Question about Maytag PAV2300 Top Load Washer
WASHER WORKS FINE BUT WILL NOT SPIN
THE WASHER WASHES FINE AND WORKS GREAT EXCEPT FOR IT WILL NOT SPIN. CHECKED THE PUMP AND IT IS NOT LOCKED UP NOR CLOGGED.
  • reginagonzal Dec 08, 2008
    HOW DO I GET TO THE PUMP
  • davidrddwg69 Dec 08, 2008
    ON THE BACK OF THE WASHER THERE IS A PANEL WITH 4 SCREWS IN IT AT THE LOWER LEFT CORNER AND ITS GENERALLY INSIDE IT.
How do i get to the pump?
Posted on Dec 08, 2008
Will not spin on spin cycle
That is a single belt driven washer built by maytag. Check the lid switch for propah operation. If it is fine tip the washer back do an inspection of the beltthemobilian_2528.jpg
Check the pump for tightness sometimes they lock up or get something in em. If that is fine turn the main drive pulley and see if it releases the brake and lets the drum turn easily. One direction it locks the tub and agitates and the other direction is pumps out the water and spins.
Manual and more HERE
Jul 01, 2011 | Magic Chef CAV2000 Top Load Washer
My front load washer won't spin. It goes thru all the rest of the cycles except spin. It doesn't spin between wash and rinse either. It drains great, I've already checked that and no restrictions.
the next thing you will need to do is replace the door lock mechanism this will fail and cause the issue you are having the only other thing would be the main control board,but replace the door lock mechanism first.
Mar 02, 2011 | Frigidaire GLTF2940ES Front Load Washer
I have an Estae(whirlpool) washer that i have had for 9 yrs. It works fine until it get to the spin cycle. Then it stops and the water stays in the washer and will not drain. Every different wash mode...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Dec 12, 2010 | Washing Machines
I got an estate whirlpool washer and it wont spin and i smell a burning smell
YOU HAVE SOMETHING STUCK IN THE WATER PUMP OR YOUR MOTOR COUPLING IS BAD
Jan 15, 2010 | Estate TAWX700JQ Top Load Washer
Spin cycle stopped on 10 yr old Amana washer
its the brushes on your motor or your pump is blocked or defective
Jun 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Washer won't spin
Kenmore HD top load Elite Pak II will not spin on cycle but pumps water out. Loud buzzing/clicking sound while on spin cycle.
Dec 11, 2008 | Washing Machines
Frigidaire front load washer won't final spin
THERE ARE A COUPLE OF CONDITIONS THAT WILL PREVENT THIS UNIT FROM SPINNING :NOT COMPLETELY DRAIN AND FAULTY DOOR LOCK AS SY.
FIRST REMOVE ELBOW ADAPTER HOSE FROM TUB TO PUMP AND MAKE SURE IS COMPLETELY CLEAN ,HOSE STRAINER THEN CHECK IMPELLER @ DRAIN PUMP NOT TO BE BROOKED , DEFORMED .DIRTY OR LOOSE IF IS LIKE THIS REPLACE PUMP IF NOT PUT EVERYTHING BACK TOGETHER ,MAKING SURE THE STRAINER IS ALL WAY DOWN (IF IT HAS ONE) IF NOT IT WILL GET LOOSE AND DAMAGE YOUR OUTHER TUB ,THEN THIS IS IT .
THEN CHECK PRESSURE SW HOSE FOR LEAKS AND BLOW SLOWLY AND CAREFULLY TO CHECK PRESSURE SW .IF CHECKS OK THEN REPLACE DOOR SW ASSY AND RUN ONE IM VERY SURE THIS WILL TAKE CARE OF YOUR SITUATION ;NOW GET ON YOUR KNEES , GET DIRTY AND HAVE A GREAT DAY!
MAYITOJHONES
Nov 09, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing machine wont spin
Try and help it to spin in the spin mode.. if it moves.. sounds like a clutch problem ..IF NOT... you may have something like nail, screw ect... binding the spin tub from moving.. get a flash lite do some close checking inside the spin tub
Aug 28, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Maytag PAV2300 Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
