Question about E-Machines EMA IMPERIAL GV (845GV) TG3 eMachines (145119) Motherboard
Emachine W2047 No BIOS Start Screen
Computer (BIOS) not starting up; no XP startup screen.
Front panel switch does not turn ON or OFF computer power.
Power supply, CPU and HDD all power on fine.
The HDD works perfect in another computer and powers up Windows XP.
The motherboard is a FIC AM37L model.
Q: What is causing the "no startup" BIOS screen?
CMOS battery, power supply, CPU, MB or graphics card?? Or maybe, the problem lies with the front panel power button and the power supply. I have a spare ATX power supply (new) but it is a smaller size.
    Scholar:
  • 172 Answers
Replace motherboard. Processor socket burnt out, contact me for further support at compdoctor2005@btinternet.com
Posted on Dec 09, 2008
How can i add guest icon to my startup screen
If your computer is not part of a domain. First check if the Guest account is turned on. You will need to be an Administrator. The guest account option is in the User Account control panel. Click Start > Control Panel (in the right hand column). Select the link for User Accounts. Click on the Guest account to turn on the option.
Then you should be able to see an option for switching to the Guest account when you log out of your current account or get to the select user screen when you turn on/restart the computer. (The default is to log in the most recent user.)
If your XP Pro computer is part of a domain, you need to use the Local Users and Groups section of Computer Management. That's in the Control Panel under Performance and Maintenance > System Tools. Right click on an account and select Properties to enable or disable the account.
I hope this helps.
Mar 19, 2014 | Microsoft Windows XP Professional
How can i getthe bios for may acer aspire one series model zg5
Things You'll Need:
  • Acer Aspire laptop
  1. 1
    Click the "Start" button found at the bottom left hand side of your desktop. Select "Turn Off Computer" in the "Start" menu options.
  2. 2
    Click "Restart" in the "Turn Off Computer" dialog box to reboot your computer.
  3. 3
    Watch your computer's reboot display closely. Press "F2" when you see the system keys display at the bottom of the screen, just before the Windows splash screen appears, to access the BIOS panel.
  4. 4
    Make any needed changes in the BIOS and hit the "F10" key to save your changes and exit the BIOS. Your computer will complete the startup process and launch Windows.
Read more: How to Access an Acer Aspire BIOS ' eHow.com http://www.ehow.com/how_5809235_access-acer-aspire-bios.html#ixzz1E2WkwLWf
Feb 15, 2011 | Acer Aspire One PC Notebook
I need to unlock the image on my computer, it was locked to protect my files. Windows simply does not show up on the screen not the start button? I am unable to start my computer! Windows XP, Compaq,...
Try to reset your in bios by entering setup in the startup. All you have to do is to press del or F2 botton some computer use F12 to inter bios setting.Or to remove your battery from the motherboard.
Nov 18, 2009 | Microsoft Windows XP Home Edition
Bluescreen s6000 cant startup. cant go to safe mode
Depends what the message is. Well
If you are getting a Blue screen repeatedly and you can't start up to windows in any custom setting ( from f8 start up menu ) one way to solve the problem is to Use the restore disc or windows installation cd or dvd to install windows into the computer or perform a repair installation if a windows already exists on the computer and the setup can find it.
how to perform a repair installation
this is for xp, but its similar on 2000 and on vista.
insert your Windows XP Setup CD, and restart your computer.
1.When the Press any key to boot from CD message is displayed on your screen, press a key to start your computer from the Windows XP CD.
if not then the computer is not set to start up from a cd, you can either enter the setup / bios to change that setting OR right when you power up the computer look at the screen it will say what button to press in order to enter boot menu or bios, it will very likely be button F12 or similar, it should say on the screen when you power on.
if it doesn't, then you need to go into the bios and change the boot order so that the computer starts from the CD first.
after that you should be able to start from the cd and install the OS (Operating system, eg.Windows)
here's some info on how to work the bios: http://www.whitecanyon.com/how-to-change-boot-order.php
Repeat step 1 when you have changed the boot order.
2.Press ENTER when you see the message To setup Windows XP now, and then press ENTER displayed on the Welcome to Setup screen.
3.Do not choose the option to press R to use the Recovery Console.
4.In the Windows XP Licensing Agreement, press F8 to agree to the license agreement.
5.Make sure that your current installation of Windows XP is selected in the box, and then press R to repair Windows XP.
6.Follow the instructions on the screen to complete Setup.
7.Ones windows is working you will need the drivers for your computer, they are at the makers website, for hp and compaq. www.hp.com for acer http://support.acer-euro.com/drivers/downloads.html for all other brands go to google and write Brand drivers. Should get you to the right place. Dell is most likely www.dell.com and so on.
Jul 12, 2009 | Intel S6240 Notebook
My computer will only turn on in "sleep mode"
When the computer is on try just pushing the power button in and out once. if this doesn't work you may need to change some settings in the startup setup menu to keep sleep mode off. Usually when a computer is turned on there is something like "press F1 for Bios or DEL (something else) for setup" setup is where you'll want to go. it will look like an old MS DOS program but using your arrow keys to navigate you should be able to change the settings.
Jun 19, 2009 | E-Machines eMachines Desktop PC
Can't install new OS
you need to install directly from the vista disc when the computer is powered on, put the disk in and it should ask you to press any button to start from cd..
if not then the computer is not set to start up from a cd, you can either enter the setup / bios to change that setting OR right when you power up the computer look at the screen it will say what button to press in order to enter boot menu, it will very likely be button F12 or similiar, it should say on the screen when you power on.
if it doesnt, then you need to go into the bios and change the boot order so that the computer starts from the CD first. the computer should say what button to press to enter bios or cmos or setup when its turned on
heres some info on how to work the bios: http://www.whitecanyon.com/how-to-change-boot-order.php
ones you get into the vista setup you can empty the hard drive, getting rid of windows xp and then install windows vista over it.
Let me know how that goes,
Thanks,
Ekse
Jun 03, 2009 | Toshiba Portege R100 Notebook
Emachine destop not recognising acer lcd monitor
It sounds more like the computer isn't starting up. The "no signal" message is coming from the monitor itself to tell you it's on but there's nothing coming in to display. Normally no special drivers are required for the monitor, and you'd see at least the computer maker's splash screen and BIOS messages if the computer was starting up properly.
You'll need to determine what is keeping the computer from starting up. Make sure it's getting AC power and that the power light comes on when you press the front panel power button. You may need a power supply. If the computer comes on but doesn't boot you may have memory problems or trouble with the motherboard. But your monitor is working properly.
May 10, 2009 | Microtek C593 15" Flat Panel LCD Monitor
You can test the power button. Remove the wires from the power on pins on the motherboard. Momentarily jump the two pins with a small screwdriver. If the computer starts the power button is bad. If it still doesn't start then something else is wrong. Did you test the memory? Also do all of the fans work, especially the CPU fan? It can't hurt to test with the other PSU. You know the HDD is good. Test one piece of hardware at a time and hopefully you will find the problem.
Jan 07, 2009 | E-Machines eMachines Desktop PC
Startup problem
Dec 20, 2008 | Compaq tc4400 Tablet PC (RL875AW#ABA)
Computers & Internet Logo
234 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
