Question about Lands Phones
Changing phones but same Bluetooth earpiece
I have an 'avant' brand bluetooth handsfree earpiece, and I have just changed mobiles from a SE v600i to a Nokia N95. I had no problems pairing my laptop to the N95, but how do I reset my earpiece, as it paried fine with the SE? I have even deleted the earpiecefrom my SE bluetooth devices etc. The earpiece instructions do not deal with changing to a new phone.
Any helpinsight would be appreciated.
Thanks in advance
Brian
Apparently deleting the earpiece from my SE devices did fix the problem, i just hadn't realised. thanks
Posted on Dec 08, 2008
How to connect bluetooth headset to my nokia c5-03 phone
Hi Madhav,
Thank you for your question at Fixya,
The solution to your problem is as follows :-
  • The blue tooth connection depends on the fact as to whether or not the bluetooth handsfree that you have is compatible with your phone or not , a good idea would be to check it before you buy one.
  • Now if you want to connect your bluetooth handsfree to your mobile , you need to first make sure that your phone's bluetooth connection has been switch on and then it's not hidden and it should be in shown to all mode as this is a nokia phone.
  • When you switch on the bluetooth connection in your phone , then you need to switch on your bluetooth handsfree and then keep it on.
  • Then again you need to go back in the bluetooth option and then select search for paired devices option or new paired device option , then the phone will search for available bluetooth connections.
  • If it detects your bluetooth , please accept that connection and then it will ask you for a pass code , which you have to enter as 0000 and then press ok.
  • That's it! you will have your phone successfully connected to your bluetooth handsfree.
Hope that helps ...:) In case you have any queries, feel free to contact me.
Sep 19, 2011 | Motorola Mobility Bluetooth Headset, Mini...
How do I pair my pama plug n go 11 bluetooth
you must change the bluetooth device,which cannot be done by u,needs technical assistance
Jul 21, 2010 | Cell Phones
How do you connect mobile phone to in car handsfree on a 2003 bmw 320ci se convertaible
To do that ignition off, press and hold the bluetooth pairing button located to center console for 3 sec. switch to ignition key to 1st position(acc) and keep press holding the button for another 3 sec untill the bluetooth pairing sign on then you can start bluetooth and mobile pairing
Nov 23, 2009 | 2003 BMW 330
Motorola earpiece H700 how to setrup earpiece .
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.
2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H700 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Jan 21, 2009 | Motorola Mobility H700 Wireless Headset
Ear piece
Hi Snuggle ,
It depends on kind of cellphone you have. Normally there should be an option of Handsfree in the phone settings. choose bluetooth device it should detect the handsfree from there . connect to your earpiece from the list of devices.
for Example : I have Sony Ericsson W700i
I have that option under Main menu -- > Settings --> Calls --> Handsfree
Hope this is Helpful
Mar 19, 2008 | Jabra BT350 Bluetooth Headset Headset
Bluetooth
Note: The handsfree speaker won’t work
when your phone is connected to a handsfree
car kit or headset.
this is all they have to offer
http://motorola-global-eng.custhelp.com/cgi-bin/motorola_global_eng.cfg/php/enduser/std_adp.php?p_faqid=3056&p_created=1176240143&p_sid=yvNEkhXi&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MjUzJnBfcHJvZHM9JnBfY2F0cz0mcF9wdj0mcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1yaW5nIHdpdGggaGVhZHNldA**&p_li=&p_topview=1
and
vibrate and ring setting may be all you can do
http://motorola-global-eng.custhelp.com/cgi-bin/motorola_global_eng.cfg/php/enduser/std_adp.php?p_faqid=1038
Jan 21, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Cant get v.2 bluesoleil bluetooth dongle to transfer music from my pc to my sonyericsson v600i
ya u can share thro bluetooth but y don u use data cable instead... its easy and fast ...
Dec 07, 2007 | Sony Ericsson V600i Cellular Phone
Transfer a ringtone from my v600i to another phone
Yes i have sent to motorola's many times, activating the bluetooth on the v3 handset can be difficult or confusing, but bluetooth transactions can be made between any two bluetooth enabled phones.
Good Luck!
Nov 11, 2007 | Sony Ericsson V600i Cellular Phone
Bluetooth handsfree problem
Bluetooth uses a technique called spread-spectrum frequency hopping. It changes frequencies 1,600 times every second. A frequency of 2.45 gigahertz (actually between 2.402 GHz and 2.480 GHz, to be exact). For the bluetooth device to work at 100% it needs to be 100% compatiable. More than likely, if you change your earpiece device, you should be able to pickup your songs. If you go to the VerizonWireless website, they should have 100% compatiable devices.
Todays Tivia:
Why is it called Bluetooth?
Harald Bluetooth was king of Denmark in the late 900s. He managed to unite Denmark and part of Norway into a single kingdom then introduced Christianity into Denmark. He left a large monument, the Jelling rune stone, in memory of his parents. He was killed in 986 during a battle with his son, Svend Forkbeard. Choosing this name for the standard indicates how important companies from the Nordic region (nations including Denmark, Sweden, Norway and Finland) are to the communications industry, even if it says little about the way the technology works.
Oct 20, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Handsfree
clean the system connector on the botton of your phone with pure alcohol or change handsfree
Apr 03, 2007 | Nokia 6230
Lands Phones Logo
105 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
