Have 61" rca wide screen tv. hook digital ant to ant A, hooked up sat. to ant B ant A has picture ant B has about three seconds of sound and shuts down no picture at all
  • chance65 Dec 07, 2008
    thanks, i tried that along with hooking sat to a couple of the video inputs with no luck.
    Genius:
  • 2,920 Answers
It sounds like you have a short on ant b try switching them around and see if thet dosent help
Posted on Dec 07, 2008
No picture but have sound
no video output seems the video output part is faulty ask for tech to have a look
Jul 11, 2013 | RCA P61939 61" Rear Projection Television
RCA DRC247N DVD Player No Audio
The separate DVD player has three output cables: video (yellow), right audio (red) and left audio (white?). These connect to the corresponding inputs on the TV. If your cable box also has three similar output cables, you probably do not have a second set of inputs on the TV so what to do? You can purchase three Y adapters that combine two female RCA connectors into one RCA plug and plug everything into your one set of connectors on the TV. However, if your cable box output connects directly to the TV antenna input, the solution is simpler. Post a comment if this approach is not going to work
Oct 13, 2012 | RCA DRC247N DVD Player
Rca tv has sound no picture
Check its line output transofrmer [LOT] and related components. Replace them
Apr 22, 2012 | RCA Televison & Video
I just purchased a Sony flat screen tv and need advice on what wires I need to connect my Denon AVR-3300 to it or to the dish cable box? My remote has these options on the remote to listen in...
Your reciever has three digital optical inputs so, what it comes down to is how many thing do you want to hook up and what input/otput do you have on your TV. Best case scenario would be to hook your cable box directly to your TV Via HDMI out, if you have HD, on your cable box to Sat/cable input on your TV. Next best would be using componenet cables for video and digital optical for audio. Last would be RCA(yellow, white and red, from Cable box to TV input. Then, you would connect your TV to receiver via(best) digital optical, or RCA. You can try to patch the video through the reciever using component or RCA to TV/DBS on receiver then out to TV but. alot of times you will lose the video in the transfer and it uses more cables, thus more margiin for error. You would set your TV menu to cable/sat and your reciever to which ever input you choose.
Jul 03, 2011 | Denon Audio Players & Recorders
I bought a Sharp Aquos HDTV. Am trying to use a digital co-ax cable to run tv thru my reciever. I get no sound. there is only 1 place on each device to hook up this cable. Any suggestions?
I dont wish to assume that when you say receiver, you mean sattelite or cable. Since you may be trying to hook this up to a surround sound reciever...
Let me also clarify, if this is the case, the receiver needs to be turned on AND the selection signal device set to TV or AUX wherever it is you've connected the TV.
Now by receiver, if you actually meant cable or sat box, then the Ext antena from that service connects to that units ANT IN.
Then from there on that unit ANT OUT to your TV SIGNAL IN.
If you want the external surround sound and have the connectors for this. Then you need to send them OUT to the Stereo/Surround receiver TV IN.
Now having said that and assuming that your TV does not have the Red and White Audio RCA connectors... Your Sat or Cable box does... You connect those to the surround sound Receiver Audio IN
Hopefully you'll find this useful.
If this has not answered the situation. Please feel free to come back and provide all components your working with. Surround reciever, Sat, cable, DVD, VCR whatever etc. etc... I'd be more than glad to help you through this
Good Luck
Respectfully
Jun 10, 2011 | Audio Players & Recorders
RCA HD61LPW42. No picture/sound.
Ur high voltage FBT,is dead the block of plastic with a red wire with a cap hook to the CRT(tv tube).Might also have to replace the whole power board?Because just couple parts it hard to determins,what else also ready to burn next!
Sep 12, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Dark picture on RCA Scenium 61 in DLP
Yes, the lamp will gradually get darker as it nears it's end. The rolling lines sounds more like the set is on a local channel for the cable hook up. If your local area has a channel 3 or 4 live terestrial broadcast simply tune the cable box output to the other one, the same for the tv.
If this is cable/local broadcast issue it will go away in Febuary when the NTSC broadcast ends.
Jan 15, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Audio from tv
It sounds like you have the red,white rca cables hooked from the back of the tv to the red,white input on the stereo or the same connection from you hd sat box or hd cablebox. In order to get the same sound quality from tv service as you do on dvd is to run a fiber optic cable or digital coax audio cable from you hd sat box or hd cablebox to your stereo which means no red,white rca cables at all, take them out. Also once you do that you must be on a hd channel to get equal sound quality of a dvd movie. I know on some hd cable or hd sat boxes you have to go in and set them up to dolby digital as well after you hook it up the way I was explaining. Try this and I hope this is helpful.
Nov 09, 2008 | Koss KS4192 System
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
Electro Med Services...
