Question about Samsung RS2534 Side by Side Refrigerator
Samsung Icemaker Problem
The icemaker on my RS2534VQ died in the tray dump position. The manual switch doesn't work. Thinking the motor was toast, I ordered a new assembly - DA97-00258C - which is in route. The next evening the little motor went on by itself, and I couldn't get it to go off. I cut one of the leads. I took the whole thing out today, reconnected the wire, reset the gears to the tray fill position, plugged it in and voila! the thing went on and cycled to the tray dump position, where it stays. And the ice level lever seems stuck in the "up" position. Is this salvageable, or should I just stick the new one in when it arrives? Could there be something somewhere else in this fridge that is connected with this problem? Any help will be appreciated.
  • hoomanm Jul 24, 2010
    My ice tray moves fine and makes ice but for some reason it won't release the ice when it turns. Then the water tries to fill up over the full tray and makes a big mess. Any suggestions?
I also had the ice tray stuck in the dump position. I unplugged it waited 5 minutes and pluged it back in. And the Ice tray moved back into the correct fill position, and the arm did drop down, But now it has not filled with any water. So now what should I try?
Posted on Aug 03, 2009
My Samsung Model RS253BASB side by side refrigerator only dispenses crushed ice no matter what I select. When I ask for ice cubes I get crushed ice. The repairman has been here 3 times and replaced the ice mater 2 times. Then he tells me that its the water itself thats the problem. Not so. My neighbors have ice makers and no one has this problem. Any solutions?<!-- from fixya rte -->
Posted on Aug 14, 2010
  • Todd Estes
    Todd Estes Mar 20, 2015
    Has anyone found out this problem?
I have the same problem. Ice maker has been down for about a year. Didn't want to shell out the cash for repair. Removed clear clear plate. Reset the cog manually as suggested. Hit the reset button. Tray cycled and then filled with water. Looks like it worked. Thank you . . . now I need a new water filter . . .
Posted on Jul 06, 2009
My samsung ice maker is making a clicking sound every 3 seconds or so...After a while it stops but then does it again...annoying! Could it be the water filter?
Posted on Jun 10, 2013
I had the same problem, I took the plug out for 5 minutes, then when I plugged it back in, the tray did return back to the fill position and the lever did drop back down. But now the tray is not filling with water. What should I try Now?
Turn off power to the fridge. To get the lever down, unscrew the front cover of the transparent ice maker water control and lever gear housing, and remove - there is a black rubber tag at the top which needs to be pushed up to allow the front to be removed. Carefully remove the largest gear cog (the others will fall out if you don't hold them back)and the lever will drop down. position the ice tray level and replace the cogs, then replace the front cover. If the cogs aren't worn this should fix the problem.
Posted on Apr 11, 2007
    Problem Solver:
  • 16 Answers
THE PROBLEM COULD BE ON YOUR ICE LEVEL LEVER.THAT LEVER TELLS THE FRIDGE TO STOP MAKING ICE.IF TAHT LEVER IS IN THE UP POSITION IT WONT MAKE IS AND THAT COULD BE WHY THE ICE TRAY STUCKS ON DUMP POSITION.
Posted on Feb 23, 2007
    New Friend:
    Problem Solver:
I turned off the ice maker from the front door panel. I removed the ice maker from the fridge (remove ice bin, then removed the two screws at front of ice maker that attach it to the top of the fridge, then slid the unit forward, disconnected(un-clipped) the power lead. I moved the ice maker to the kitchen counter. The ice maker front assembly and ice tray slide out of the housing (I pressed up on the tab and slid it to the side). With the unit standing upright I removed the 4 screws and removed the clear cover. I pulled the biggest gear out then rotated the tray to the fill position then replaced the large gear. I reinstalled the clear cover and 4 screws and then slid the front assembly back into the housing then installed the whole thing back in the fridge. When Ii pressed the test button on the ice maker, the tray turned but once again stayed in the dump position. I put the ice bin back in and turned on the ice maker then checked again and the tray was in the fill position. Everything working fine now. FYI I did find a small piece of plastic (broken off gear?) inside the gear box that was probably binding things up, so be sure to check for that. It was actually stuck to the large gear I removed (stuck to the clear grease).
Posted on Dec 07, 2014
  • J L Klaassen
    J L Klaassen Dec 07, 2014
    Model referenced above was Samsung RS253BASB
Alright I reset the cogs, cycled it with the reset buttong and again it stuck in the dump position. I did this 10x with the same result. Need help to solve this!
Posted on Jan 17, 2010
I couldn't get my ice tray to move from dump position. I tried re-set but it moved only slightly.
I then turned it off at the mains, counted to ten then turned it back on. Waited a few minuites, opened the freezer door and tardah....it was in its correct position.
Posted on Apr 08, 2008
Thanks, Fredcb. I installed the new ice maker unit, couldn't get it fully cycling either. Called the repairman, who also, in the end, didn't get it working. By that time we noticed the top half of the fridge section wasn't cooling. I called in a Sears tech - who discovered that the neutral lead was dead - a buried wiring problem, which knocked out the evap fan. I guess that wiring short may have also affected the ice maker. The freezer and the bottom half of the fridge kept working. I was $250 into parts and service at that point. To my relief and gratitude, Samsung and their retailer, Best Buy replaced the entire refrigerator. Sam
To replace water filter, turn off icemaker how
The wire like switch that hovers above the icemaker needs to be in the up most position. This shuts the water valve off to the ice maker. Remove the maker tray and dump the existing ice. When changing the filter, twist off and remove as per the directions that come with the replacement filter. Hand tighten and do not twist on with a wrench. The rubber seals are soft and make a positive seal with out too much force.
Mar 17, 2014 | Jenn-Air JCD2389G Side by Side...
Ice maker not dumping ice.
sounds like the icemaker timing or motor is bad. those parts are not replaceable on this model, you would need a new icemaker assembly
May 02, 2012 | Samsung Refrigerators
Whirlpool IceMagic Plus not working.
Pour about 2/3 cup of water into the ice maker . If it dumps the ice but doesn't refill , replace the ice maker . If it doesn't dump , and the cubes stay in the ice maker , replace the ice maker .
The switch on the icemaker for normal , runs the icemaker normaly . In the ice plus , a small fan comes on , blowing the inside air , over the ice maker mold , to help it freeze faster .
Sep 14, 2009 | Refrigerators
Ice cubes not freezing completely before dumping
check evaporator fan if working or u may have a leak , or check condsr fan motor :)
Aug 28, 2009 | Amana ARS2464B Side by Side Refrigerator
Icemaker is not dumping ice. Lever is in the down
the heaters go south in the tray and cant eject , need new one
Aug 25, 2009 | Frigidaire FRS3R5EMB Side by Side...
Will not dump tray...stops at 2:00 position, will not advance
Possible cause of this is. 1st the heater is out. 2nd the motor in the icemaker has a dead spot. If heater then the complete icemaker should be replaced. If motor I would replace the faceplate.Part #150 Should be around $55 for part. You can find parts by visiting u-line at www.u-line.com and under customer service you will see parts locator.
Jun 08, 2009 | U-Line Icemaker
Ice maker overflows
The Icemaker may not be dumping the cubes after they freeze then more water pours in on top of them. The icemaker has a heater which turns the cubes loose and allows them to dump. You may find someone to work on an icemaker, not sure. If this is the case, I would replace the icemaker.
Dec 16, 2008 | Amana Refrigerators
Ice maker leaking water
replace the icemaker fill switch in the icemaker its self its a micro switch behind the gold panel on the front of the icemaker
May 03, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Repost to catriver about ice machine
I have exactly the same problem in a Samsung RS2577SL side by side. The motor is still getting power after it stalls, and you can help it with your finger (pushing hard) to advance to the switch detent on the cam. You can't move the tray at all if the motor isn't getting power. I purchased a new icemaker from repairclinic.com. It worked fine on the 1st test cycle, but never cycled completely again. I think the motor is getting low voltage, but I don't know what it should be. Anyone have a schematic for a Samsung icemaker?
Feb 04, 2007 | Samsung RS2534 Side by Side Refrigerator
Samsung RS2534 Side by Side Refrigerator Logo
5,086 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
