanks for using fixya, please take a moment to rate my solution I hope you fin it fixya appropriate.
Posted on Dec 07, 2008
  • Lee A.
    Lee A. Dec 07, 2008
    You can get one on sale for under 15$ even 10$ now. If it is under a year old it will still be covered under their warranty as this is a defect.
    N. America, Canada, S. America:
    SanDisk Corporation
    601 McCarthy Boulevard
    Milpitas, CA 95035
    Tel: 1-866-SANDISK (1-866-726-3475)
    That is the number to inquire about warranty repair/replacement.
    you can also e-mail at
    Thank you,
Memory card locked
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 10, 2014 | Canon PowerShot SX 200 IS Digital Camera
Question for SanDisk SD card 2 GB - Camera is Canon PowerShot SD870 IS Digital Elph Question: When memory card is inserted in my camera the message "memory card error - card locked" shows when...
There is a small switch in the card that is currently in the locked position. you need to move it over to the other position to unlock it.
Aug 06, 2008 | Cameras
My Panasonic DMC-FZ20 says Memory Card Error.
Please check your cameras capability to support larger sized SD cards.It may not support those two SD cards.Also check for slide locks on the side of the cards and slide them to 'open' before inserting.
Hope it helps.Thanks!
Feb 18, 2012 | Panasonic Lumix DMC-FZ20 Digital Camera
OK I keep sliding the lock un lock on the side of the memory card and it still says memory error. I cant do anything with my what??
Welcome to Fixya
Looks like you havea already have a defective memory card. Try to insert a differnet memory card and see if it will give you the same error.
Thank you for using Fixya!
May 31, 2011 | Canon PowerShot A560 Digital Camera
It says memory card error.i took out the sd card and it was not locked and it still says memory card locked. i formated the card also and it still says the same thing.
How big is its capacity ? Some device can only support memory card at certain maximum capacity, if you inserted card with higher capacity it wouldn't able to read it and it would say "card error".
Try to insert another card with lower capacity. i.e. if you have got "card error" notification for inserting 4 Gb memory card, try to insert 2 Gb card
Hope this help, and if you think its helpful RATE please.
Jan 28, 2011 | Canon PowerShot SD790 IS/ IXUS 90 IS...
Cannon Powershot A540 SanDisk SDHC 4 gb I insert the card and receive a memory card error. Can't format
A 4 gb memory card is beyond the capacity of your Cannon A540. It is too large. I would stick with a 1 gb card in that camera.
May 28, 2010 | Canon PowerShot A540 Digital Camera
Memory card Sandisk 4GB gives error memory card
The S50 uses SD cards. Your 4GB card is actually an SDHC card, and will not work in the S50. You will have to confine your choices to cards 2GB and smaller.
May 15, 2010 | Pentax Optio S50 Digital Camera
Inserted new sandisk ultraII 2gb into camera. error message, disk locked. unlocked, still error message
Does it work with other cards? There's a small switch on the memory card reader inside the camera which tells the camera that the card is locked. Most likely this switch is broken. You can try to point it with needle or something but I'm afraid you will have to give it away for a repair to a local repair shop or Canon service center.
Sep 27, 2009 | Canon PowerShot A540 Digital Camera
Locked Memory Card
I use a Nikon D300 and have Sandisk Compact Flash memory cards. i ahve not come across this problem but would suggest that you insert the memory card into your camera and reformat the memory card. This should clear any errors in the system BUT IT WILL ALSO WIPE ANY PHOTOGRAPHS YOU AHVE TAKEN when formating the memory card.
Oct 20, 2008 | SanDisk ULTRA II 4GB Compact Flash Card...
SanDisk 2GB Secure Digital Memory Card Logo
56 people viewed this question
Top SanDisk Electronics - Others Experts
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
