Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Reddyheater 150,000 heater had been working great prior to. was running for 15 mins, suddenly shut off, tried to reset, checked filter. the unit's power light comes on and nothing else happens.
    Genius:
  • 1,199 Answers
Look for a fuse!
Posted on Dec 07, 2008
Sudden shut down
It's possible that this is a hardware failure or a power adapter failure. Try to reset the unit and reinstall it again. You can also check for firmware updates available online. Try to use other power adapter as well with the same specs with the original power adapter.
Jan 25, 2014 | Linksys Computers & Internet
Reset computer
give it a few cycles to relearn its self- key on start run, shut down,start and run, shut down and start and check it out- Denny
Dec 31, 2013 | Nissan Murano Cars & Trucks
Jandy Legagy LRZ pool spa heater not Igniting at all?
F4 = bad igniter ... Has this heater worked in the past and just suddenly stopped? Look for a bad igniter.
Nov 25, 2012 | Pool & Spa
Laars N G pool heater keeps shutting off then restarts
check gas pressure and the size of your line if too small a line and too long a run from the meter it will run out of gas in line then line fills back up heater fires and drains line again
Jul 25, 2012 | Teledyne Laars Laars Lite2 Heater 175000...
Torpedo kerosene heater shuts off after 15 seconds, have to push reset and it starts again, what's the problem?
Does it light? If it does it could be the electric eye that sees the flame and keeps the unit running. It is either dirty or bad. remove the eye and clean it. It pulls straight out and has two prongs on it. Does not matter how it goes back in. It is just a switch. Replace and try again. If it still does not light replace the eye.
If you cleaned the eye and or replaced it and it still does not work there are a few more things to check...
  • Not gtting enough fuel. Check the filter. Usually a small in line filter.
  • It also could be the transformer is getting weak. The transformer produces 10,000 volts between the two electrodes that keeps the heater running. I would only change the transformer if everything else checks out.
  • The electrodes may also need adjusted.
  • The nozzle also may not be atomizing the fuel properly to keep the unit running. I recommend changing it at least once a year depending on the use.
There are some good video on YouTube that will give you some great troubleshooting ideas.
Feb 21, 2011 | Heating & Cooling
Richmond power vent water heater won't stay lit. I've reset the unit several times and the unit will run for about 10-15 minuets then shuts down (into lock down). Then I have to shut it off unplug it and...
I have a 40 gal richmond water heater with power vent and had a similar roblem. I call to talk to a tech and he suggested the vacuum switch. I ordered on line. It was $43 plus shipping and I installed it and it did the job. I happy.
Mar 29, 2010 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Air suddenly not coming on Honeywell RTH230B
for starts, check fuses in disconnect box by condensing unit
Aug 20, 2009 | Honeywell Programmable Thermostat Heater
Thermostat turns unit one every 5 min
check your filter if it is dirty it will not allow enough air flow and cause the heat limit stat in the unit to trip causing unit to cut off when it resets it will come back on.
Dec 23, 2008 | Honeywell Focus 6300B 5-2 Days...
Toyostove laser 55
sequence of operation is just like the monitor. combustion blower comes on to purge chamber of fumes. after the delay, the solenoid pump comes on and deposits fuel to the burner mat, within 20 sec the igniter comes on, incandesces and ignites the fuel if there is no flame, the flame rod is supposed to shut down heater and go into a lockout condition until shut off or unplugged to reset. check solenoid pump first. you already know the igniter works. check the fuel filter in the fuel sump might be clogged. check the fuel sump float valve, might be stuck, supposed to hang free in the sump with needle valve open. thermostat is digital just starts and shuts down the burner and solenoid pump.
Dec 13, 2007 | Rinnai Toyostove Direct Vent Heater:...
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
80 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
