Question about Durabrand DWT1905 TV
Having trouble hooking up my DVD player
TThe menu options provided when using the remote do not provide for DVD player and I get blank screen when tuning into Channel 3. I get no video. DVD player is hooked up properly to ports on front of TV. The remote doesn't seem to provide on the menu an option for DVD player hookup or DVD mode. I might need help using the remote. Please email me with any suggestions. Henry Swift (Horseraddish)
I have no problem connecting my dvd player to the tv but i cannot get the cable to work! do you think it is something wrong the the cord itself?
Posted on Sep 30, 2008
Try looking on your tv's menu for "input" or "input select". This should allow you to switch to your front AV inputs. If that doesn't work hook into the coaxial cable in the back of the set (the one for your cable or satellite input. Plug the cable from the output or to tv side of your reciever into the input of the dvd player and run another lenghth of coaxial cable from the output of the dvd player to the coaxial input where your satellite or cable was plugged into the back of your set. When you want to watch a DVD just turn on the DVD player and the picture should come up. When you turn it off your satellite or cable should come right back.
Posted on Feb 20, 2007
Remove close caption
The CC (closed caption) option is usually set (on or off) from your TV's menu screen. From your remote (or TV), select the Menu, then look for Settings, and when you see CC .... you can turn it off. If you provide the TV model, more specific instructions can be provided.
Mar 03, 2014 | Televison & Video
I'm trying to hook up my Panasonic DVD player (model DVD-S29) to a Comcast cable box but have not been successful. My DVD player only has Audio Out connections, with no audio in connections. I...
the cable in should go to the box and cable out from the box to the TV.These should all be coaxial cables correct?Hook up the DVD player to the TV using the red,white,and yellow cables is also correct.In order to watch a DVD,you have to use the input select button on the remote for the TV ONLY to change inputs.If you have a universal remote for the TV and not the original factory remote provided with the TV,you need to use the menu button located on the outside of the TV.I just searched on my flat screen and was unable to find an input select through the menu button.It may not be possible on this TV if you do not have the original remote and if you own a universal.My universal for one of my older TV's is about 7 years old so I do not know if newer ones have an input select option.If they do not,it is most likely due to patents and royalty payments which these cheap remote makers do not want to pay.Anyhow,let me know if this helps.Just comment here and i will get an auto link to your comments.Good luck! Greg
Sep 19, 2010 | Panasonic DVD-S29 DVD Player
Sir, I try change some option by remote controle screen became blank. I want bring back as before how I can do reset?
first press Turn unit off (power off) using remote, then Press "369" on DVD player remote, then press Turn unit on (power on) using remote.
Aug 06, 2010 | Sony DVP-NS67P DVD Player
I'm having trouble with a Logik LPD860 portable dvd player. The screen is very dark and I'm unable to see the settings menu to make it lighter.
I had this problem. I am aware that this thread is pretty old now but it may be useful for others who are looking forward solution. Try pressing the DVD AV OUT button on the remote, work on mine when I had a dim screen with no back light.
Oct 11, 2009 | Televison & Video
Hook up player
Your TV hopefully supportsw more then one unit connecting to it. if not you will need to use an input on one of your units (direct tv unit or DVD player) for the other unit. Example your direct tv is connected to your TV, on the back of your direct tv unit is a video /audio input. connect your dvd player to that input. on your direct tv remote or menu should be an option to use that input.
Aug 25, 2009 | GoVideo Go Video DVD/VCR Combo
While having one too many beers my friend managed to use the remote to get to the 'secret' Service Technician Menu for my LG RC797T DVD recorder to make it Region free. This he did mange to do, however his...
In 480p resolution, you highlight the 16.9 aspect ratio from the TV Aspect menu option in Setup and then type 1397139 on the remote. This brings up the service screen with all options and machine information.
Optimal (best) settings are as follows.
1 : f 2 2 : 35 (this is DivX)
3 : 93 (macrovision?) 4 : f f (Vcd/Svcd)
5 : f f (region free) 6 : c0 (c0 = LG logo)(ce = Insignia)
7 : 04 8 : 15
All I can say is Keep these and and dont mess around or you can kill it....
Apr 17, 2008 | LG Televison & Video
RCA F25645 25in TV.
I have this same TV. The DVD player is either hooked up to the video or s-video input. Go to the Menu (either through the remote or from the front of the TV) and select the Setup option. Go to the part where it asks if you want to use a DVD player. Select yes. Then select Video Input. Exit the Setup. When you hit the DVD button, it will switch to the Video input. The second step is to go into the Menu and select Channel, then go to Video Input Source. From there, select which input you are using for your DVD player, the S-Video or the standard Video (yellow composite cable).
Mar 06, 2008 | RCA F25645 25" TV
4805 blank screen
My first guess would be that the projector can't sync to the DVD player after the reading stage. If correct, you should be able to change the settings on the output of the DVD player.
Feb 25, 2008 | InFocus ScreenPlay 4805 Multimedia...
Durabrand DWT1905 TV Logo
361 people viewed this question
Top Durabrand Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
