Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Will not start
Fridigaire FDB1500LFCO, the heat lock light is on, it will not start, door is closed and latched, reset GFCI on wall near it, tried to press cancel, stil not wking
  • lah_fla Dec 09, 2008
    I have exactly the same problem. Any solution or is it a service call?
I had the same problem. I turned off the breaker on the electrical panel for a minute and the dishwasher reset. It's working now. Yahoo.
Posted on Dec 10, 2008
Quiet partner whirlpool III gold reset
TRY A RESET CODE
Press the "Sani Rinse," "Heated Dry," "Sani Rinse" and "Heated Dry" buttons on the dishwasher's electronic control panel in quick succession to put the appliance in diagnostic mode.
Close the dishwasher door and engage the door latch.
Wait 10 seconds before pressing the "Cancel" button to reset the dishwasher.
Dec 18, 2013 | Whirlpool Gold Dishwasher with Quiet...
Electric dryer not get heat
Inspect the front door lock if "F22" is displayed. Press the "Pause/Cancel" button two times. Close the washer door firmly to latch the door. Remove clothing preventing the door from closing and latching. Press the "Power" button, followed by the "Start" button.
May 12, 2012 | Maytag Epic 7.0 Cu. Ft. SuperSize Capacity...
I have a Whirlpool stove (model# RF385PXE)and I tried to start the self clean oven cycle the letters "door" appeared along with "E1" and "F5". The door is closed all the way. I even tried pushing it closed...
HI. This code is an indicating that the Self clean latch will not lock. Lock mechanism failure. follow the procedure below to address further.
1. If door latched:
A. Disconnect power from unit.
B. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
C. Replace door switch.
D. Re-apply power.
E. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
B. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
C. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Nov 16, 2009 | Ovens
''Clean'' light is blinking, ''Cancel'' does not reset the cycle.
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Apr 01, 2009 | Whirlpool 24 in. DU1055XTP Built-in...
My clean light is flashing....call service to check heater?
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water. Check the element for damage (burnt/shorted).
To clear the flashing light you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Mar 05, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Clean light will not go out
-high temp wash
-heated dry
-high temp wash
-heated dry
Feb 04, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Clean light flashes constanly. Won't clear out to start new cycle
-high temp wash
-heated dry
-high temp wash
-heated dry
Jan 03, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Fridgdaire self cleaning latch
try holding in on the door latch plunger the one that turns the oven light off when you close the door then press start then cancel and inspect the door plunger for any damage
Sep 06, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Kenmore dishwasher, model 665.170 344 01. "Clean" light keeps flashing and will not stop. Have tried everything in the manual and the light still will not stop flashing.
If the clean light flashes 7 times, pauses then repeats...
If the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive).
-high temp wash
-heated dry
-high temp wash
-heated dry
Jul 18, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
My oven door will not close it has a lock button showing can't cancel
make and model??
is not actuallly physically closing??? perhaps the lock/ latch has partially engaged prevetning door from closing, and with the door oopen it cannot do anything for safety reasons. can you see a door /light switch thtyou can depress by hand??? if so push and hold it in the light should go out, and at this point continue to hold in switch and try starting a self clean cycle ( dont worry it wont actually start cleaning right away)it then should activet the latch assy to fully engage and suppoedly lock door, still depressing the button then press thecancel button and the latch should return to the normal resting position and you can close the door
Apr 01, 2008 | Kitchen Ranges
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
290 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
