Question about Sharp ANW9Z WIDE ANGLE COVERSION LENS XVZ9000U Multimedia Projector
Sharp Projector Sharp XVZ9000U projector I replaced Lamp with a new one and the red lamp light is on and nothing will happen can't get the projector to turn on to reset the lamp counter. The red lkamp symbol was blinking then the projector turned off. How do I get it back on
  • 2,237 Answers
To reset lamp timer, hold down enter, arrow down, and arrow right, then press the power button.
Posted on Jun 10, 2009
  • jasbo
    jasbo Aug 18, 2009
    to reset lamp timer, hold down enter, arrow down, and arrow right, then press the power button.
  • jasbo
    jasbo Aug 19, 2009
Replaced new lamp in sharp pg-d3050 projector, but not getting on only led turn green and then red
then ,check the lamp or lamp ballast (integrated with the powersupply)
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Oct 08, 2013 | Sharp Projector lamp Projector Lamp
Sharp projector Bulb replaced but still won't work?
check the ballast
Have a nice day!
Jerry
Lampdeng Limited
Nov 08, 2012 | Sharp Projector Lamp For Xv-z90 Xv-z90e...
I replaced the lamp on my XGC55X Sharp Projector and it worked great for 2 nights (roughly 6 hours). Now it goes to warm up, with the lamp light blinking, and will power down with the status button showing...
Have reset the lamp hours after installing the new lamp? If, not the projector has treated the new lamp as old lamp & refusing to light further. So, reset the lamp hours to zero. To reset the lamp timer do as follows. Plug the power cord into the AC socket of the projector. Switch ON the power of the socket. (not projector) While pressing simultaneously INPUT, ENTER & UNDO on the projector, press ON on the projector. "LAMP 100%" is displayed, indicating that the lamp timer is reset.
If this does not correct your problem then the problem lies in other area. Let me know so that further I can provide you solution. Above things are preliminary
Aug 06, 2011 | Sharp XG-C55X Multimedia Projector
Just replace my lamp with a new one, when i start my projector, everything seems to work fine but the lamp doesn't light up. the lamp light flashes green for 30 second, theres a ''motor'' sound in the same...
HI,
You can visibly inspect the lamp to make sure the bulb behind the glass is intact & the round part of the bulb is clear & round. Otherwise if possible return the lamp for exchange. If the same thing happens then the lamp ballast is likely bad. I have many in stock I can diagnose it.
Apr 14, 2011 | Sharp XR-10X Multimedia Projector
LCD projector shuts off durning use
u have not mentioned how long u have been using this projector. either the lamp life is low or the circuitry protecting the lamp temperature is defective or even the air intake of the fan is inadequate, a filter is fitted for air flow if this is clogged or blocked, lamp temp will rise and unit shuts down. if lamp indicator is yellow or red it is time to change the lamp. if it is red - lamp is totally out, if u turn on the unit four times without replacing lamp, the unit simply wont turn on. one other possibility is power cable and power connections. check power cable too.
Apr 07, 2010 | Sharp Notevision PG-A10X Multimedia...
I bought a new lamp for my sharp XR-11XC. Standaby/on light is flashing and lamp light is red. TI tried two new lamp. all has the same problem. Need help, Thanks!!!
have you reset the lamp timer yet? can't remember the procedure for that one exactly often hold power and down and left arrows whilst plugging in power. Check info on instructions that came with your new lamp.
Nov 18, 2009 | Sharp Projector lamp Projector Lamp
Sharp projector xr10xl standby light flashing and lamp light on what is wrong?
if it's blinking green, nothing is wrong. it's just cooling. if it's blinking red and the lamp is off, the lamp door is open.
Jan 13, 2009 | Sharp XR10XL DLP Projector
PG-C45X projector wont power on
To solve this problem, simultaneously press the "Input", "Enter", and "Undo" buttons. While holding these buttons, press "On". When the project turns on, you should see "LAMP 100%". This indicates that you have successfully reset the lamp life timer.
Nov 17, 2008 | Sharp (BQCXGC50X1) Projector Lamp for...
Won't power up
I had the same problem after I replaced my lamp. You need to hold down the:
On
Enter
Down Arrow
Right Arrow
simultaneously - this resets the lamp counter. After I did that my projector fired right back up.
Nov 22, 2007 | SharpVision XV-Z9000U Multimedia Projector
Open Questions:
ricoh aficio sp C232SF / c231sf When enabled, initializes but does not print Ricoh Aficio SP C232SF / c231sf The situation is. When enabled is initialized, writes that greeedy and is in readiness. No mechanism at this time does not work, except the scanner line. Scanning Starts, black and white is faster than the ruler, the color is slow. The document feeder works off a sheet and hands. After all the manipulations on the display Processig shines indefinitely no mechanism works until you press stop. The same situation when you try to print reports or when sending to print from a computer. the driver stood on the USB bus. Using command center see it all, but printing is also not achieved. Sees the tray and the presence of paper. Now this is the strange print though, and no, the black toner decreases. Already there was an inscription about it on the display and in commands the center shows the decrease in black. Only black. If you press for example copying, will stand and-writes about the heating of the stove no mechanical work and after a couple of seconds is ready. Stove at this time safely lying on the table next to the machine. the line Lamp is normal, but no power is supplied to it. The power supply did not find any problems. In the service you start the registration-work out the engines of development and tape, and a couple of auxiliary. Tried to make init EEPROMy, tried to rewrite the data in it, as if installing a new one-no changes Any ideas and assumptions are accepted And for dessert - a main Board, engine and the controller changed. The situation is quite similar. Sew and successfully both through the grid and through the USB port. I don't know where to look
Sep 23, 2018 | Ricoh Office Equipment & Supplies
See all Sharp ANW9Z WIDE ANGLE COVERSION LENS XVZ9000U Questions
701 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
