Question about Tappan TEF242 Electric Kitchen Range
Fuse blows when I plug in my Gibson oven/stove
When I plug in my Gibson stove/oven the fust downstairs blows out it does not matter if I have a 30 amp or 20 amp fuse it sparks at the wall and blows fuse out, I can not see any obvious defects with cord I am wondering if there is a fuse inside the back panel that could be blown?
3 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Oven fuse blows - Nothing works
try lifting the stove top assy and checking wires under main top, leading to the elements them selves??? if tis tripping and not allowing to reset its gotta be an obvious short. isit hard wired directly to stove or into a 220 cord and plug???id look again, perhaps remove entire back panel and have someone trip on the breaker you might see where it flashes as it trips off
Posted on Apr 04, 2008
marka19
  • 1430 Answers
SOURCE: My Fridgidaire FEF366BCC just popped my breaker
This sounds like a main control problem. More specifically like one of the relays is shorted. You will need to acess the main control and carefully inspect it for any burn marks. If you don't see any disconnect the main power supply wire going to the main control. Then plug it back in if it trips the breaker the problem is in the power cord or wiring from the cord junction to the main control. If it does not trip the breaker the problem is the main control. Here is a link that should help http://appliancehelponline.com/ovenerc.html
Posted on Jul 21, 2010
Have error message on my ne fiigidaire gallery gas range...error Sd...oven will not work and timer etc will not function properly
Some stoves have an override on the oven side... oven pilot light must be lit or it will go to safe mode. if it is an auto light then check the fuse usually located up by the top left side on bk of stove.
Jan 02, 2015 | Frigidaire Gallery 30" Self-Cleaning...
My Maytag Performa glass top stove does not work. The oven doesn't heat up but the stove top works fine. I checked my fuse box downstairs and it is fine. I checked the stove to see if there were any...
Dear Gina,
It should be one of 3 things.
1) The element has burned out, or
2) The socket the element plugs into has failed, or
3) the wires hooked to the socket have toasted.
Someone must take the stove apart to see.
God bless your efforts.
Oct 26, 2017 | Maytag PER5710 Performa Electric Kitchen...
1984 stove, fuses located on the top of stove/ 30amp keeps blowin
It sounds like the element has a short in it. unplug the range, and take the element out and inspect if for burn marks. check the wires going to the element to make sure they have not shorted.
Jul 01, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Stove oven wont work..
Yes, you can use the Eaton Viking element in place of the Gibson element as long as all mountings are the same.
You should use ceramic washers between the element and the casing to prevent it from grounding out...which is what probably happened to the element in the first place.
Be sure to look for chapped or burnt wiring BEFORE replacing the element. Also look for burnt connectors.
Hope this help you! :)
Apr 11, 2009 | Viking Stove/Oven/Range Timer Knob -...
Oven doesn't work.
HI. thanks for your question. i would replace the 2. 30 amp fuses in the stove. try that. if not repaired. check the timer. it must be set to MANUAL, for the oven to work, check that.thanks the appliance doc. please rate my answer. thanks
Oct 08, 2008 | Ovens
Apr 03, 2008 | Tappan TEF242 Electric Kitchen Range
Tappan TEF242 Electric Kitchen Range Logo
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De GO PATS
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
