Question about GE WWSE6260B Top Load Washer
General Electric Washer Model # WWSE3160 Won't Start,Acts dead?.
Washed a load the other day,worked fine,the next day went to wash another small load and changed settings,noticed no lights came on as normal,hit start and nothing.No lights, sounds or nothing,just dead.Checked the fuse panel,was ok,checked outlet and had juice,unplugged washer for a time and tried again,still dead.Any clues on what to check next?.Is there any fuses in the washer control panel?.Thanks for any help,money is tight and need a cheap fix.
Amigaman
  • 248 Answers
SOURCE: Another flood. GE washer
The water sound is normal. There is a solution in the top of inner tub for balance. Is it overflowing...as in not stopping the fill cycle? If so check to make sure small hose is still attached to outer tu at bottom left front. This dome that it connects to can become filled with scum and causes the unit to not know that it's full. This causes flooding. You can try removing hose and cleaning out with thin wire. Sometime only fix is to replace outer tub. Again, this is only if overflowing!!
Another possibility is a bad break allowing outer tub to spin in agitation. This throws water up over sides of tub. Monitor unit when agitating to see if outer tub picks up speed and starts to spin. It is normal for it to index.
Posted on Nov 09, 2007
chris0fer
  • 5 Answers
SOURCE: My washer is leaking...
Open the rear panel on the washer. Check the 3 rubber hoses connected to the pump. Make sure there are no splits, or a **** in any of them. Also look at the pump and make sure the casing is not cracked and dripping (if coins enter the pump they can crack the casing, causing a leak). If there is a leak in a hose, replace that particular hose. If the pump casing is cracked, replace the pump.
Posted on Jun 19, 2008
cbrown801
  • 3 Answers
SOURCE: washer wil not spin or drain out after cycle completed
sounds like drain is plugged. this is a fairly easy fix,and you actually get paid to do it. unscrew the bottom panel of your washer should be 3 screws on the very bottom then you will see a white plug that is about 2 1/2" unscrew it (make sure you have a bowl under it water will leak ) and pull it out. this is where you get paid you will find all kinds of change and junk just clean it out reinstall and your clothes will be a lot drier after the spin cycle
Posted on Mar 30, 2009
SOURCE: GE Front Load Washer Model WBVH5100HWW - door lock light is on
I queryed another site; justanswer.com with technician Larry, who provided the solution. Replace the door latch assenbly part # WH10X1006 $146.99 from GE. A local parts house had the identical under a Whirlpool # WP8182634 for 59.46. Install the new assemble and all is well.
Posted on May 07, 2009
SOURCE: GE Profile wpre6100gowt, wont agitate or spin
same problem
Posted on Sep 06, 2009
No water is coming on at the start of the cycle
check hot & cold hose , take off hose from washer . Put in bucket open water coming or not .
Apr 18, 2017 | Amana ALW895 Top Load Washer
Washer won't spin. Washed bath mats (small) and
Read a post from someone else on this - turned out it works fine, just wouldn't work with the small wet load. I added towels to the bath mat load, washed them, it spins fine. Washed clothes & that worked fine too. Yay!! Not broken. Just not found of small loads of bath mats!
Jan 22, 2010 | Frigidaire ATF6000ES Front Load Washer
I have a Kenmore top load washing machine. I just did a load and it was fine. I went to start a new load and turned on the washer; the agitator starts but there is no water coming in. As the agitator...
Try checking the inlet filters then dig to intake valves to make sore those are operating, next step would be the pressure sensor...
please update me about your progress
Jul 19, 2009 | Hotpoint Aquarius WD63 Front Load...
I have a GE WBVH6240HWW Front load washer. I
i would try to clean the trap out at the bottom, there is a panel on the bottom take that off and clean out the trap, it looks like a turn dial, something like that has happend to me, it cant hurt to try
Feb 24, 2009 | General Electric WBVH6240HWW Front Load...
Frididaire front load washer won't lock
I find that I need to be extra gentle or it won't lock.  Try that.
Jan 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer shows no signs of power
Yup, this is what happened to me. I also get a "44" error code and erroneous beeping. This is exactly what the class action law suit was about. The Whirlpool Calypso's of your type have the red LED and touch controls, right? They go bad internally after a few years, regardless of how much or how little you use them. There is nothing you can do. Order a new or reconditioned control panel, or have it serviced and repaired by a qualified company referred by Whirlpool Service... Don't do this yourself... The part is about $200 or so plus $60 to $80 minimum call out charge, and sometimes the new parts are as bad as the one you currently have. Best Bet... Time to upgrade to something newer. You may spend your money on this repair, yet in a few months, have the same thing again or something else go wrong. It's just not worth the repair.... Indy :)
Sep 14, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Front loading washer door lock
It has not been resolved yet. It has been worked on twice now. It has a new electric panel (not sure what it is really called other than the brain) and part of the motor has been replaced. Now apparently the heater core is not working. The tech told me the heater core probably went out which caused the other 2 issues. I suggest buying the extended warranty if it is ever offered to you. My washer is only 9 month.
Aug 29, 2007 | Frigidaire Affinity ATF7000ES Front Load...
GE WWSE6260B Top Load Washer Logo
187 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
