Question about Pioneer AVH-P5700DVD Car DVD Player
Touch screen is out of alignment
When i want to hit escape or any other button i need to hit around it
  • 60 Answers
Sounds like the display has taken a hard hit or alot of shakin!! you might have to send the unit off to be realigned
Posted on Dec 07, 2008
Touch screen sensitive
Sounds like you need a new digitizer. They cost around 10.00.
YouTube
Website
Jul 04, 2013 | Motorola Mobility Rival A455 Cell Phone
Mio moov 300 screen alignment problem
Download the user manual online and look for factory resettings. Follow instructions and it should work. On my Garmin, the same thing happened. On Garmin, you turn the unit off, press and hold the top left corner of your screen, and turn the unit on while pressing the top left corner of the screen. You wait for 10 seconds and a black dot appears and requests you touch it. The dot moves around the screen and you keep touching it. Once done, your screen perimeter is identified and all the letters fall in place when you press them. Good luck!
Dec 02, 2012 | SNK Mio Moov 300 GPS Receiver
LG KS20 touch screen not responding corecttly some times.
LG KS20 touch screen SolutionGo to settings menu - Touch celebration - click correctly touch position - u see done.
or" change your PDA ( touch screen )
Dec 15, 2011 | LG KS20 Smartphone
How to align screen e755 pocket pc
To align your screen
select Settings, System, Align Screen to ajust the touch screen,
If the screen alignment loses calibration it may not be possible to adjust alignment useing the above method.
In that case the align screen command can be executed by simultaneously pressing the power button and scroll button.
useing the stylus when comanded touch the cross hairs and the Pocket PC will align the screen
Feb 24, 2011 | Toshiba e755 Pocket PC
Canon ImageRunner 3570 Touch Screen
you have to do it in service mode.
hit additional functions.....let go
hit the 2 and the 8 key together.... let go
hit additional function ......let go
then on the screen hit copier...
function
panel
touch check
this will put + on the screen touch the + in the 9 possitions it pots up in and then hit reset twice. if this doesnt align it you have to replace the screen.
Aug 11, 2009 | Canon imageRUNNER 3570 Copier
How to fix or escape from htc touch align screen
The quickest way out of the alignment screen is to actually align the screen by pressing the screen whereever the little cross is located on the screen. Or if you don't want to align the screen simpley hit the power button to turn it off and then hit it again to turn it back on.
Jun 05, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Htc touch, touch screen not working
The touchscreen is a thinlike mylar sheet that overlays the screen. Once damaged, all you can do it get it replaced. To verify if the touchscreen is "smashed", try using the thumbwheel or up and down buttons. If you can move around the display, then this means the touchscreen is damaged but will not prevent you from using your device, that is, until you turn it in for repair/replacement.
Mar 20, 2009 | HTC Touch P3450 Smartphone
Touch panel is not working
needs to be replaced , if it does not respong to ur taps have u tried aligning the screen does it work at all or no area is responsive on screen then u can try hard resetting it first but after that it will be guaranteed that ur touch panel is faulty which seems like to me
but one thing u shud now all data will be lost in factory reset process and if u touch panel is faulty u will stuck up in initial aligning process so pls backup first b4 going ahead sync contacts and sms calender an stuff then try this
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
if u are stuck at align process then it is now pretty sure that ur TOUCH PANEL / also called DIGITIZER is faulty u can get it replaced around 60 $ or so
pls rate me fixya for my diagnosis if u like
Mar 06, 2009 | HTC Touch P3450 Smartphone
The touch screen does not appear to be working
needs to be replaced , if it does not respond to ur taps have u tried aligning the screen does it work at all or no area is responsive on screen then u can try hard resetting it first but after that it will be guaranteed that ur touch panel is faulty which seems like to me
but one thing u shud now do all data will be lost in factory reset process and if ur touch panel is faulty u will stuck up in initial aligning process so pls backup first b4 going ahead sync contacts and sms calender an stuff then try this
Mar 05, 2009 | HTC Touch P3450 Smartphone
I have C4200 All-in-One printer.I install new color cartridge, printed align sheet, put it on glass, hit color button. I'm still stuck; this is second question today. There is small window which says click...
Are you sure that there is not an "OK" button and you don't push the actual screen? I am guessing you have to find an "OK" button. I don't think that machine has a touch screen interface. I hope this helps.
Dec 05, 2008 | Office Equipment & Supplies
Pioneer AVH-P5700DVD Car DVD Player Logo
182 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
